“Want to Speed-Up Your PC?”
Manage our Startup Programs. Read on to find out how…
By simply managing your start up programs and services, you can speed up your PC performance considerably. This adjustment should affect boot your CPU access time and your internet speed. Following the steps below to speed up computer access time by micromanaging your start up programs and services.
If you want a hard drive defragment software tool. A registry cleaner is a great piece of software that will perform a defrag regularly and optimize your PC for performance and speed. Click here for a free scan.
However be careful to not uncheck any vital programs that could halt your PC startup. If this happens just simply restart your computer in “Safe Mode” and re-enable the program and services. Also remember to close all applications. Open applications are will not get defragmented.
  • Open your Start menu.
  • Click Run
  • In the command screen type “msconfig.exe”
  • In the “system configuration utility”,
    click either “service” or “startup” tab
  • Uncheck all programs that your are no longer using.
  • Click “OK”
Delete Computer History
Confused??
Dont know which process or program do what? To find out more about the what each process and program does on your PC. Visit the Processlibrary.com
Here is a list of programs and services you dont need unless your are running a network. They are safe to remove from your startup configuration. The removal of these features will speed up your PC during the startup
Unnecessary for Startup
Alerter
Clipbook
Computer Browser
Fast User Switching
Human Interface Access Devices
Indexing Service (Slows the hard drive down)
Messenger
Net Logon (unnecessary unless networked on a Domain)
Netmeeting Remote Desktop Sharing (disabled for extra security)
Remote Desktop Help Session Manager (disabled for extra security)
Remote Procedure Call Locater
Remote Registry (disabled for extra security)
Routing & Remote Access (disabled for extra security)
Server
SSDP Discovery Service (this is for the utterly pointless
“Universal P’n’P”, & leaves TCP Port 5000 wide open)
TCP/IP NetBIOS Helper
Telnet (disabled for extra security)
Universal Plug and Play Device Host
Upload Manager
Windows Time
Wireless Zero Configuration (for wireless networks)
Workstation
Click here to return to the Top 4 ways to speed up your PC article
Popular Articles
Best Registry Cleaner
Fix a Slow Internet Connection
Speed Up Internet Videos
