Coldfusion Protx VSP Form Integration Kit
Do you have a Coldfusion site and wish to integrate it with the Protx payment system? If so then this is the best script for you, by using the VSP Form you do not require SSL encryption because all sensitive details are collected on a Protx secure server.
In this script you will need 6 pages.
  • functions.cfm
  • submit1.cfm
  • submit2.cfm
  • submit3.cfm
  • completed.cfm
  • notcompleted.cfm
I will start with the page functions.cfm this page will contain variables such as your VendorName, EncryptionPassword and your server name.
<CFSCRIPT>
   VendorName="CFProject";
   EncryptionPassword="Passwordhere";
   MyServer="http://cfproject.co.uk/payment/";
vspsite="https://ukvps.protx.com/vps2form/submit.asp";
function base64Encode(plain) {
   output = "";
   output = ToBase64(plain);
   return output;
function base64Decode(scrambled) {
   output = "";
   output = toString(toBinary(scrambled));
   return output;
function simpleXor(InString, Key) {
   KeyList = ArrayNew(1);
   output = "";
   for(i = 1; i LTE Len(Key); i=i+1){
      KeyList[i] = Asc(Mid(Key, i, 1));
   for(i = 0; i LTE Len(InString)-1; i=i+1){
      result = (bitXor((Asc(Mid(InString, i+1, 1))), (KeyList[(i MOD Len(Key))+1])));
      if (result eq 0){
         output = output & urldecode("%00");
      } else {
         output = output & Chr(result);
   return output;
function getTokens(thisString, thisToken) {
   Tokens = arrayNew(1);
   subString = "";
   Tokens = ListToArray ("Status,StatusDetail,VendorTxCode,VPSTxId,TxAuthNo,AVSCV2,Amount,AddressResult,PostCodeResult,CV2Result,GiftAid,3DSecureStatus,CAVV");
   if (REFindNoCase(thisToken&"=", thisString) eq 0) {
      output="";
   } else{
      subString=mid(thisString,REFindNoCase(thisToken, thisString)+len(thisToken)+1,len(thisString));
      i = 1;
      while (i LTE ArrayLen(Tokens)){
         if (Tokens[i] neq thisToken) {
            if (REFindNoCase("&" & Tokens[i], subString) gt 1) {
               substring=left(substring,REFindNoCase("&"&tokens[i], subString)-1);
            if (REFindNoCase("&" & Tokens[i], subString) eq 1) {
               substring="";
         i = i +1;
      output=subString;
   return output;
</CFSCRIPT>
The vspSite variable should be changed depending on which stage of th development you are at, all you have to do is uncomment the appropriate line. For example the extract below is set the send the data to the live site.
//** Simulator site **
//vspSite="https://ukvpstest.protx.com/VSPSimulator/VSPFormGateway.asp";
//** Test site **
//vspSite="https://ukvpstest.protx.com/vps2form/submit.asp";
//** Live site - ONLY uncomment when going live **
The VendorName and EncryptionPassword will be provided to you when you signup with Protx.
Now we more on to the 3 submit pages. these pages will be used to collect appropriate information about the products being sold so they can be saved to your database and sent onto Protx.
