Thursday, February 08, 2007
How to convert PowerPoint to flash Using Free Tools
It would be exciting if you could convert a PowerPoint presentation to flash in a completely free way. With a lot of net searching and tutorial reading, I was able to do it with some Open Source Tools. You can read this step-by-step tutorial to learn the details.
I launch Open Office in headless mode with a Mac. Then I open an Xterm and do the following
$ cd /Applications/OpenOffice.org 2.0.app/Contents/MacOS/program/
$ ./soffice -headless -accept="socket,port=8100;urp;"
Download JOOConverter from
http://jooreports.sourceforge.net/?q=jooconverter
JOOConverter is an Open Source Java/OpenOffice Document converter to perform conversions between different office document formats.
I use a Java Library JOOConverter to convert my PowerPoint to flash by running
$ java -jar jooconverter.jar powerpoint.ppt flash.swf
The converted flash does not look pretty good with some strange artifacts in it. But it does play with a flash player although no other SWF tool is able to handle or even to read this flash file by Open Office. So I decided to find a tool to tidy up the flash file.
Download Transform SWF from
http://sourceforge.net/projects/transform-swf
The Transform SWF framework is the tool to parse and encode Flash (.swf) files.
I finally managed to find Transform SWF to rewrite the flash file. I Load it into Transform’s internal swf model and then write it out again. With some nasty hacking of the Transform source, I was able to swallow exceptions caused by the out-of-bounds pointers in the swf file generated by swallow exceptions. And once again, it worked.
I think it would be troublesome to convert a PowerPoint to flash in this way if you do not have some programming experience. For the practical things, you may try some commercial converters in the market like Wondershare PPT2Flash Standard and PPT2Flash Professional
Wondershare PPT2Flash Standard at
http://www.sameshow.com/powerpoint-to-flash.php?sid=5
How to use it from
http://www.ppt-to-dvd.com/forum/viewtopic.php?t=1514
Free Trial from
http://www.sameshow.com/download/ppt2flash-download.php?sid=5
Wondershare PPT2Flash Professional at
http://www.sameshow.com/powerpoint-to-flash-pro.php?sid=5
How to use it from
http://www.ppt-to-dvd.com/forum/viewtopic.php?t=1515
Downlaod it from
http://www.sameshow.com/download/powerpoint-to-flash-download.php?sid=5
Labels: , ,
5 Comments:
At 10:52 AM , Blogger MR Liukh said...
Nice tutorial!
I have a tool to burn powerpoint to dvd.
Also share with you :
Presentation to DVD
At 12:50 AM , Blogger Unknown said...
I've used transform to work with swf files in the past. How did you manage to hack transform to handle the out-of-bounds exceptions? I am currently working on trying to find a solution to fix the openoffice generated swf file and would greatly appreciate some direction.
At 8:36 PM , Blogger Norma said...
Try iSpring Free 3.5! It does great job.
At 10:21 AM , Blogger Unknown said...
Hi,
I tried the same and visited so many forums for that. Ultimately found the solution here.
www.ppt2flashsdk.com
Hope it will help you.
At 12:42 AM , Blogger Rick said...
I found and use another solution: Print2Flash. Converting PPT/PPTX files to Flash using Print2Flash is a piece of cake. Also, they have an SDK for invoking conversion from programming languages such as C#, PHP, C++, etc. The product and SDK are available for download at their site: www.print2flash.com
Post a Comment
Subscribe to Post Comments [Atom]
<< Home
