System Restore Points - Stop XP Dual Boot Delete
How to Stop System Restore Points from being Deleted in Vista and Windows 7 when Dual Booting with XP
When you are dual booting XP with Vista and/or Windows 7, this will show you how to stop XP from deleting all of the System Restore Points and Shadow Copies in Vista and Windows 7 everytime you start XP.
You must be logged in as an administrator to be able to do the steps in this tutorial.
For more information, see also:
Note   Note
In Vista and Windows 7, shadow copies are used to maintain System Restore Points. Additionally, shadow copies are used to maintain Complete PC Backup files. Therefore, when you access the volume from an earlier operating system (XP), it will delete all restore points and all except the most recent versions of Complete PC Backup files in Vista and Windows 7.
Tip   Tip
This problem occurs because the volume snapshot driver that is included with Vista and Windows 7 uses disk structures that are incompatible with earlier versions of Windows. Therefore, the earlier operating system deletes Vista and Windows 7 shadow copies with the associated restore points. This behavior occurs because the earlier Windows operating systems do not recognize the new disk structures.
warning   Warning
This does not actually fix the problem. It is a workaround that will stop XP from deleting the restore points and shadow copies. After you restart XP, you will not be able to access the volume Vista and/or Windows 7 is on from XP. However, you can still access the volume that XP is on from Vista and Windows 7.
It has been reported that some 3rd party disk defragmentation programs could also delete your restore points when used.
OPTION ONE
Using a REG File Download
warning   Warning
This needs to be done in XP, not in Vista or Windows 7. This download assumes that Vista or Windows 7 is installed on the D: drive as the second OS. If this is not true for you, or you need to add another drive to be hidden from XP, then do OPTION TWO below to do this manually with the drive letter that your Vista or Windows 7 is installed on instead.
1. To Stop XP from Deleting Restore Points
A) Click on the Download button below to download the file below.​
Stop_XP.reg
download
B) Go to step 3.​
2. To Restore Default Settings in XP
Restore_Default_Settings.reg
download
3. Click on Save, and save the .reg file to the Desktop.​
4. Right click on the downloaded .reg file and click on Merge.​
5. Approve the merge when prompted.​
6. Restart XP to apply the changes.​
7. When done, you can delete the downloaded .reg file if you like.​
OPTION TWO
Manually Through Registry Editor
warning   Warning
1. Open the Start Menu, click on My Computer to open it, then make note of the drive letter for the Vista and/or Windows 7 installation that you wan to prevent XP from seeing to prevent their restore points from being deleted.​
2. Open the Start Menu, click on Run to open it,, then type regedit and press Enter.​
3. In regedit, navigate to the location below. (see screenshot below)​
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
4. To Stop XP from Deleting Restore Points
A) In the left pane, right click on MountedDevices and click on New and Key.​
NOTE: If you already have the Offline key under MountedDevices, then skip this step and go to step 4C. (see screenshot below step 4C )​
B) Type Offline and press Enter.​
C) In the right pane of Offline, right click on a empty area and click on New and DWORD Value. (see screenshot below)​
D) Type \DosDevices\D: and press Enter. (see screenshot below step 4F)​
NOTE: While in XP, if your Vista or Windows 7 is not showing as being on the D: drive in Computer, then substitute D: with the drive letter that it is shown to be on instead. For example, if it is shown to be on the E: drive, then type \DosDevices\E: instead. Repeat this step if you wish to hide another drive letter from XP.​
E) In the right pane, right click on \DosDevices\D: and click on Modify.​
F) Type 1, and click on OK. (see screenshot below)​
G) The registry should now look like this. (see screenshot below)​
H) Repeat steps 4C to 4G for any other drive letter that you want to prevent them from being seen by XP.​
I) Go to step 6.​
5. To Restore the Default XP Settings
A) In the right pane of Offline, right click on \DosDevices\D:, and click on Delete. (see screenshot below step 4H)​
B) Click on Yes to confirm the deletion.​
C) Repeat step 5 for any other listed drive letter that you would like XP to be able to see again.​
  • Stop_XP.reg
  • Restore_Default_Settings.reg
Wonderful overview--THANK YOU!
Shawn, do you know if need to install Vista BEFORE adding this reg tweak, but before rebooting to XP?
Noel
My Computer
Hi Noel,
Yes, Vista will need to be installed first. Afterwards, just boot into XP and apply the reg tweak to hide Vista from XP.
