How to Use Brushes and Filters in Adobe Camera Raw (Make Selective Adjustments)
Adobe Camera Raw has a few tools that can help you make selective changes to parts of your raw image. Any adjustments you make in Adobe Camera Raw are non-destructive, meaning they don’t touch your original image and you can revert to your original at any time. In this tutorial, you'll learn how to use Camera Raw to create local adjustments.
How to Make Changes to One Part of a Photo in Camera Raw
Making local adjustments to your image is an important part of the editing process. While global adjustments focus on the picture as a whole, local ones mean you can target those parts that need specific attention while leaving other areas untouched. There are three main tools: the Adjustment Brush, Graduated Filter, and the Radial Filter.
Adjustment Brush
When you click on the adjustment brush in the far-right menu, you’ll see the Selective Edits menu appear, which looks very much like the Basic Edits one.
The idea of this is to paint over the areas you want to make specific changes to. First, click the dropdown menu next to the brush size and you can choose your brush options.
- Size: the pixel diameter of your brush
- Feather: how hard or soft the brush is
- Flow: how the adjustment is applied (the rate of application)
- Density: the transparency (or opacity) of the stroke
- Overlay: having this ticked will put a pin in where you make an adjustment so you can see and flip between them easily.
You’ll also see Auto Mask as a tick option. If this is selected then your strokes will be confined to areas of similar colours. This is useful if you’re painting over objects or anything with definite lines or borders as it stops applying the mask as you approach the edges.
You can choose whether or not you can see a mask as you paint over your image by ticking Mask Options, where you’ll also see you can pick a colour and choose whether the mask colour indicates the area you want to change, or if you want it to exclude that area.
Whether you want a mask visible on not probably depends on how you prefer your workflow: selecting a tool and then applying the adjustment to the photo, or masking over an area of the photo and then adjusting the edit options. Adobe recommends the former, but I actually find the latter useful most of the time. You might do a mix of both.
Apply Adjustment Brush
When you’ve selected and modified your brush, toggle the mask on to make it easier to see where you’re brushing, and brush over a part of the image to adjust. If you make a mistake you can select the eraser icon next to the brush and use that to make everything neater. I’ll brush over the wall to demonstrate.
Once you’ve finished brushing over your area, it’s easier if you then untoggle the mask by unticking Mask Options. Heading down to the Selective Edits, any changes you make to the sliders will now take effect on the area you’ve brushed over. If I pull the shadows up, you can see it on the wall where the mask was:
You can adjust any of the sliders and it will only make changes to that specific section of the photograph.
When you’re happy to move on, just click Create a New Adjustment to start working on a new area.
You can edit your entire image this way, though I always prefer to make global adjustments (in Basic Edits) first and then do some fine tuning with local adjustments.
Graduated Filter
The Graduated Filter is fairly descriptive of what it does – allowing you to apply adjustments of the same type across a particular part of your photo, choosing the size of the area it applies to.
Like the Adjustment Brush, you can choose to see a mask, but unlike the Adjustment Brush, rather than painting that on, you drag an area out between two parallel lines and it’s up to you how wide or narrow that strip is, or which direction it goes in.
This tool is particularly useful for things like skies. Using the mask above, if I lower the highlights and add a blue hue to the filter you can see the changes apply most heavily at the top of the filter guide, at the red dotted line, and then become weaker as you move down to the bottom green dotted line:
Once you’ve adjusted, you can still move the guide lines to shift, expand or shrink the area of effect, and, more usefully, you can then select an adjustment brush or eraser to refine the area. If you have large areas of adjustment this means you can apply the filter across that part of the photograph and then simply refine that by brushing the effect in or out.
Radial Filter
The Radial Filter works in exactly the same way as the Graduated Filter but it’s round.
You can apply your adjustments to the ellipses or to the area outside of it, just check the Invert box. The radial filter would be useful for things like applying blur if you’re aiming for a faux shallow depth of field, or for creating your own vignette.
Try a Video Tutorial on the Adjustment Brush
If you have an older version of Adobe Camera Raw or you like to walk through a technique with narration then you might find this video useful.
More Video Resources From Envato
Read the Envato Video Marketing Guide
Boost your video marketing skills with our comprehensive guide: You'll learn video marketing from start to finish, so that whether you're a novice or a pro, you'll learn some useful skills that will improve your next video.
Download Free Video, Free Music, and Free Motion Graphics Templates From Mixkit
Check out Mixkit for free stock videos, free stock music, and free templates for Adobe Premiere Pro. Yes, free!
Make a Motion Graphics Video Online With PlaceIt
You don't need professional software to create visually-appealing videos, you can make them right in your browser: PlaceIt is an online service with a video maker uses professionally-designed motion graphics templates.
Envato Elements: Unlimited Downloads
Envato Elements offers millions of stock items: photos, music, video clips, fonts, graphics templates of all sorts, video project templates for After Effects, Premiere Pro, Final Cut Pro and Motion, and creative courses from Envato Tuts+, all with a single subscription.
More Adobe Camera Raw Tutorials
- How to Use Texture, Clarity, Dehaze, Vibrance and Saturation in Adobe Camera RawMarie Gardiner30 Dec 2020
- How to Use Presets in Adobe Camera Raw (for Free)Marie Gardiner25 Jan 2021
- How to Change White Balance in Photos With Adobe Camera Raw (Post-Process Basics)Marie Gardiner30 Sep 2020
- How to Use Look-Up Tables (LUTs) for Instant Photo Effects in Adobe Camera RawMarie Gardiner25 Oct 2020
