Design a Print-Ready Beer Label in Adobe Illustrator
It's time to roll up your sleeves and get down to business with this full-featured Adobe Illustrator label design tutorial. This one takes you from setup to production of a cool beer label layout.
Although this could be useful for any bottled concoction of your choosing, we are going to be working on printable beer labels for this one. OK, let's do it!
What You'll Learn in This Beer Label Design Tutorial
- How to set up a beer bottle label design in Illustrator
- How to add text and graphics when you create the beer label
- How to create a banner strip for the custom beer label
- How to integrate a photo image into your beer label layout
- How to use the Placeit beer label maker
- How to create an Adobe Illustrator label design
What You'll Need
As well as access to Adobe Illustrator and Adobe Photoshop, you’ll also need to download the following image file and font to follow this tutorial:
You can also check out the photos, borders, and even more fonts from Envato Elements. Get 'em all for a single, flat monthly fee and use them in your printable beer labels.
Jump to content in this section:
1. How to Set Up a Beer Label for Printing
Open a new Illustrator document (File > New or Command-N), and set the beer label size to 11 inches by 8.5 inches in CMYK color mode. Make sure to change the Units and Color Mode as needed.
This could differ if you're aiming for a bottle beer label size or a beer can label size, so measure your props or mockups beforehand.
Select the Rectangle Tool (M), with no Fill and 0.25 pt stroke, and then click once on the stage and enter 4 in wide by 3.5 in high. Select the Ellipse Tool (L), click once on the stage, and enter 2.1 in by 2.2 in. Select both the ellipse and the square, and in the Align panel, center the objects horizontally and vertically.
Select the square, and in the menu, go to Effect > Crop Marks.
Increase the square's size to 4.125 in by 3.875 in. This square will be the image size, which is 1/8 in larger than the crop marks. This ensures no white space when you or the printers cut these labels out. It's a key step if you want to get the appropriate beer label size.
Select All (Command-A), and in the Align panel, toggle the artboard and center the label horizontally and vertically.
Select the square with the crop marks and, from the top menu, select Object > Lock > Selection (Command-2).
2. How to Add Text & Graphics to the Beer Label Design
Once you have the setup for your Adobe Illustrator label design, select the ellipse and Copy it (Command-C). Don't paste it quite yet. Fill the oval with dark green #6B752A
. Give the oval an inside light green #D3E27E
3 pt stroke.
Use the Appearance panel to add an outside dark green #6B752A
1.5 pt stroke.
Go ahead and Paste in Front your copied ellipse (Command-F).
Double-click the Scale Tool to bring up the Scale dialogue panel, and enter 65% in the Uniform field.
Select both ellipses and, in the Pathfinder panel, apply Shape Modes: Minus Front, and then click Expand.
You should still have your original oval in the clipboard, so take the ellipse and Paste in Front again (Command-F).
Double-click the Scale Tool to bring up the Scale dialogue panel, and this time enter 71% in the Uniform field, and click OK.
Select the Type On A Path Tool and choose one of the Envato Elements fonts (I used Bristain Rought Serif font at 23 pt, and Tracking at 130) and set the Fill color to white. Click on the oval and type the brand name of the product—for example, "OLD BARREL"—on the beer label layout.
Adjust the Tracking (the space between the letters), if necessary, by clicking between the letters and pressing Command-Shift-[ or ].
Adjust the baseline, if necessary, by increasing or decreasing the size of the ellipse that the text is on.
View the Rulers by pressing Command-R or Menu > View > Show Rulers, select the type, and drag a horizontal guide from the top ruler to the center of the circle. If the guide isn't visible, then go to Menu > View > Show Guides (Command-;). Use the Selection Tool (V) to drag the handle of the text to the center position.
Select the Ellipse Tool (L). Click and hold Alt-Shift while dragging outward from the center of your oval to create a circle that extends past the empty center of the oval. Fill it with orange #F2781C
and null Stroke.
