HDR, or high-dynamic range, photographs have become very trendy—especially among photographers who enjoy creating surreal effects in their images. However, this technique can be used for photo-realism to combine multiple exposures into the ideal image.
This video explains the step-by-step process necessary to create HDR images using Photoshop:
Creating HDR Images Using Photoshop
Huges recommends starting with 3 to 5 exposures of the same image to create an HDR photograph. He outlines the following steps to combine the exposures into the ideal composite:
1. Import the images into Photoshop. Go to the Automate menu (File > Automate > HDR Pro) and choose Merge to HDR Pro.
2. Change to 32-bit. Photoshop will give you all your images along with one of two dialogs. The first, more simple dialog means you’re in 32-bit, while the second, busier one indicates you’re using 16-bit.
3. Remove Ghosts. Layering multiple exposures, especially in situations where some of the content in the image is moving, will result in ghosting between the images. Simply click on Remove Ghosts, and Photoshop will correct the image.
4. Tone the image. Use Camera RAW for toning. If you use Photoshop CC, simply click “Tone in ACR”. If you use Photoshop CS6 or Lightroom 5, save a 32-bit .tif file, then go into Photoshop’s file handling preferences and tell Camera RAW to open those .tif files. Now, you can use your familiar controls to adjust the exposure, open shadows, introduce clarity, add warmth, and make any other adjustments you desire.
Bryan O’Neil Hughes compares his HDR image to the mid-range single capture. He notes that the HDR is much more vibrant, detailed, and shows a great dynamic range. Add this tool to your editing repertoire to add depth and detail to your best photographs.
Like This Article?
Don't Miss The Next One!
