Preview
Create a Stylish Sports Car Dashboard With Areas of Detailed Realism
Aug 6th in Illustration by Jonathan
In this tutorial, we'll show the advanced Adobe Illustrator artist how to make a realistic sports car dashboard. You should have a solid understanding of Adobe Illustrator tools before you begin this tutorial. We'll be using a variety of tools to create this illustration.
Author: Jonathan
Jonathan is a graphic designer with extensive hands-on knowledge of Adobe Suite Products. He has several years of experience using Adobe Illustrator, specifically, and seeks to share his skills with the design community.
Final Image Preview
Let's take a look at the image we'll be creating.
Final Image
Start off by making a matte that has rounded corners.
Draw a circle to start off the gauge cluster.
Stretch the circle vertically. Duplicate the oval and layer them on top of each other to add depth. Then add a gradient to the outermost oval to simulate metal.
Make a new circle inside the oval and add a blue-green gradient to it.
Add an inner glow by going to the top of the screen and selecting Effect > Stylize > Inner Glow.
Draw a circle and cut off the top, as shown below.
Round the corners by going to the top of the screen and selecting Effect > Stylize > Round Corners. Note, your values may be drastically different than what is shown below. Values are dependent upon the size of the artwork. If you are adding the rounded corners to an object that is very small, you will not have to enter as high of a value as I have entered. If your object is really big, then your values will be higher.
Add an inner glow by going to the top of your screen and selecting Effect > Stylize > Inner Glow.
Create the tick marks around the gauges by drawing a rectangle, while rotating and copying at the same time. Rotate and copy at the same time by first selecting the object, then select the Rotate Tool (R) (shown at the very bottom), and hold down Alt while you click-and-drag. Then release the mouse at the location where you'd like the copied object to fall. Below we are not using any mathematical system to decide where the lines will fall. Just use your eye and make it look good.
Step 10
Once you have the shapes made, use the Pathfinder to merge them. Draw a circle slightly smaller than the tick marks and use the Pathfinder again to eliminate the middle of the tick marks.
Step 11
Create other widths and lengths of tick marks to achieve the effect shown below.
Step 12
Place the tick marks over the top of the gauge.
Step 13
Add numbers using a modern font. The font I've chosen is Dicot. Add an Outer Glow around the numbers to create realism. Again, your variables may not be exactly the same as the variables below. As long as you're satisfied with what it looks like, that's all that matters!
Step 14
Make two arrows that point left and right.
Step 15
Duplicate the arrows and stagger them slightly. Use the Pathfinder Palette to break apart the shapes.
Step 16
Make the top of the arrows black so that the arrows look recessed.
Step 17
Draw a circle and a triangle to begin making the gauge needles.
Step 18
Add a gradient to the circle and one mesh point to the triangle, using the Gradient Mesh Tool. Change the color of the mesh point to pink to give the needle depth.
Step 19
Add a drop shadow using the settings shown below.
Step 20
Position the gauge needle over the gauge.
Step 21
Make the left gauge by duplicating the oval from the first gauge. Rotate the oval slightly to give the impression of foreshortening.
Step 22
Add tick marks around the edges using the tick marks from the first gauge.
Step 23
Small details go a long way in the overall look of the piece. This icon was drawn using mostly simple rectangle shapes.
Step 24
This icon was drawn predominantly using the Rounded Rectangle Tool.
Step 25
Add the gauge needles, half circle, and the temperature.
Step 26
The gauge for RPM's is slightly different than the other two gauges. Use a variation of the tick marks you created before and draw a circle on top of them.
Step 27
Expand the circle by going to the top of your screen and selecting Object > Expand. Select the boxes, as shown below, and click OK. Use the Pathfinder Palette to break apart the shapes. Now you can color each section of the RPM indicator.
Step 28
This is what the completed RPM gauge looks like.
Step 29
Line up all three gauges and make the center gauge the largest.
Step 30
Duplicate the circles that are highlighted below. We will use these circles to make consistent reflections across all three gauges.
Step 31
Draw an oval that covers all three circles. Use the Pathfinder Palette to break apart the shapes. Then delete the portions of the broken-apart shapes that you do not need.
Step 32
Select the objects shown below and go to Object > Transform > Transform Each. Enter the variables shown below to reduce the shapes simultaneously. Reducing the shapes highlighted will create the impression of a recessed area around the shapes.
Step 33
Fill the shapes will a gradient. Then adjust the blending mode and transparency to achieve a translucent effect.
Step 34
Now we're ready to create the dashboard. Start off by drawing an oval. You can achieve some interesting shapes by warping your object. Warp an object by going to Object > Envelope Distort > Make with Warp. Experiment with different styles to create a shape that you like. Get creative, this is all about creativity, not technical prowess.
Step 35
Duplicate the dash board and enlarge or shrink it slightly to create depth.
Step 36
Add a few mesh points using the Gradient Mesh Tool and change their color to create a highlight.
