RSS/Atom feed Twitter
Tutorial: Create a sparkling Disco Ball
Written by , translated by devvv · Created on Oct 22, 2010, last updated over 13 years ago CC BY-NC License
Motivation
For one it might be a relic from the past, for others it is a symbol for pure party and dancing: a disco ball. It is a sparkling and glossy orb that has a glassy mosaic-like surface which is then rotating in colored disco light to spread the lights into different directions. I needed such a disco ball for a party flyer that I did for myself.
Tutorial details
  1. 1
    Create a new file using these dimensions:
    Width: 800px
    Height: 400px
    Of course you can use any size but pay attention that it is an aspect ratio of 2:1 (we will need this later)
    For this step: Fill the background with different colors. You can also use a variation of only one color. I used a soft brush with the “Color from Gradient” enabled in the preferences. I also used some Brush dynamics to fill the background.
  2. 2
    The mosaic
    To create the mirrored glossy surface go to Filter / Distort / Mosaic and use the values from the picture.
    Make sure that you disable the option “Allow tile splitting” on the right side of the filter dialogue. The option “FG/BG lightning” is used to fill the spaces between the mosaic with color. In my case this would be black.
  3. 3
    Scale the image
    To avoid distortions when we later use the Map filter it is necessary to scale it on the width. To do this use Image / Scale: Enter 400px width. Disable the chain-symbol. You should then have a square image.
  4. 4
    Mapping
    Now we get to the important step of the tutorial.
    Filter / Map / Map object. Use map to a sphere in the dropdown. Use the following values from the images. You don’t need to make changes in the “orientation” tab.
  5. 5
    Unsharp Mask
    In step 4 we already got a nice output. We need to do some more fine tuning however. For more sharpness use Filter / Enhance / Unsharp Mask with these values:
  6. 6
    Add sparkle
    Now we need some sparkle. For that create a new brush using the brushes editor (bottom right). Change the foreground color to white. Click on some places in the image. (Further details on how to create sparkle you will find in the according tutorial – http://www.gimpusers.com/tutorials/sparkle-on-objects)
    Important: Reset the options of the brush dynamics before adding the sparkle. Use white as foreground color.
  7. 7
    There are of course many color variations possible. The whole disco ball comes to life when using a nice background. Also some rotation of the sphere is a good ide to get more dynamic into the scene.
    I hope you enjoyed the small tutorial! I’ve got the inspiration to this tutorial from http://mosquitosplace.com/2008/10/disco-ball-tutorial/ which was a motivation for a kiwi partyflyer.
Comments
Subscription management
Todo Gimp
almost 13 years ago
Excellent tutorial!
I've create a spanish version of your tut.
http://www.todogimp.com/?q=general/tutorial-bola-de-discoteca
Thanks
Todo Gimp
http://todogimp.com
TheJoe
over 13 years ago
Wow!! this is extremely gay!!
wonderful!
Tristen member for almost 14 years Tristen 4 comments
over 13 years ago
This is really cool.
Andrei
over 13 years ago
Lookin' for some hot stuff ... and you posted it. I would appreciate if you could write another tutorial on how to create images like the wallpaper you used in this one.
Thanks a lot.
PatrickEB
over 13 years ago
Maaaaaaaaaaaaaaaaate!
This will make me hot dude...well, with the sister-in-law! :)) and some of my gay friends (male).
The in-law is a real disco queen and she'll love the next birthday card I make for her.
Fantastic work there - Love it!