My Computers
System One System Two
  • Operating System
    Windows 10 Pro 64-bit
    Manufacturer/Model
    Custom
    CPU
    Intel i7-8700K 5 GHz
    Motherboard
    ASUS ROG Maximus XI Formula Z390
    Memory
    64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
    Graphics Card(s)
    ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound Card
    Integrated Digital Audio (S/PDIF)
    Monitor(s) Displays
    2 x Samsung Odyssey G7 27"
    Screen Resolution
    2560x1440
    Hard Drives
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    8TB WD MyCloudEX2Ultra NAS
    PSU
    Seasonic Prime Titanium 850W
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Logitech wireless K800
    Mouse
    Logitech MX Master 3
    Internet Speed
    1 Gb/s Download and 35 Mb/s Upload
    Other Info
    Logitech Z625 speaker system,
    Logitech BRIO 4K Pro webcam,
    HP Color LaserJet Pro MFP M477fdn,
    APC SMART-UPS RT 1000 XL - SURT1000XLI,
    Galaxy S23 Plus phone
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    NVIDIA GeForce 940MX
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
Hello,
I run a Dual Boot XP and Vista . I had the described problem : the restore points of Vista deleted by XP . I applied the suggested fix in the registry and the restore point problem is solved.
BUT now from time to time (not always) when running XP and I request a restart I receive a black screen and the PC reboots... no "Saving your settings" , no "Shutting down" window anymore ...:shock:
When I request a shutdown I have the "saving your settings" and "shutting down" windows;
Any recommendation?
Thanks in advance.
My Computer
Hi Emile,
Welcome to Vista Forums. :party:
This is usually related to when you have something running in the background and how long it takes for XP to shut them down when you click Shutdown or Restart. When nothing is running, it can shutdown very quickly.
I believe XP has these same settings as Vista. Add a bit more to the WaitToKillServiceTimeout string value name to allow for more time for XP to shutdown things. The default in Vista is 20000, you might try bumping it up to 25000.
http://www.vistax64.com/tutorials/70567-shutdown.html
Hope this helps,
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
Hello Brink,
Just to clarify when I request a "restart" in XP and the problem happens I receive immediatly the black screen and PC reboots:(
The PC does NOT wait.
My Computer
Emile,
My apologies, it should still apply to Restart since it calls for XP to shutdown first, then restart.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
You're welcome Emile. Glad that it is working ok for you now.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
Chicken and egg: How do you apply this fix to XP from Vista without booting into XP first? I'm thinking that doing a "Load Hive" in Vista's regedit would be the way, but I'm not sure and am not comfortable doing that (though I do use regedit frequently for more normal things).
My Computer
Hi rseiler,
Welcome to Vista x64 Forums. :party:
I would just do it from within XP to be safe. This way you can use the download and not even have to enter the registry. You can always manually create a new restore point in Vista afterwards to replace the deleted ones.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
rseiler,
I suppose you could do a Complete PC Backup to save everything, then make the change to the XP settings. When done, do a Restore Complete PC for Vista.
It's the only thing I can think of that may help your situation.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
Is "Load Hive" really not a valid option? I thought its purpose was to be able to "remotely" edit another system's Registry. Perhaps someone experienced with that particular function of Regedit can confirm.
My Computer
rseiler, I do not know if it is or not. You might post this same question in one of the forums or newsgroups to get more exposer on it. Hopefully someone will know of the solution for you.
Sorry, :(
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
After applying stop xp.reg xp still removes vista restore points. In xp can't see vista drive. The drive letters change in each os so that c: is vista in vista and c: is xp in xp, could that be causing my problem, or maybe the page file location?
My Computer
System One
  • Manufacturer/Model
    HP Pavilion dv9535nr
Hi LennyP,
Having the driver letters show as C: for the OS when you start in each OS is normal. The page file for the OS should be on the same drive or partition that the OS is installed on to help avoid problems.
I know, you probably did, but I have to ask. ;)
Did you do this from within XP and restart XP afterwards?
Do you have more than one XP installed? If so, you will need to apply this to each one installed.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
Yes, in xp and restarted, and no only one xp, but xp and vista on 2 different drives, one on each. I think I will move the page file, vista put it on the other drive when it installed.
My Computer
System One
LennyP,
I'm not sure why XP would still be deleting the Vista restore points if it is no longer able to see Vista.
I would definitely have Vista's page file back on a drive other than the one XP is on.
My Computers
  • Operating System
    Manufacturer/Model
    Custom
    CPU
    Motherboard
    Memory
    Graphics Card(s)
    Sound Card
    Monitor(s) Displays
    Screen Resolution
    2560x1440
    Hard Drives
    PSU
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Mouse
    Internet Speed
    Other Info
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
LennyP,
When viewing the vista drive from vista in Disk mgt the system files are on the D: drive? Moved the paging files to their respective drives, still no restore files.
Thanks lenny
My Computer
System One