Submit1.cfm
<CFSET seed = Randomize(Second(Now()))>
   <CFSET NewID = CreateUUID()>
<CFSET Session.VendorTXCode = "#NewID#">
<FORM ACTION="submit2.cfm" METHOD="POST" ID="form1" NAME="Example">
<TABLE BORDER="1" WIDTH="100%">
<TR>
<TD WIDTH="36%" ALIGN="right"><B>Your Unique Transaction Code</B> </TD>
<TD WIDTH="64%"><CFOUTPUT>#Session.VendorTXCode#
<INPUT type="hidden" NAME="VendorTxCode" VALUE="#Session.VendorTXCode#">
</CFOUTPUT> </TD>
</TR>
<TR>
<TD WIDTH="36%" ALIGN="right"><B>Transaction Value</B> </TD>
<TD WIDTH="64%"><CFOUTPUT>#Form.FinalCost#
<INPUT type="hidden" NAME="Amount" VALUE="#Form.FinalCost#">
</CFOUTPUT> </TD>
</TR>
<TR>
<TD WIDTH="36%" ALIGN="right"><B>Currency</B> </TD>
<TD WIDTH="64%"> GBP <CFOUTPUT>
<INPUT type="hidden" NAME="Currency" VALUE="GBP">
</CFOUTPUT> </TD>
</TR>
<TR>
<TD WIDTH="36%" ALIGN="right"><B>Description of Goods<BR>
</B></TD>
<TD WIDTH="64%"> Items Bought From CFProject
<INPUT type="hidden" NAME="Description" VALUE="Items Bought From CFProject"></TD>
</TR>
</TABLE>
<BR>
<TABLE BORDER="0" WIDTH="100%">
<TR>
<TD WIDTH="50%"><table width="100" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="1" nowrap="nowrap" bgcolor="#BFBFBF"></td>
<td><a href="../checkout.cfm"><img src="../images/back.gif" border="0" /></a></td>
<td width="1" nowrap="nowrap" bgcolor="#BEBEBE"></td>
</tr>
</table></TD>
<TD WIDTH="50%"><cfoutput>
<input type="hidden" value="#Form.CustomerID#" name="CustomerID">
<cfif IsDefined ("Form.Delivery")>
<INPUT TYPE="HIDDEN" NAME="Delivery" VALUE="#FORM.Delivery#">
</cfif>
<INPUT TYPE="HIDDEN" NAME="CartID" VALUE="#FORM.CartID#">
</cfoutput>
<tr>
<td width="1" bgcolor="#BFBFBF"></td>
<td><input name="image" type="image" value="Submit the Order details" src="../images/proceed.gif" /></td>
<td width="1" bgcolor="#BEBEBE"></td>
</tr>
</table></TD>
</TR>
</TABLE>
</FORM>
In this script you will notice a few Form cariables which need to be collected fromt he previous page. These are:
  • Form.FinalCost
  • Form.CustomerID
  • Form.Delivery
  • Form.CartID
This step is the start of the Payment process. More experienced developers may be able to integrate this step with submit2.cfm.
submit2.cfm
For this page we need to get the information sent from the page before and save it into a database.
<cfparam name="FORM.CustomerID" default="">
<cfquery name="cust" datasource="#Application.datasource#">
SELECT *
FROM tblStoreCustomers
WHERE CustomerID = '#FORM.CustomerID#'
</cfquery>
<CFSCRIPT>
   ThisVendorTxCode = form.VendorTxcode;
   ThisAmount = form.Amount;
   ThisCurrency = form.Currency;
   ThisDescription = form.Description;
</CFSCRIPT>
We now need to create a form collecting the rest of the information about the billing and delivery address.
<TABLE ALIGN="right" WIDTH="100%" BORDER="0" CELLPADDING="0" CELLSPACING="0">
            <TR>
               <TD ALIGN="left"><FORM ACTION="submit3.cfm" METHOD="post" ID="form1" NAME="Example"><CFOUTPUT>
               </cfif>
                  <INPUT TYPE="hidden" NAME="VendorTxCode" VALUE="#ThisVendorTxCode#">
                  <INPUT TYPE="hidden" NAME="Amount" VALUE="#ThisAmount#">
                  <INPUT TYPE="hidden" NAME="Currency" VALUE="#ThisCurrency#">
                  <INPUT TYPE="hidden" NAME="Description" VALUE="#ThisDescription#">
                  <INPUT type="hidden" NAME="VendorEmail" VALUE="Sales@cfproject.co.uk">
                  <input type="hidden" name="AllowGiftAid" value="">
                  <input type="hidden" name="ApplyAVSCV2" value="">
                  <input type="hidden" name="Apply3DSecure" value="">
                  <INPUT type="hidden" NAME="CustomerEmail" VALUE="#cust.Email#">
                  <INPUT type="hidden" NAME="BillingAddress" value="#cust.Address1# #cust.Address2# #cust.City#">
                  <INPUT type="hidden" name="BillingPostCode" value="#cust.PostCode#">
