Sound Recorder - Enable or Disable
How to Enable or Disable Sound Recorder in Vista
This will show you how to enable or disable the ability to use Sound Recorder for all user accounts on the computer. Sound Recorder is enabled by default in Vista.
Note   Note
Using Sound Recorder, you can record sound as a digital media file on your computer from a variety of devices, such as a microphone that is plugged in to your sound card.
Tip   Tip
The Sound Recorder EXE file is located at the location below.
C:\Windows\System32\SoundRecorder.exe
EXAMPLE: Sound Recorder
NOTE:
The shortcut for Sound Recorder is in the Start menu at: All Programs, Accessories, Sound Recorder.
EXAMPLE: Sound Recorder Disabled Message
NOTE:
This is the message a user will see when they try to run Sound Recorder if it is disabled.
METHOD ONE
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two below for the Vista Home Basic and Home Premium editions.
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.​
2. In the left pane, click on User Configuration, Administrative Templates, Windows Components, and Sound Recorder. (See screenshot below)​
3. In the right pane, right click on Do not allow Sound Recorder to run and click on Properties. (See screenshot above)​
4. To Enable Sound Recorder
A) Dot Disabled or Not Configured and click on OK. (See screenshot below step 5A)​
B) Go to step 6.​
5. To Disable Sound Recorder
A) Dot Enabled and click on OK.​
6. Close Local Group Policy Editor window. Your done.​
METHOD TWO
Using a REG File Download
NOTE: This method will work for all Vista versions.
1. To Enable Sound Recorder
A) Click on the download button below to download the file below.​
Enable_Sound_Recorder.reg
download
B) Go to step 3.​
2. To Disable Sound Recorder
Disable_Sound_Recorder.reg
download
3. Click on Save, and save the .reg file to the Desktop.​
4. Right click on the downloaded .reg file and click on Merge.​
5. Click on Run, Continue (UAC), Yes, and then OK when prompted.​
6. When done, you can delete the downloaded .reg file if you like.​
  • Disable_Sound_Recorder.reg
  • Enable_Sound_Recorder.reg
Shawn...I recieved a warning that my computer could not verify this download for the enable sound recorder filr. Since it's on this site I feel it's very safe...please re-assure me ? I downloaded it to save, and will run after you respon in kind.Thank you:o
My Computer
Hello Pistachio,
No worries, this is normal when you try to run or open a file downloaded from a unknown source (not from your computer or network). The file is completely safe, and you would just need to do steps 5 and 6 to approve merging the REG file. That's all. :)
My Computers
System One System Two
  • Operating System
    Windows 10 Pro 64-bit
    Manufacturer/Model
    Custom
    CPU
    Intel i7-8700K 5 GHz
    Motherboard
    ASUS ROG Maximus XI Formula Z390
    Memory
    64 GB (4x16GB) G.SKILL TridentZ RGB DDR4 3600 MHz (F4-3600C18D-32GTZR)
    Graphics Card(s)
    ASUS ROG-STRIX-GTX1080TI-O11G-GAMING
    Sound Card
    Integrated Digital Audio (S/PDIF)
    Monitor(s) Displays
    2 x Samsung Odyssey G7 27"
    Screen Resolution
    2560x1440
    Hard Drives
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    8TB WD MyCloudEX2Ultra NAS
    PSU
    Seasonic Prime Titanium 850W
    Case
    Thermaltake Core P3
    Cooling
    Corsair Hydro H115i
    Keyboard
    Logitech wireless K800
    Mouse
    Logitech MX Master 3
    Internet Speed
    1 Gb/s Download and 35 Mb/s Upload
    Other Info
    Logitech Z625 speaker system,
    Logitech BRIO 4K Pro webcam,
    HP Color LaserJet Pro MFP M477fdn,
    APC SMART-UPS RT 1000 XL - SURT1000XLI,
    Galaxy S23 Plus phone
  • Operating System
    Windows 10 Pro
    Manufacturer/Model
    HP Envy Y0F94AV
    CPU
    i7-7500U @ 2.70 GHz
    Memory
    16 GB DDR4-2133
    Graphics card(s)
    NVIDIA GeForce 940MX
    Sound Card
    Conexant ISST Audio
    Monitor(s) Displays
    17.3" UHD IPS touch
    Screen Resolution
    3480 x 2160
    Hard Drives
    512 GB M.2 SSD
