NotifyOSDconfig – Simple GUI for Customizing NotifyOSD
Sponsored Link
NotifyOSD Configuration is a simple GUI for you to Customizing your NotifyOSD.
First you need to install patched NotifyoSD using the following commands from your terminal
sudo add-apt-repository ppa:leolik/leolik
sudo add-apt-repository ppa:amandeepgrewal/notifyosdconfig
Update source list
sudo apt-get update
Now install notifyosdconfig using the following command from your terminal
sudo apt-get install notifyosdconfig
Using notifyosdconfig
Open notifyosdconfig from Applications -> Accessories -> NotifyOSD Configuration
Once it opens you should see similar to the following screen here you can configure notification bubble settings
notification text settings
Sample notification
It’s broken now! What happened?
Should be built in with NotifyOSD in my opinion.
