Login x
User Name:
Password:
Social Links Facebook Twitter YouTube Steam RSS News Feeds
Members Online
0 Active | 54 Guests
Online:
LATEST FORUM THREADS
CoD: Battle Royale
CoD+UO Map + Mod Releases
Damaged .pk3's
CoD Mapping
heli to attack ai
CoD4 SP Mapping
Tutorials
HL2
ratings:
Awful Rating
Poor Rating
Average Rating
Good Rating
Excellent Rating
Make those gas traps/fires that are in Ravenholm
Versions: You must be logged in to view history.
In this tutorial you will be learning how to make those gas traps/fires in Ravenholm that you can turn on and off.
1) Make a room, a player spawn, light and if you want to some npc_zombies.
2) Make a prop_static and in the World Model keyvalue type models/props_citizen_tech/Firetrap_PropaneCanister01a.mdl then make another prop_static and its World Model keyvalue is supposed to be models/props_citizen_tech/Firetrap_gashose01a.mdl then make a prop_dynamic and in its World Model keyvalue type models/props_pipes/valvewheel002.mdl That will make the first prop_static look like a gas tank, the second like a pipe and the prop_dynamic like a wheel. Now place them so it looks lpretty nice.
3) With the invisible texture make a brush that covers the prop_dynamic but not more. Tie it to an entity (Ctrl+T) and make it a func_Door_rotating. Give it the name valve_1. And in the Flag Menu check Toggle, Use Only, Passable and Door Silent
4) Make some env_fire and place them where you want your fires to be. Name them or it to fire_1.
5) Make some env_spark and place them where those little pipes goes off from the big one to make it look "normal" and name then spark_1.
6) Make a env_firesource and place it in the middle of the env_fire's and make its radius cover the env_fire's and alittle more. Set its itensity / Damage to 100 and its name to firesource_1.
7) Now make a light and choose its color to some fire looking color. Also give it the name light_1 and in the flag section check Initially Dark.
8) Make four ambient_generic. Place one near the env_spark and the others over the env_fire's. The one near the env_spark should have d1_town.GasJet as its Sound Name keyvalue. And on one other d1_town.LargeFireLoop, and on next d1_town.FlameTrapIgnite and on the last d1_town.FlameTrapExtinguish. Set all the ambient_generic to Start Silent in the flag menu and the d1_town.FlameTrapIgnite and d1_town.FlameTrapExtinguish should have the is NOT looped flag checked to. Also name them sound_1
9) Now to the hard part. Open the properties window with your func_door_rotating selected. Then press the Output menu. Click add.
The first output: 1st Line: OnClose 2nd Line: sound_1 3rd Line: Stopsound
The Second Output: 1st Line: OnClose 2nd Line: firesource_1 3rd Line: Disable
The Third Output: 1st Line: OnClose 2nd Line: fire_1 3rd Line: ExtinguishTemporary
The Fourth Output: 1st Line: OnClose 2nd Line: light_1 3rd Line: TurnOff
The Fith Output: 1st Line: OnClose 2nd Line: fire_1 3rd Line: Disable Also set the delay to 2
The Sixth Output: 1st Line: OnOpen 2nd Line: fire_1 3rd Line: Enable
The Seventh Output: 1st Line: OnOpen 2nd Line: firesource_1 3rd Line: Enable
The Eighth Output: 1st Line: OnOpen 2nd Line: light_1 3rd Line: TurnOn
The Ninth Output: 1st Line: OnOpen 2nd Line: sound_1 3rd Line: PlaySound
10) Now make a trigger_hurt with the texture brush and make it cover the fire area.
11) Enjoy burning some zombies :)
Made by TTTC. Thanks to Habboi!!!!!!!
Latest Syndicated News
Codutility.com up and runn...
Nice, and there still using the logo and template for the screenshots, which...
dundy writes...Quote:Call of Duty modding and mapping is barly alive only a ...
Mystic writes...Quote:It seems to me the like the site is completely dead? ...
Partners & Friends