Right-click > Arrange > Send to Back (Command -Alt-[) to send the orange circle to the back.
3. How to Create a Banner Strip for the Beer Label Badge
Select the Rectangle Tool (M) and click once on the artboard to open the Rectangle dialogue panel. Enter 2.2 in and 0.3 in for the Width and Height.
With the rectangle selected, go to the Gradient panel and choose a horizontal linear gradient color #533930
on each end and #704438
in the middle. Give the rectangle a 1 pt black Stroke, and check the Round Join option.
In the menu, go to Object > Envelope Distort > Make With Warp and choose Squeeze, check Horizontal, and Bend only 2%.
Type in the kind of product, such as "Handcrafted Beer", and center it in the rectangle (I'll stick with Bristain Rought Serif font for all the text).
Select the Rectangle Tool (M) and click once on the artboard. Enter 0.5 in width and 0.3 in height. Give it a 1 pt black Stroke, using the Round Join option again.
Give this rectangle a Linear Gradient with #533930
on the left and #986633
on the right.
With the rectangle selected, go to Object > Path > Add Anchor Points.
With the Direct Selection Tool (A), select the middle point on the right of the rectangle, and drag it towards the center to create the end of the tail. Hold Shift while dragging to force it to be straight.
Place this tail object on the right end of the rectangle, and nudge it down a bit. Send it behind the rectangle: Right-click > Arrange > Send Backward (Command-[).
Copy (Command-C) the tail object and Paste in Front (Command-F).
Right-click the copied tail object and select Transform > Reflect. Choose Vertical and 90 degrees for the angle. Move the reflected tail object over to the left side, holding Shift while dragging to force it to be straight.
Now, a detail to make the banner more realistic: zoom in close to where the right tail meets the rectangle. Choose the Pen Tool (P) and draw a shape with four clicks: the bottom right of the rectangle, the bottom left of the tail, straight up to any position (hold Shift), and back to the beginning point to close.
Fill the shape with a dark brown #2D1C17
and 1 pt rounded black Stroke.
Press Command-[ until the shape is behind the rectangle but in front of the tail.
Copy it (Command-C), and Paste in Front (Command-F).
Right-click > Transform > Reflect > Vertical 90 degrees.
Shift-drag to the same spot on the left end of the beer label banner.
Select the entire banner and go to Object > Envelope Distort > Make With Warp, choosing Arc and 12% for the Bend.
Step 10
Now, let's place the beer label banner into the design.
Click the brand name text "OLD BARREL" so the center point is visible. Drag a vertical guide from the left Ruler to the center point. Place the banner in position, using the vertical guide to keep it centered.
4. How to Draw & Add a Wheat Grain to the Beer Label
Let's try to make stalks of wheat from scratch. Use the Ellipse Tool (L) and create a small thin vertical oval of any color.
Use the Convert Anchor Point Tool (which is nested in the Pen Tool) and click the top point of the oval. Use the Selection Tool (V) and press Alt while dragging to create a copy of this teardrop shape to use as the tip of the wheat in a few steps. Place it aside for now.
Use the Direct Selection Tool (A) and drag the top point up and to the left on our original teardrop shape. With the Direct Selection Tool (A), drag the left curve handle to the right, which curves the teardrop shape. Now it looks more like a grain of wheat.
Double-click the Rotate Tool (R) and choose an Angle of about -20 degrees. You want to get that tip pointing slightly right of vertical.
From the menu, select Effect > Distort & Transform > Transform. We'll repeat the wheat grain to make the rest of the wheat stalk. Check Preview and enter 3 for Copies and -0.45 in (about) for Vertical. Click OK when it looks right.
Copy it (Command-C), Paste in Front (Command-F), and then Right-click > Transform > Reflect, and choose Vertical 90 degrees. Nudge it left into position. Place your copied teardrop on the tip.
Use the Line Segment Tool (\) and create a 2 pt, Round Join, Round Cap, white vertical line for the stem, below the grains.
