Retouch Basics for Graphic Designers and Photographers
We've got important Photoshop techniques here for you, all focused on improving your photo manipulations and retouches. This tutorial will teach you how make skin smoother, and how to make charming eyes. By simply adjustment layers you will make better colors. Then, you will make grain on skin, to more realistic look.
Preview of Final Results
With this tutorial you will create amazing beauty retouch, which can be used in printed media - like in magazines, flyers, adverts and more. You can use this knowledge in your designs, or even if you are photographer! You'll need Photoshop CS5 or newer to follow this tutorial.
final-results
Tutorial Resources
Open stock photo with the model. Duplicate it - drag layer to "New layer" symbol.
step-001
Now you'll be working on duplicated layer. Choose Clone Stamp Tool. Use soft brush. Hold alt and pick cleaner fragments of skin. Then use stamp tool under her eyes, erase freckles and wrinkles. (Feel like plastic surgeon.) You should play with brush size.
step-002
Go to her forehead. Also with clone stamp tool erase hair strands and wrinkles. Use smaller brush.
step-003
Duplicate layer when clone tool was used. From top menu choose Blur > Gaussian blur.
step-004
Add mask to this layer. Mask everything, but except face and neck. Mask eyes, hair, lips and nose. Facial features will be more detailed, than skin.
step-005
Decrease opacity of this layer to 70%.
step-006
Now her face is dolly-like. Add new layer. From top menu choose Filter > Noise > Add noise.
step-007
Add mask to this layer. Fill it with black.
step-008
Back to layer with blur. Hold alt and click on mask.
step-009
Select all (ctrl + A), then copy (ctrl + c) selected area.
Step 10
Go to noise layer. With alt holding click mask and paste copied mask (Ctrl + V).
step-010
Step 11
Decrease opacity of this layer to 3%. Then change blending mode to overlay. Skin will be look like real.
step-011
Step 12
Add new layer. Pick Big, soft brush and use #d0b3a6 color. Draw some strokes on her face - where skin isn't perfect.
step-012
Step 13
If it's needed, choose from top menu Filter > Blur > Gaussian blur.
step-013
Step 14
Change blending mode of this layer to Soft light. It will make skin lighter.
Pages: 1 2 3
Luminar: AI Photo Editing
Sponsored
Luminar AI lets you turn your ideas into reality with powerful, intelligent AI. Download the photo editor and see how you can completely transform your photos in a few clicks.
17 comments on “Retouch Basics for Graphic Designers and Photographers”
  1. Ich hatte der Zeit nur mitbekommen, er sollte sein amateur dreier Studium Amerika gemacht und Japan für einen Elektronikkonzern gearbeitet haben.
  2. Directions are very unclear. Fragmented sentence and simple directions does not provide the correct way to navigate through photoshop at all. I was very hard to follow these directions without knowing every single little tool in photoshop. Photoshop fucks you up if you don't have everything exactly correct.
  3. Looks just like an advertisement! Very well done. This has certainly given me some good clues into photo retouching.
Leave a Reply
cross