                <table width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td colspan="3">If Your Delivery Address Is Different From Your Billing Address Please Enter It Here</td>
</tr>
<tr>
<td width="28%">&nbsp;</td>
<td>&nbsp;</td>
<td width="38%">&nbsp;</td>
</tr>
<tr>
<td valign="top">
<tr>
<td><strong>Billing Address </strong></td>
</tr>
<tr>
<td>#cust.FirstName# #cust.LastName#</td>
</tr>
<tr>
<td>#cust.CompanyName#</td>
</tr>
<tr>
<td>#cust.Address1#</td>
</tr>
<tr>
<td>#cust.Address2#</td>
</tr>
<tr>
<td>#cust.City#</td>
</tr>
<tr>
<td>#cust.PostCode#</td>
</tr>
</table></td>
<td>&nbsp;</td>
<td valign="top"><table width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td colspan="2"><strong>Delivery Address</strong></td>
</tr>
<tr>
<td>Name:</td>
<td><input maxlength="30" name="CustomerName" size="30" value=""></td>
</tr>
<tr>
<td>Address:</td>
<td><textarea rows="3" name="DeliveryAddress" cols="20"></textarea></td>
</tr>
<tr>
<td>PostCode:</td>
<td><input maxlength="10" name="DeliveryPostCode" size="10" value=""></td>
</tr>
<tr>
<td>Contact Number: </td>
<td><input type="text" name="ContactNumber" size="20" maxlength="20"></td>
</tr>
<tr>
<td>Contact Fax: </td>
<td><INPUT TYPE="text" NAME="ContactFax" SIZE="20" MAXLENGTH="20"></td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table></td>
</tr>
</table>
               </CFOUTPUT>
                  <TR>
                     <TD WIDTH="50%">
<tr>
             <td>
</tr>
</table>
                        </TD>
                     <TD WIDTH="50%">
<tr>
</tr>
</table>
                     </TD>
                  </TR>
               </TABLE>
               </FORM>
             </TD>
            </TR>
    </TABLE>
submit3.cfm
Ok this is where it starts to get difficult. This is where we bring it all together and send it off to Protx for payment. what happends here is we gt all of the information and build them together into a crypt string to they cannot be read when being send to Protx you encrypt the data with the Encryption key that protx assign you. we will then save the rest of the data into our database to await conformation of payment.
<cfparam name="SESSION.CustomerID" default="1">
<cfquery name="Customer" datasource="#Application.datasource#">
SELECT *
WHERE CustomerID = '#SESSION.CustomerID#'
</cfquery>
<CFINCLUDE template = "functions.cfm">
<CFSCRIPT>
ThisVendorTxCode = form.VendorTxCode;
if (IsDefined('form.ShoppingBasket')) {
   ThisShoppingBasket= form.ShoppingBasket;
} else {
   ThisShoppingBasket="OFF";
ThisContactNumber = form.ContactNumber;
ThisContactFax = form.ContactFax;
ThisAllowGiftAid = form.AllowGiftAid;
ThisApplyAVSCV2 = form.ApplyAVSCV2;
ThisApply3DSecure = form.Apply3DSecure;
stuff = "VendorTxCode=" & ThisVendorTxCode & "&";
stuff = stuff & "Amount=" & ThisAmount & "&";
stuff = stuff & "Currency=" & ThisCurrency & "&";
stuff = stuff & "Description=" & ThisDescription & "&";
stuff = stuff & "SuccessURL=" & MyServer & "completed.cfm&";
stuff = stuff & "FailureURL=" & MyServer & "notcompleted.cfm&";
if (form.CustomerEmail NEQ "") {
   stuff = stuff & "CustomerEmail=" & form.CustomerEmail & "&";
if (form.VendorEmail NEQ "") {
   stuff = stuff & "VendorEmail=" & form.VendorEmail & "&";
if (form.CustomerName NEQ "") {
   stuff = stuff & "CustomerName=" & form.CustomerName & "&";
if (form.DeliveryAddress NEQ "") {
   stuff = stuff & "DeliveryAddress=" & form.DeliveryAddress & "&";
if (form.DeliveryPostCode NEQ "") {
   stuff = stuff & "DeliveryPostCode=" & form.DeliveryPostCode & "&";
if (form.BillingAddress NEQ "") {
   stuff = stuff & "BillingAddress=" & form.BillingAddress & "&";
if (form.BillingPostCode NEQ "") {
   stuff = stuff & "BillingPostCode=" & form.BillingPostCode & "&";
if (ThisShoppingBasket eq "ON") {
   stuff = stuff & "Basket=3:Sony SV-234 DVD Player:1:GBP170.20:GBP29.79:GBP199.99:GBP199.99:The Fast and The Furious Region 2 DVD:2:GBP17.01:GBP2.98:GBP19.99:GBP39.98:Delivery:1:GBP4.99:----:GBP4.99:GBP4.99&";
stuff = stuff & "Your goods will be dispatched within 7 days.