Select all the wheat elements and make them white.
From the menu, select Object > Envelope Distort > Make with Warp, and choose Arc for the style, check Vertical, and about a 30% Bend.
Place the wheat on the label, resizing and rotating as necessary, and then go to Arrange > Send Backward (Command-[) to send it behind the banner.
Copy (Command-C) and Paste in Front (Command-F).
Right-click, Transform > Reflect, choose Vertical 90 degrees, and move the copy to the right side of the label.
5. How to Integrate Additional Text Into the Beer Label Badge
Add the word 'Wheat', "Ale", "Kolsch", or whatever the type of drink it is. In the menu, go to Object > Envelope Distort > Make with Warp and enter an acceptable negative number in the Bend effect.
Position the text in the bottom middle of the label.
Select and Copy (Command-C) the main large text-on-a-path.
Paste in Front (Command-F). Increase the size so the circle is just larger than the label oval. Use the Selection Tool (V), and click any corner of the text-on-a-path and Alt-Shift-Drag to expand equally.
Type a catchphrase or quote to personalize the product. Decrease the font size as necessary and use the color #6B752A
. Use the Selection Tool (V) to adjust the position of the text on the curve, by dragging the right handle.
6. How to Add a Photo to a Homebrew Beer Label Design
Get a photo of the brewmaster, or any person you'd like to feature on the label. It's the head and shoulders we're looking for. It's very helpful to have the subject on a white background.
Many thanks to wookiestock at deviantart.com for the photo I've used in this tutorial. Open the photo in Adobe Photoshop.
In the Photoshop menu, go to Image > Adjustments > Threshold and adjust the slider until there's a good balance of light and dark in the face. We will need the face area to be contained, as in no breaks along the perimeter of the head, because we will fill the face in with white later.
So for this image, I darkened his left cheek and right ear so there is a complete outline of his head after the threshold is applied.
Use the Elliptical Marquee Tool (M) to create a selection around the head and shoulders. Go to Select > Inverse (Command-Shift-I) and delete everything but the head and shoulders.
Crop (C) and Save (Command-S) the photo.
Add your new face photo to your Adobe Illustrator label design. Select the image and click the Image Trace button in the Properties panel, or select the Black and White Logo preset from the Tracing Presets button, and Expand.
Click Live Paint, and then, with the Live Paint Bucket Tool (K), Fill all the black areas with dark brown #533930
. Fill all the face portions with white. Clean up the image as necessary and place it in the middle of the label.
Now we want the top of the head to pop out from the oval, but the rest to go behind the oval, making a 3D effect.
Select the face, Copy (Command-C), and Paste in Front (Command-F). Right-click and select Ungroup (Command-Shift-G).
In the Pathfinder panel, choose Unite and click Expand to make the face one solid shape.
Use the Knife Tool to chop off the top of the head, and delete the rest by using the Direct Selection Tool (A). Find it hidden under the Eraser Tool (Shift-E).
Select the face and send it back behind the oval. The chopped-off head part will be in front now. Grab the Selection Tool (V) and Scale the face and head shape slightly up.
This beer label for printing is really starting to shape up. All we need now is a background, and it's finished!
7. How to Design a Custom Beer Bottle Label Background
These are instructions considering that we're working with a bottle beer label size, but they also work for a beer can label size. Select the label square and Fill it with light green #D3E27E
. Remove the stroke.
Use the Line Segment Tool (\) to create two horizontal 0.25 pt black lines: one near the top and one near the bottom. Feel free to make them longer than the square, as we will crop them later.
The Blend option makes it easy to repeat these lines evenly across the background. Select them both and, in the menu, go to Object > Blend > Blend Options and choose 50 for Spacing: Specified Steps and click OK.
Now go to Object > Blend > Make to apply the effect. Send the lines behind the artwork but keep them in front of the green background.
Use the Opacity Mask to fade out the lines. Copy (Command-C) the green square and Paste it in Front (Command-F) of the lines, and give it a Radial black and white Gradient, with black in the center.
