PHPDoc, code completion and iterations with PHP
Coding is very important part within our work as developers. Maybe it isn’t the outcome of our work. Our clients don’t really mind if our code is smart or not. They only want the product or service we give  them. Code is our problem. However smart code and agile programming skills are really useful to accomplish with our objectives. One useful tool is PHPDoc.
PHP is not Java. Java is a strongly typed programming language. Because of that modern IDE helps us a lot when we are coding Java. In PHP we don’t need to declare the type of a variable when we declare it. Even we don’t need t declare the variables. This behaviour can be good or bad. For IDEs it’s very bad. I’m not going to start the first flame-war between Java and PHP now. The fact is that we want to code as fast as we can making less mistakes and writing the less code as we can to reach our goals. PHP has some limitations but we also have some tools as PHPDoc to help us.
Let’s start with an example
class MyClass
	function hello($name)
		return "Hello " . $name . "\n";
When we want to use this class and we type:
$obj = new MyClass;
echo $obj->       <------ code completion appear in our IDE suggesting hello function
But now we put a simple singleton function in MyClass
class MyClass
	private static $_instance = null;
	function singleton()
		if (is_null(self::$_instance)) {
			self::$_instance = new self;
		return self::$_instance;
And we use our singleton:
echo MyClass::singleton()->     <---- ups nothing happens
That’s because our IDE doesn’t know the return type of our singleton function. Because of that we are going to help to our IDE with a bit of PHPDoc magic.
	 * @return MyClass
And now our IDE will help us.
And now something a bit different. We have other class:
class MyClass2
	static function getAll()
		return array(new MyClass, new MyClass, new MyClass);
According to PHPDoc manual we can hint getAll function with @return array[int]MyClass but code completion doesn’t work, at least on my tests (please tell me I’m wrong because it’s the best solution).
So I need to use a small trick to get the autocompletion:
foreach (MyClass2::getAll() as $row) {
	/* @var $row MyClass */
	echo $row->     <------------------- code completion appear
I’ve tried with @return array[int]MyClass and also using SPL Iterators but that’s the only way I know to ensure autocompletion.
Other possible solution is use a dummy cast function in MyClass. It’s a bit ugly solution but also works always:
	 * @param MyClass $cls
	 * @return MyClass
	static function cast($cls)
		return $cls;
Now We can use:
	echo MyClass::cast($row)->hello("Gonzalo"); // code completion works
8 thoughts on “PHPDoc, code completion and iterations with PHP
  1. A rather late reply, but you should be able to skip the MyClass::cast() thing, by doing something like this:
    /** @var $row MyClass */
    echo $row->hello(‘world’);
    Now, instead of having to call MyClass::cast() N times, PHP just needs to throw away a comment line once.
  2. Note that you can also can set the return parameter as an array of specific classes, example:
    class MyClass2
    * @return MyClass[]
    By adding the “[]” after the return line, you specify that the result is an array of MyClass instances.
    Your IDE will automatically use code completion in a foreach loop now for the objects.
    echo $row-> <————- Code completion will apear without using the @var line
Leave a comment
This site uses Akismet to reduce spam. Learn how your comment data is processed.
