Simple and Easy way to create reflection to images using javascript in 2 steps, check out demo .
Step 1: download reflection.js and place it in ur web site folder so that u can include this file to your site,
Way to include reflection.js to ur site
<script language=”javascript” src=”reflection.js” type=”text/javascript”>
</script>
Step 2: just you need to put class=”reflect” in your image tag.
Code
<img src=”http://webdesigninfostuff.googlepages.com/webdesignj.png” class=”reflect” />
That’s it isnt simple 🙂
download complete file reflect.zip
Visit http://cow.neondragon.net for more reflections.
Very interesting and highly educational
Your blog is nice. I think you should add your blog at http://www.blogadda.com and let more people discover your blog. It’s a great place for Indian bloggers to be in and I am sure it would do wonders for your blog.
Great, i’ll try it
hi setty,
i was clueless until i found your site on google search. your solution worked perfectly for the image that i needed to reflect on my blog sidebar. thanks for your great solution.
Wind Mill