If you have any problems with your order please do not hesitate to contact us.
We look foreward to dealing with you in the future."
stuff = stuff & "ContactNumber=" & ThisContactNumber & "&";
stuff = stuff & "ContactFax=" & ThisContactFax & "&";
stuff = stuff & "AllowGiftAid=" & ThisAllowGiftAid & "&";
stuff = stuff & "ApplyAVSCV2=" & ThisApplyAVSCV2 & "&";
stuff = stuff & "Apply3DSecure=" & ThisApply3DSecure;
crypt = base64Encode(SimpleXor(stuff,EncryptionPassword));
</CFSCRIPT>
<CFTRANSACTION action="begin">
<cfoutput>
   <CFQUERY datasource="#Application.datasource#" Name="CreateOrderHeader">
      INSERT INTO tblOrders
         (CustomerIDFK, OrderID, OrderDate, OrderTime, TotalCost, Delivery, VendorTxCode, Status, StatusDetail, VPSTxID, TxAuthNo, Curr, ContactNumber, ContactFax, AllowGiftAid, ApplyAVSCV2, Apply3DSecure, CustomerEmail, CustomerName, DeliveryAddress, DeliveryPostCode, BillingAddress, BillingPostCode)
      VALUES (
      '#Session.CustomerID#',
      '#NewID#',
         '#DateFormat(Now(),"mmmm, dd, yyyy")#',
         '#TimeFormat(Now(), "HH:mm:ss")#',
         '#ThisAmount#',
       <cfif IsDefined("Form.Delivery") AND #Form.Delivery# NEQ "">
         '#FORM.Delivery#'
          <cfelse>
NULL
</cfif>,
         '#Session.VendorTXCode#',
         'New',
         'Sent to user for sumbission',
         'null',
         'null',
         '#Form.Currency#',
    <cfif IsDefined("Form.ContactNumber") AND #Form.ContactNumber# NEQ "">
'#Form.ContactNumber#'
<cfelse>
NULL
</cfif>
    <cfif IsDefined("Form.ContactFax") AND #Form.ContactFax# NEQ "">
'#Form.ContactFax#'
<cfelse>
NULL
</cfif>
    <cfif IsDefined("Form.AllowGiftAid") AND #Form.AllowGiftAid# NEQ "">
'#Form.AllowGiftAid#'
<cfelse>
NULL
</cfif>
    <cfif IsDefined("Form.ApplyAVSCV2") AND #Form.ApplyAVSCV2# NEQ "">
'#Form.ApplyAVSCV2#'
<cfelse>
NULL
</cfif>
    <cfif IsDefined("Form.Apply3DSecure") AND #Form.Apply3DSecure# NEQ "">
'#Form.Apply3DSecure#'
<cfelse>
NULL
</cfif>
'#Customer.Email#'
'#Customer.FirstName# #Customer.LastName#'
    <cfif IsDefined("Form.DeliveryAddress") AND #Form.DeliveryAddress# NEQ "">
'#Form.DeliveryAddress#'
<cfelse>
'#Customer.Address1#, #Customer.Address2#, #Customer.City#'
</cfif>
    <cfif IsDefined("Form.DeliveryPostCode") AND #Form.DeliveryPostCode# NEQ "">
'#Form.DeliveryPostCode#'
<cfelse>
'#Customer.PostCode#'
</cfif>
    <cfif IsDefined("Form.BillingAddress") AND #Form.BillingAddress# NEQ "">
'#Form.BillingAddress#'
<cfelse>
NULL
</cfif>
    <cfif IsDefined("Form.BillingPostCode") AND #Form.BillingPostCode# NEQ "">
'#Form.BillingPostCode#'
<cfelse>
NULL
</cfif>
   </cfquery>
</cfoutput>
</cftransaction>
<CFSET OrderID = NewID>
   INSERT INTO tblOrderDetails (OrderIDPK, ItemIDPK, Quantity, Colour, ItemSize, IDtandn, tandncost)
   SELECT '#OrderID#', ItemIDPK, Quantity, Colour, ItemSize, ID, tandncost
   FROM tblCartItems,tblItems
   WHERE ItemIDPK = ItemID
   AND CartIDPK='#Form.CartID#'
   AND Colour = Colour
   And ItemSize = ItemSize
</cfquery>
Ok now we have saved all the data now we just need to show some terms and conditions and send the details off to Protx.
