Reliability Monitor
Page 1 of 4 123 ... LastLast
    Reliability Monitor
    Reliability Monitor
    View Reliability and Problem History with Reliability Monitor in Windows 7 and Windows 8
    Published by
    Designer Media Ltd
       Information
    This tutorial will show you how to open and use Reliability Monitor to review reliability and problem history to help resolve issues in Windows 7 and Windows 8.
       Note
    Reliability Monitor is an advanced tool that measures hardware and software problems and other changes to your computer. It collects 24 hours of data before it displays any results and calculates the stability index that ranges from 1 (the least stable) to 10 (the most stable). You can use the index to help evaluate the reliability of your computer by reviewing the reported application failures, Windows 7 failures, Miscellaneous failures, Warnings, and Information. Any change you make to your computer or problem that occurs on your computer affects the stability index.
    EXAMPLE: Reliability Monitor
    NOTE: You can tell your Index score (scales from 1 to 10, 10 is the best score) by looking at how the chart line ends in the upper right corner boxed in red below compared to the scale of 10 to 1 on the left upper corner boxed in red below.
    Here's How:
    1. Click on the Action Center icon in the notification area of the taskbar, click on Open Action Center, and go to step 3 below. (see screenshot below)
    OR
    2. Open the Control Panel (icons view) in Windows 7 or Windows 8, click/tap on the Action Center icon, and go to step 3 below.
    3. Click on the Maintenance drop down arrow to expand it, then click on the View reliability history link under the Check for solutions to problem reports section. (see screenshot below)
    4. In the Reliability Monitor, you can: (see screenshot below)
    • Next to View by, click on Days, Weeks, Month, or Year to view the stability index over a specific period of time that you want.
    • In the upper pane, click on any event on the graph to view its reliability details in the lower pane.
    • Under the lower Reliability details pane, you can click on an available link under the Actions column. For example, View technical details to see more details about the reported problem.
    • At the bottom, click on the View all problem reports link to view only the problems that have occurred on your computer. This view does not include the other computer events that show up in Reliability Monitor, such as events about software installation.
    • At the bottom, click on the Save reliability history link, to save this Reliablilty Monitor report as an .xml file to give to support if needed.
    5. When done, click on OK. (see screenshot above)
  1. Posts : 4,282
    Windows 7 Ultimate Vista Ultimate x64
    Not looking very reliable there Shawn lol.
      My Computer
  2. Posts : 72,116
    Thread Starter
    LOL, nope. IE8 keeps crashing on me now and then destroying my score.
    I guess I should look into that one day.
      My Computer
  3. Posts : 1,003
    Win7 Ultimate x64 on Desktop / Win7 Ultimate x86 on laptop / Win7 x86 Starter on Netbook
    Thanks, it looks great at first......lol. Mine is starting to go up now after taking off some software windows didn't like!
      My Computer
  4. Posts : 72,116
    Thread Starter
    You're welcome Romulinx. Hopefully you will get a perfect 10 soon.
      My Computer
  5. Posts : 34
    7 rtm
    Shawn,
    Great forum! You always seem to have the "best" stuff... exactly what I am interested in!
    I just made the leap to W7 RTM.... foolish me ... on 4 machines!
    Ok, so with your help I found the reliability monitor once again. (I thought it was MIA until I read your How To article). As you might recall, I am anal about showing a 10.0 . So, how can I reset the rating in 7 back to 10? Just delete the RAC the same way as Vista?
    Thanks!
    Charlie
      My Computer
  6. Posts : 72,116
    Thread Starter
       #6
    Hello Charlie, and welcome to Seven Forums.
    You can just clear the history to reset this.
    Problem Reports and Solutions - Clear History
    Hope this helps,
      My Computer
  7. Posts : 34
    7 rtm
       #7
    Thanks Shawn,
    I saw that before. You delete the items in a very similar fashion to Vista. It doesn't reset the history though. In Vista you had us delete the files in sub directories under RAC. After you did that and rebooted, the Relieablity number was back to 10 as if you had just installed the operating system. I tried to delete those file in 7 but they seem to be different. The database file is locked as well. Any thoughts on how to get the reliability number back to "ground zero"... day 1. . . literally?? . . without really screwing up the system...
    Thanks again Yoda!
    Charlie
      My Computer
  8. Posts : 5,807
    Windows 7 Home Premium x64 - Mac OS X 10.6.4 x64
       #8
    Hope this helps,
    thats cheating
      My Computer
  9. Posts : 72,116
    Thread Starter
       #9
    charlieo said:
    Thanks Shawn,
    Thanks again Yoda!
    Charlie
    Charlie,
    Sorry, yes it's the exact same method as in Vista below to do so. I'll make a new tutorial on it tonight for the Windows 7 version of it though. :)
    Reliability Monitor - Reset - Vista Forums
      My Computer
  Related Discussions
Our Sites
Site Links
About Us
© Designer Media Ltd
Find Us
