VBScript Tutorials - Herong's Tutorial Notes
Dr. Herong Yang, Version 4.01
Procedures - Functions and Subroutines
Part:   1   2  3  4  5  6
VB Script Tutorials - Herong's Tutorial Notes © Dr. Herong Yang
Data Types and Literals
Variables
Logic Operations
String Operations
Conditional Statements
Arrays
Loop Statements
Built-in Functions
Variable Inspection
... Table of Contents
This chapter describes:
  • What Is a Procedure?
  • Defining and Invoking Function Procedures
  • Function Procedure Example
  • Defining and Invoking Sub Procedures
  • Sub Procedure Example
  • Rules of Passing Arguments
  • Example - Passing Arguments by Reference
  • Example - Passing Arguments by Value
  • Passing Array as Arguments
  • Variable Scope in Procedures
  • Example - Variable Scopes
Notes and samples in this chapter are based Visual Basic 6.0.
A Procedure is a unit of code outside of the main execution code. But it can be executed by an invoking statement in the main execution code. There are 3 aspects about procedures:
1. Defining a procedure.
2. Invoking a procedure.
3. Exchanging data between the main execution code and a procedure.
VB offers two types of procedures:
1. Function Procedure - A procedure that returns a value explicitly.
2. Sub Procedure - A procedure that does not return any value explicitly.
A "Function" statement defines a function procedure with the following syntax:
   Function function_name(argument_list)
      statement_block
      function_name = return_value
   End Function
where "function_name" is the name of the function, "argument_list" a list of variables used to pass data into and/or out of the function, and "return_value" is the value to be returned explicitly to the invoking statements.
Of course, "argument_list" is optional.
Assigning the return value to the function name is also optional. If not given, default value will be returned to the invoking statements. But this is not recommended.
Invoking a function procedure is simple, no need of any special statements. Just use the function name with an argument list in any expression:
   ... function_name(argument_list) ...
This will cause the system to:
  • Stop evaluating the expression.
  • Map data or variables based on the argument list.
  • Execute the entire statement block defined inside the function.
  • Take the value returned in the function name.
  • Continue to evaluate the expression.
If you want terminate a function procedure early, you can use the "Exit" statement:
   Exit Function
(Continued on next part...)
Part:   1   2  3  4  5  6
Dr. Herong Yang, updated in 2006
VBScript Tutorials - Herong's Tutorial Notes - Procedures - Functions and Subroutines
