In this intermediate tutorial, I'll show you how to create a vector speaker icon. When you break down the elements you'll find it fairly easy. We'll be using some ellipses with gradients, the Grid Tool, and the Mesh Tool to create this icon design.
Final Image Preview
Let's take a look at the final icon design below.
Create a new document that is 8.5 inches wide by 11 inches tall. Then use the Ellipse Tool (L) and create a 6 inch by 6 inch ellipse.
With the ellipse selected, create a Linear Gradient from the Gradient Panel. Add another swatch to the Gradient Slider by clicking just below the slider. Change the first swatch to a 57% black, the second swatch to a 12% black, and the third swatch to a 57% black.
With the Gradient Tool (G), adjust the gradient by clicking and holding Shift, and drag from the top-right of the circle to the bottom-left. Now, the gradient should look like it is at a 45 degree angle.
With the ellipse selected, go to Object > Path > Offset Path to bring up the offset dialog. Change the Offset to -.125 inches.
Change the first swatch on the offset ellipse to a 50% black, the second swatch to a 4% black, and the last swatch to a 50% black.
With the smallest ellipse selected, Offset the path again. This time set the Offset to -.3 inches and change the fill to a 60% black.
With the smallest ellipse selected, Offset the path yet again. This time change the Offset to -.125 inches.
With the new ellipse, create a Radial Gradient from the Gradient Panel and change the first swatch to white and the second swatch to a 100% black.
With the radial gradient ellipse selected, Offset the path at -.3 inches and change the fill color to a 50% black.
Step 10
Offset the latest ellipse again, but this time change the Offset to -.05 inches and change the fill color to a 90 % black.
Step 11
Again, Offset the latest ellipse, but change the Offset to -.125.
Step 12
Create a three swatch Linear Gradient like the first few ellipses. Change the first swatch to a 82% black, the second swatch to a 34% black, and the last swatch to a 82% black. Like the first couple of Linear Gradients, adjust the gradient to a 45 degree angle.
Step 13
With the Rectangular Grid Tool (located under the Line Segment Tool in the Tools Panel) click on the artboard to bring up the Rectangular Grid Tool Options dialog. In the dialog change the Width and Height to 5 inches and change the Horizontal and Vertical dividers to 80.
Step 14
Make sure the grid has a 1 point black stroke with no fill. Then expand the strokes of the grid by going to Object > Path > Outline Stroke. If you don't outline the strokes of the grid, you'll get some unexpected results when you proceed to the next step.
Step 15
With your grid selected, go to Effects > Warp > Twist to bring up the Warp Option dialog. Change the Bend for the Twist effect to 50. Next, expand the appearance of the effect by going to Object > Expand.
Step 16
Place the grid so it is centered over the ellipses. Copy (Command + C) the second to last ellipse (the 90% black filled one) and Paste it in Front (Command + F). Select the copied ellipse and the grid, and press the Intersect Shape Areas in the Pathfinder Panel. Finish it up by pressing the Expand button in panel.
Step 17
Select the ellipse right below the grid (it might be easier to select the ellipse by locking (Command + 2) the grid object. Then Offset the path -1.25 inches. Bring the ellipse to the front and change the gradient so it only has two swatches. Change the first swatch to a 50% black and the second swatch to a 4 % black. Adjust the gradient so the darker color is at the top of the gradient.
Step 18
With the ellipse still selected, Offset the path -.125 inches and change its fill to a 30% black.
Step 19
Withe the Mesh Tool (U), click halfway between the top and center of the ellipse in the middle, which creates a Mesh Point. With the Mesh Point still selected, change the color in the Color Panel to white. Next, use the Mesh Tool again to make a Mesh Point by clicking on the vertical line from the first Mesh Point towards the bottom of the ellipse. Change this Mesh Point to a 40% black.
Step 20
Select the ellipse under the mesh ellipse and Copy (Command + C) and Paste it in Front (Command + F). With the Selection Tool (V), stretch the copied ellipse down from the bottom-middle anchor point. Change the color to a 70% black and send the object behind the grid.
Step 21
The next couple of steps deal with the screws on the edge of the speaker. Create an ellipse that is .16 inches by .16 inches. Then create a Linear Gradient with the same swatches as the ellipse in the middle of the speaker (not the mesh ellipse). Adjust the gradient so the darker color is at the top of the ellipse.
Step 22
Offset the ellipse by .03 inches, and adjust the gradient so the lighter color is at the top of the ellipse.
Step 23
Copy (Command + C) and Paste (Command + V) these two ellipse so you have a total of four screws. Place the screws around the rim of the speaker.
Step 24
Draw a 4 inch by 4 inch ellipse and create a Radial Blend. Change the gradient so the first swatch is black and the second is white.
Step 25
Squish the Radial Gradient ellipse with the Direct Select Tool (V). Place the ellipse behind all the other artwork. Also, line up the center of the ellipse with the bottom of the speaker.
Step 26
That's pretty much it! If you want to add a background color, make sure the drop shadow shape is set to multiply in in the Transparency Panel. For my background, I created a rectangle the size of my document, and used a Radial Gradient with a 75% black as my first swatch and a 100% black as my second swatch.
Final Image
Below is the final image completed!
User Comments
( ADD YOURS )Craig Snedeker August 15th
=D First comment!!! =D
This is an awesome tutorial!!!!! Thanks.
Ali August 15th
Nice.
Dima August 15th
Great tutorial!Very helpful.
Thank you!
pica August 15th
lol… i’m always annoyed that you use inches instead of pixel (or mm…)
but the tutorial is cool
i never knew the Rectangular Grid Tool, now i do
Billy August 15th
Looks great!
Rype August 15th
Pica,
I should start using something more universal than inches. I will probably try pixels over mm.
Andrew Houle August 15th
Great tut. Looking forward to learning more about the rectangular grid tool!
Mr Kuzio August 15th
WOW!
It’s great!
Grant Friedman August 15th
Once again, another great tutorial from Rype!
Burticus August 15th
Love the tutorial…
Whenever I offset a path, AI by default groups the original path with the new which is annoying when you’re trying to select one thing…Does anyone know how to fix this?
Lake August 15th
@Burticus… strangely, that only happens to me on complex shapes…
Good tut - the Twist effect doesn’t look right, but that’s what tuts are for… learning foundations.
Nate August 15th
Awesome job Rype. Thanks man
RabiD August 15th
Great tutorial!Very helpful for me - newbie !
Thank you!
Shane August 16th
Very good tutorial - thanks for posting.
Braden Keith August 16th
oh dis is reaal cool
Grafiko August 17th
wow, it looks great, great work..as always..
PBP August 18th
I loved the tutorial…just a quick note that I found the screws could be a bit improved by using the rectangle tool and sizing it directly in between the second and third ellipse. You then create a symbol from your screw and place them on each rectangle point. Once that is complete, use the Transform–>Rotate option to rotate it 30 degrees. Complete this twice and you end up with something a bit more realistic.
Rype August 18th
Good tip PBP!
vino August 22nd
i couldn’t understand step 16, buddy…………………
Maxdison August 22nd
so cool tutorial.
thx
Kasule August 26th
awesome man, simple but cool al try it .thanks alot
Vector Graphics August 26th
Professional look, cool tutorial. Thanks vectips
samer September 23rd
tihis is realy great!!!!!!!!!!!!!
paullocezar November 13th
very very good!
r0bert November 20th
pretty nice looking end result, thanx man
Add Your Comment
( GET A GRAVATAR )Your Name November 21st
