tutorialbunch.com
tutorialbunch about tutorialbunch contact tutorialbunch
Categories
line
menu symbol
Photoshop
dark line
dark line
menu symbol
Illustrator
dark line
dark line
menu symbol
Flash
dark line
dark line
menu symbol
Free Stock Images
dark line
  previous button index button next button
Vector Wing
Hi Friends
You are going to learn how to create vector wing in illustrator through this example, It has been completed step by step and described to makes it easy for the beginner. If you follow every step you surely reach on the final result. You will learn more about pen tool, brush and styles, I am sure you like and enjoy.
Select fill color "#c0bebf" and block the stroke color, select Pen Tool (P key) and draw a wing shape then apply inner glow by following this path (Effect menu > Stylize > Inner Glow). A window appears on the screen and makes settings as done below picture.
vector wings
Select Pen Tool (P key) and draw wing carefully with same fill color but stroke color should be "#4b4b4c".
vector wings
Select Pen Tool (P key) and draw little wing and drag drop in the Brush Panel (F5) then click on the "New Scatter Brush" and adjust all the setting. Draw a line by Pen tool and apply wing brush as done below picture.
vector wings
Select Pen Tool (P key) and draw a wing but make sure it should be large than first, use upper step and make different brush settings then apply.
vector wings
Apply same step to make another one sequence of the wing but make sure the brush setting should be different as done below picture.
vector wings
The wing is completed.
vector wings
Apply any background and shadow that is final result.
vector wings
Santosh Kumar Web & Graphic designer
Santosh Kumar
This is santosh kumar living in New Delhi (India) and love to work as a Web & Graphic Designing. I like to create sketch, background, illustration and vector graphics. Tutorialbunch.com is a very good place where I express my creativity.
Donate Please
Home | Photoshop | Illustrator | Flash | Free Stock Images | Contact Us | Sitemap
Copyright © 2008-2023 Tutorialbunch.com. All rights reserved
Designed by Utkarsh kashyap
