Hello everyone,
Yesterday, I searched a lot to find a simple PHP paging system form my site. I found many, but they scare the hell out me! There coding was to hard to understand. So I decided to write a simple PHP that creates paging from MySQL Query. So Let's Start!
The linking should be > page.php?page=NUMBER
$pages=$_GET['page']; //Get the current page
//Connect to your MySQL
$mysql_link = mysql_connect("localhost", "namef", "pass");
mysql_select_db("test") or die("Could not select database");
// This the full code which will generate a paging system
$limit=10; // Limit of result per page
$qresult = mysql_query("SELECT * FROM sample_db"); // Let's get the query
$nrResults=mysql_num_rows($qresult); // Count the results
if (($nrResults%$limit)<>0) {
$pmax=floor($nrResults/$limit)+1; // Divide to total result by the number of query you want
// to display per page($limit) and create a Max page
} else {
$pmax=floor($nrResults/$limit);
$qresult = mysql_query("SELECT * FROM sample_d DESC LIMIT ".(($_GET["page"]-1)*$limit).", $limit");
//Need to generate query considering your limit
while($line = mysql_fetch_array( $qresult ))
// Now once we got the query from MySQL, we need to think what we to do it. You can do anything. This is just an example
echo "
Name: ".$line['name']." <br />
Age: ".$line['age']." <br />
Phone Number: ".$line['phone']." <br />
// Here comes the Real part of this Tutorial!!
} echo "<div class='navpage'>"; // Make a simple css
// We need to create a Previous page, so we need $pages to be bigger than 1, otherwise at the first page we would get a 0.
//For the previous to show up we need at least to be at the second page.
if($pages > 1) {
$prevp="<a href='http://mysite.com/page.php?page=".($pages-1)."' title='Previous Page'>Previous Page</a>"; } else {echo "";}
echo $prevp;
// Here We want create a page from the results we got by dividing the total by the the limit. So let say you got
//45 results and you want 5 results per page; these simple lines will create you 8 pages.
$pid=1;
while ($pid<=$pmax) {
$paging= "<a href='http://mysite.com/page.php?page=$pid' title='Page $pid of $pmax'> $pid</a>";
//So here, let say we are at the 3rd page and we want the 3 to be blank so the user can know where is he now.
//This will act as Current Page! We need to replace the url by a text
$newpaging=str_replace("<a href='http://mysite.com/page.php?page=$pages' title='Page $pages of $pmax'> $pages</a>", "<span>$pages</span>", $paging);
echo $newpaging;
$pid++; // create pages until reach the result
//We want to create a next page and a last page, $pages have to be less than $pmax.
if($pages < $pmax) {
$nextp="<a href='http://mysite.com/page.php?page=".($pages+1)."' title='Next Page'>Next Page</a>"; } else {echo "";}
echo $nextp;
echo "<a href='http://mysite.com/page.php?page=$pmax' title='Last Page'>Last Page</a>";
echo "</div>";
When linking to the first page it must have this form page.php?page=1 . The page=1 is important otherwise it will result in an error.