Step 37
Place your gauges on top of the dashboard. Add a subtle Outer Glow around the gauges to help give them brilliance.
Step 38
Don't forget small details. Details really make an illustration appear complete.
Step 39
Gradients are a quick way to simulate depth.
Step 40
Draw a line that follows the perimeter of your dash board. Check Dashed Line in the Strokes Palette and enter a value in the first box to turn your line into a dashed line.
Step 41
We want to add a gradient to the dashed line but gradients cannot be applied to a stroke. We solve this problem by going to Object > Flatten Transparency. Move the Raster/Vector Balance slider all the way to the right, as shown below, then click OK. This will break apart the line and allow you to use a gradient as a fill.
Step 42
Go ahead and add a gradient.
Step 43
Achieve the illusion of motion by first drawing arched shapes similar to the shapes below.
Step 44
Apply a black and red gradient and blur the shape by going to Effect > Blur > Gaussian Blur. In your Transparency Palette select Lighten from the drop down list so that the shape blends in with the artwork behind it. Experiment with the opacity, if your shape is too dark.
Step 45
Give the background an atmosphere by adding a moody gradient.
Step 46
Draw circles and give them different effects to add interest to the background.
Step 47
Add an Outer Glow to the dash board.
Step 48
Last, we'll create a random burst pattern in the background by first drawing a circle. Next go to the top of the screen and select Effect > Distort & Transform > Roughen.
Step 49
Experiment with different variables to give the circle an array of pointed corners. When you're done, place the object behind the artwork, and adjust its opacity to achieve the final effect.
Final Image Preview
The sports car dashboard is complete!
Enjoy this Post?
We'd love your vote!
User Comments
( ADD YOURS )
  1. vino August 6th
    good work…
  2. konkas August 6th
    This tut is full of awesome
  3. Sean Canady August 6th
    This is an excellent tutorial and shows Illustrator’s capabilities!
    Good Job!
  4. Réka August 6th
    I’m in LOVE!!!:)
    Great work!
  5. Grafiko August 6th
    nice techniques, It feels weird without a steering wheel, but good tutorial.
  6. Andrew August 6th
    Awesome! A lot of work, but it looks great!
  7. SpazZ August 6th
    Big fat kudos!! That is an amazing display of Illustrator skills!
  8. greg spradlin August 6th
    Very nicely done!!! I like the clean simple lines used to create this artwork. When it is all put together I think it gives it a nice realistic look. I am trying to apply this approach to the new artwork I do.
  9. Nate August 6th
    This is a pretty crazy tutorial… Crazy in a good way though.
  10. Mark Abucayon August 6th
    wow good job I like it!
  11. Dan August 6th
    Not to shabby
  12. pica August 6th
    woaho!
    this is great! it looks so unbelievably realistic
    just amazing
  13. Ali August 6th
    pretty nice
  14. Clemson August 6th
    Wow. Pretty cool.
  15. w00p August 6th
    Holy smokes!
  16. Ryan Hicks August 6th
    Definitely needs a steering wheel.
    Also don’t like the motion effect of the temp gauge because it doesn’t rise that fast on an actual car.
    If it did … your car needs looked at ;)
    Anyways awesome tut!
  17. MoNsTeR August 6th
    nice gas pump
  18. Reid August 6th
    This is an awesome tutorial, thanks for sharing!
  19. Alex Beltechi August 6th
    Very nice attention to detail. Most people (myself included) would ignore things like foreshortening…
  20. Jonathan August 7th
    As always, thanks for the nice compliments on my work! I appreciate it.
  21. Joefrey Mahusay August 7th
    Cool tut. I gonna try this one!
  22. Shane August 8th
    Wow! The quality of some of these tutorials is some of the best on the whole eden - oops - envato network!
    Great end result and clearly laid out steps! Thanks for posting.
  23. Abhijit V. Chaore August 11th
    I have no words to describe your work……its simply awesome man!!!! Congrats and keep it up…..
  24. Usama August 11th
    WOW …
  25. K3v August 11th
    Nice! Great eye for details!
  26. Braden Keith August 12th
    looks nice/realistic minus the red fade following the speedometer tick
  27. mireille August 19th
    amazing…… very nice effect
  28. IceDesign August 27th
    The tut is awesome. Just a quick heads up. Most likely if you were driving your temp gauge on the left wouldn’t be going up that much. Usually only moves a bit here and there..wouldnt be such a great jump that the tut is kinda showing.
    Unless your car is overheating..but then your just dumb for driving it anyways.
  29. 5ivedance September 25th
    pretty, but the inspiration…i just don’t kown what i want to take
  30. Nausheen October 8th
    Fantastic and realistic work……..
    Keep it up like this..
    Its really very good
  31. Sherlock Holmes October 23rd
    this is really bad..
    it barely explains anything.
    very bad job.
Add Your Comment
( GET A GRAVATAR )
  • Gravatar
    Your Name December 4th
Arrow
