Disk Cleanup - Correct Shortcut for Vista 64 bit
How to Correct the Disk Cleanup Shortcut in Vista 64 bit
By default in Vista 64 bit (x64), the shortcut in the Start Menu points to the 32-bit (x86) executable for Disk Cleanup. While Disk Cleanup will work fine from this shortcut for most things, there is one function that does not work correctly – the cleaning of System Restore points, Shadow Copies, and Previous Versions. This will show you how to fix this error in the Start menu Disk Cleanup shortcut.
CREDIT TO: Kristan Kenney: Confessions of a Windows Enthusiast
Here's How:
1. Open the Start Menu.​
2. Click on All Programs, Accessories, and then on System Tools.​
3. Right click on Disk Cleanup and click on Properties.​
NOTE: All other Disk Cleanup shortcuts are correct. Just this one has is incorrect.
4. In the Target: area, change it from: (See screenshot below step 5)​
%SystemRoot%\SysWOW64\cleanmgr.exe
TO:
%SystemRoot%\system32\cleanmgr.exe
5. Click on Apply.​
6. Click on Continue in the Access Denied prompt. (See screenshot below)​
7. Click on Continue in the UAC prompt.​
8. You should now see this below for the properties. (See screenshot below step 9)​
9. Click on OK.​
I know my question may sound stupid - but it appears that the new shortcut will do the opposite of what is recommended - the fix seems to be directing the Disk Cleanup shortcut to the 32-bit (x86) executable, which appears not to be x64. The original pointed into the folder SysWOW64 - What is SysWOW64?
Thanks for all the valuable tips and info
My Computer
Hello Bill, and welcome to Vista Forums.
The 32-bit and 64-bit Vista should run out of the System32 folder instead. The WoW64 folder is to allow 32-bit applications to run in a 64-bit Vista, but you can read more in details about it in the link below.
WoW64 - Wikipedia, the free encyclopedia
Hope this helps,
My Computers
System One System Two
  • Operating System
    Windows 10 Pro 64-bit
    Manufacturer/Model
    Custom
    CPU
    Intel i7-8700K 5 GHz
    Motherboard
    ASUS ROG Maximus XI Formula Z390
    Memory
    64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
    Graphics Card(s)
    ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound Card
    Integrated Digital Audio (S/PDIF)
    Monitor(s) Displays
    2 x Samsung Odyssey G7 27"
    Screen Resolution
    2560x1440
    Hard Drives
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    8TB WD MyCloudEX2Ultra NAS
    PSU
    Seasonic Prime Titanium 850W
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Logitech wireless K800
    Mouse
    Logitech MX Master 3
    Internet Speed
    1 Gb/s Download and 35 Mb/s Upload
    Other Info
    Logitech Z625 speaker system,
    Logitech BRIO 4K Pro webcam,
    HP Color LaserJet Pro MFP M477fdn,
    APC SMART-UPS RT 1000 XL - SURT1000XLI,
    Galaxy S23 Plus phone
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    NVIDIA GeForce 940MX
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