<CFOUTPUT>
<FORM ACTION="#vspSite#" METHOD="post" ID="form1" NAME="Test">
<INPUT TYPE="hidden" NAME="VPSProtocol" VALUE="2.22">
<INPUT TYPE="hidden" NAME="TxType" VALUE="DEFERRED">
<INPUT TYPE="hidden" NAME="Vendor" VALUE="#VendorName#">
<INPUT TYPE="hidden" NAME="Crypt" VALUE="#crypt#">
<TABLE ALIGN="right" WIDTH="100%" BORDER="0" CELLPADDING="4" CELLSPACING="0">
<tr>
<td colspan="2"><div align="center">
<textarea name="Terms And Conditions" readonly="readonly" cols="65" rows="10" id="Terms And Conditions">#Termsandcon.Body#</textarea>
</div></td>
</tr>
<tr>
<td colspan="2"><div align="center">By Clicking on 'Proceed' below you are agreeing to the Terms And Conditions. </div></td>
</tr>
<TR>
<tr>
<td width="1" nowrap="nowrap" bgcolor="##BFBFBF"></td>
<td width="1" nowrap="nowrap" bgcolor="##BEBEBE"></td>
</tr>
</table></TD>
<tr>
<td width="1" bgcolor="##BFBFBF"></td>
<td width="1" bgcolor="##BEBEBE"></td>
</tr>
</table></TD>
</TR>
</TABLE>
</FORM>
</CFOUTPUT>
There we have it, the payment can now be sent to Protx.
completed.cfm
On this page we need to decrypt the information sent back to us from Protx and update the database to tell us the payment has been completed.
<CFSCRIPT>
Decoded=(SimpleXor(base64decode(crypt),EncryptionPassword));
VendorTxCode = getTokens(Decoded, "VendorTxCode");
Status = getTokens(Decoded, "Status");
VPSTxID = getTokens(Decoded, "VPSTxID");
TxAuthNo = getTokens(Decoded, "TxAuthNo");
AVSCV2 = getTokens(Decoded, "AVSCV2");
Amount = getTokens(Decoded, "Amount");
AddressResult = getTokens(Decoded, "AddressResult");
PostCodeResult = getTokens(Decoded, "PostCodeResult");
CV2Result = getTokens(Decoded, "CV2Result");
GiftAid = getTokens(Decoded, "GiftAid");
VBVSecureStatus = getTokens(Decoded, "3DSecureStatus");
CAVV = getTokens(Decoded,"CAVV");
</CFSCRIPT>
<CFQUERY
   NAME="updateOrder"
   DATASOURCE="#Application.datasource#">
   UPDATE tblOrders
      SET
         Status='Authorised',
         TxAuthNo='#TxAuthNo#',
         VPSTxID='#VPSTxID#'
      WHERE VendorTxCode= '#VendorTxCode#'
</CFQUERY>
<cfquery name="order" datasource="#Application.datasource#">
SELECT *
FROM tblOrders
</cfquery>
Now you can just display some details to the user such as the order number and contact details.
<CFOUTPUT>
                  <TR>
                   <TD ALIGN="right" HEIGHT="18"><B><FONT SIZE="2">Order ID :</FONT></B></TD>
                   <TD ALIGN="left" HEIGHT="18">#order.OrderID#</TD>
                </TR>
                  <TR>
                     <TD ALIGN="right" WIDTH="25%" HEIGHT="18"><B><FONT SIZE="2">Vendor Tx ID:</FONT></B></TD>
                     <TD ALIGN="left" WIDTH="75%" HEIGHT="18">#VendorTxCode#</TD>
                  </TR>
                  <TR>
                     <TD ALIGN="right" WIDTH="25%" HEIGHT="18"><B><FONT SIZE="2">Amount:</FONT></B></TD>
                     <TD ALIGN="left" WIDTH="75%" HEIGHT="18">#Amount#</TD>
                  </TR>
                  <TR>
                     <TD ALIGN="right" WIDTH="25%" HEIGHT="18"><B><FONT SIZE="2">VPS Transaction ID:</FONT></B></TD>
                     <TD ALIGN="left" WIDTH="75%" HEIGHT="18">#VPSTxID#</TD>
                  </TR>
                  <TR>
                     <TD ALIGN="right" WIDTH="25%" HEIGHT="18"><B><FONT SIZE="2">Status:</FONT></B></TD>
                     <TD ALIGN="left" WIDTH="75%" HEIGHT="18">#Status#</TD>
                  </TR>
               </TABLE>
               <BR>
               <P>
               <FONT COLOR="##006699">If you have any queries about your transaction, please email us on "<strong><a href="mailto:sales@cfproject.co.uk">sales@cfproject.co.uk</a></strong>" quoting reference &quot;<strong>#order.OrderID#</strong>&quot;</FONT></P>
             </TD>
            </TR>
         </TABLE>
</CFOUTPUT>
On this page you could also send an email to the customer using my Coldfusion Mail Script
notcompleted.cfm
As with the completed page we will need to Decrypt the data sent back to us from Protx, and we will need to update the order with the status of why the order did not complete.