Select the square and the lines, and in the Transparency panel dropdown menu, choose Make Opacity Mask. Adjust the gradient to fade the lines out in the center.
Make sure to click the left square in the Transparency panel when you are finished editing the opacity mask, because you will not be able to select other elements until you do.
8. How to Prepare a Label Design and Print It
Some printers freak out when they see transparency-related effects, so we will flatten ours to be safe. Select the opacity mask and choose Object > Flatten Transparency.
Select all the text in this file or just Select All (Command-A), and in the menu, choose Type > Create Outlines. This will ensure your typography is preserved. It may be a good idea to save your beer label for printing before this step, in case you want to edit the text later.
Select everything including the crop marks and Group it (Command-G). Change the x-position to 3 in. Copy and Paste in Front another label (Command-F). Move the x-position of the second label to 8 in.
Ungroup (Command-Shift-G) the objects until you can select and delete the horizontal crop marks in the middle of the two printable beer labels.
Congratulations, You're Done!
Here is your final, super tasty beer label for printing! Now you can take a beer label template and create a beer label by yourself.
Thanks for following along, and I really hope your designs are a big hit. Here's the original beer bottle label design I made for "Huja Brew", and a mockup of our custom design using Placeit's beer label maker.
Now it's up to you: choose the beer label size, make your own beer can template in Illustrator, and print it as many times as you want!
Try a Placeit Customizable Beer Label Template
I hope you enjoyed this printable beer labels tutorial and learned a few tricks along the way. Now you are a craft beer label designer!
If you are looking to save time or searching for other mockup designs, templates, and logos, check out these amazing beer label design makers on Placeit.
1. Beer Label Generator for a Stout Beer
For a more serious, royal, sixteenth-century feel, try this beer label generator. It's a simple, clean design, and you can easily adjust the layout and content. Just create the beer label design and print it!
2. Wrestling Mask Beer Label Design Maker
This beer label design maker has a fun approach, with a lucha libre damaged effect to it. You can upload your own custom mask design, change the color tone, and try adding other decorative font styles to it. It's suitable for both a bottle beer label size and a beer can label size.
3. Geisha Beer Label Template
If you are looking for an ornamental, colorful, and exotic design, try out this beer label template. It's easy to adjust the layout content, and you can swap the colors and graphics to create simple and printable beer labels.
4. Lager Beer Label Template
To present a more modern, fresh, geometric style, try this lager beer label template. This is a great option for contemporary and unique brew mixes.
5. Beer Label Maker for a Cool Craft Beer
Too busy to design a beer can template in Illustrator? Make it faster with this cool beer label template. Easily work on this label design and print it. It was specifically designed for a craft beer label layout.
Design Your Own Printable Beer Labels
I hope you found the inspiration today to design your very own bottle beer or beer can template in Illustrator. Or maybe you chose to generate one using the Placeit beer label maker. This second choice is perfect if you don't have the time to work on a beer can template in Illustrator.
Check out these other articles, roundups, and tutorials from Envato Tuts+ for even more design inspiration. Happy brewing!
- How to Create a Detailed Beer Label in Affinity DesignerKevin House04 Apr 2016
- Illustrating a Cool Glass of BeerEren Goksel20 Aug 2008
- How to Create a Jack Daniel's-Inspired Whiskey Label in Adobe InDesign & IllustratorGrace Fussell31 Dec 2023
- How to Design a Wine Bottle LabelLaura Keung01 Jul 2022
- 10 Must-Have Product Mockup TemplatesMelody Nieves16 Jul 2022
- How to Make a Beer Can Mockup in PhotoshopAshlee Harrell30 Mar 2022
- 32 Best Custom Beer Bottle Labels (Using a Beer Bottle Label Maker)Nona Blackman20 Feb 2021
- 25 Best Beer Mockups (Beer Bottles, Cans, Glasses: PSD and Mockup Generator)Nona Blackman14 May 2023