<CFSCRIPT>
StatusDetail = getTokens(Decoded, "StatusDetail");
</CFSCRIPT>
<cfquery name="updateOrder" datasource="#Application.datasource#">
UPDATE tblOrders
SET Status='#Status#',
StatusDetail='#StatusDetail#',
VPSTxID='#VPSTxID#'
</cfquery>
Again we should also show the customer some information about the transaction
<CFOUTPUT>
<TR>
</TR>
<TR>
</TR>
<TR>
</TR>
</TABLE>
<BR>
<P> <FONT COLOR="#006699">If you have any queries about your transaction, please email us on "<strong><a href="mailto:sales@cfproject.co.uk">sales@cfproject.co.uk</a></strong>" quoting reference &quot;<strong>#VendorTxCode#</strong>&quot;</FONT></P> </CFOUTPUT>
And that is the script. There is a lot of room for improvement and extra functionality to be added.
Enjoy
Related Blog Entries
Comments
Cynan Rhodes's Gravatar thanks - this saved loads of time. Protx should be thanking you too...they aren't very clued up on CF!
# Posted By Cynan Rhodes | 01/08/08 19:46
Hung Pham's Gravatar Do you have the codes to AIM integrate to authorize.net?
# Posted By Hung Pham | 17/10/08 14:03
Jonny Shaw's Gravatar Im sorry i dont understand what you mean?
# Posted By Jonny Shaw | 17/10/08 14:35
Dom's Gravatar Thanks for posting this - saved me loads of time. You might want to look at the base64Decode function though, I ran into problems with this not working, which I fixed as per this post - http://www.webmasterkb.com/Uwe/Forum.aspx/coldfusi...
// Initialise output variable
output = "";
// Fix plus to space conversion issue
scrambled = Replace(scrambled," ","+");
// Do decoding
// output = ToString(BinaryDecode(scrambled,"Base64"));
// Return the result
return output;
# Posted By Dom | 07/01/09 17:20
Archives By Subject
Advertising (3) [RSS]
Blog Design (1) [RSS]
CFProject Scripts (2) [RSS]
Coldfusion Charts (3) [RSS]
Coldfusion Functions (5) [RSS]
Coldfusion Overview (1) [RSS]
Coldfusion Tutorials (17) [RSS]
For Sale (2) [RSS]
Image Manipulation (1) [RSS]
Java (1) [RSS]
JavaScript (4) [RSS]
PHP (1) [RSS]
Useful Tools (3) [RSS]
Recent Comments
Coldfusion and Java
Henry Ho said: I'm more interested in writing Groovy with CFGroovy. I think you may want to look into that as well... [More]
Coldfusion and Java
Jeremy P said: Since CF is build on Java, it's very easy/handy to use it. I recently had to "drop down"... [More]
Coldfusion and Java
Kumar said: Similarly to what Ben said, we have used Java objects in ColdFusion to perform certain tasks. Dan V... [More]
Coldfusion and Java
Ben Nadel said: I use Java objects in ColdFusion all the time. The CreateObject( "java" ) method makes it ... [More]
Coldfusion and Java
Steve Brownlee said: Yes, I can provide some advantages, but that's a large discussion. It can provide speed advantages ... [More]
Recent Entries
Coldfusion and Java
Coldfusion Hosting From £2.50
Coldfusion Blog | Coldfusion Hosting | About Me
