Context Menu Items Missing - Fix when more than 15 Files are Selected
    Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
    Published by
    Designer Media Ltd
       Information
    This will show how to restore the missing Open, Print, and Edit context menu (right click) items for when you have more than 15 files selected in Vista, Windows 7, and Windows 8.
    This will also set how many items that can be selected to Open, Edit, or Print at once.
    These context menu items were removed by design like this in Windows to avoid accidentally performing these actions on a large number of files.
    EXAMPLE: Context Menu with more than 15 Files Selected
    NOTE: The left screenshot is the default with more than 15 TXT files selected, and the right screenshot is when you have them restored even with more than 15 TXT files selected.
    Context Menu Items Missing - Fix when more than 15 Files are Selected-default.jpg
    Context Menu Items Missing - Fix when more than 15 Files are Selected-changed.jpg
    OPTION ONE
    Using a REG File Download
    1. To Show Context Menu Items when more than 15 Files are Selected
    A) Click/tap on the download button below to download the file below.
    NOTE: This sets the MultipleInvokePromptMinimum DWORD value to 10,000 items that can be selected to Open, Edit, or Print at once. If you need a different amount, then you can use OPTION TWO below to manually set what you need.
    Show_Context_Menu_Items_Unlimited_Files_Selected.reg
    B) Go to step 3.
    2. To Not Show Context Menu Items when more than 15 Files are Selected
    Default_Show_Context_Menu_Items_up_to_15_Files_Selected.reg
    3. Save the .reg file to your Desktop.
    4. Double click/tap on the downloaded .reg file to merge it.
    5. Click/tap on Run, Yes (UAC Windows 7/8) or Continue (UAC Vista), Yes, and OK when prompted.
    6. If open, close and reopen Windows Explorer to apply the changes.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Manually in Registry Editor
    1. Press the Windows + R keys to open the Run dialog, type regedit, and press Enter.
    2. If prompted by UAC, then click/tap on Yes (Windows 7) or Continue (Vista).
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    Context Menu Items Missing - Fix when more than 15 Files are Selected-reg1.jpg
    4. To Show Context Menu Items when more than 15 Files are Selected
    A) In the right pane of Explorer, right click on a empty space, then click/tap on New and DWORD (32-bit) Value. (see screenshot above)
    B) Type MultipleInvokePromptMinimum, and press enter. (see screenshot below)
    Context Menu Items Missing - Fix when more than 15 Files are Selected-reg2.jpg
    C) Double click/tap on MultipleInvokePromptMinimum, select (dot) Decimal, type in a number for how many items you would like to be able to select at once to either Open, Edit, or Print at once, then click/tap on OK. (see screenshot below)
       Note
    Typing in 16 or above will allow Open, Edit, and Print to always be available in the contect menu no matter how many items you select.
    However, the number you enter here is how many items you will be able to select at once to actually be able to Open, Edit, or Print them all at once though.
    Context Menu Items Missing - Fix when more than 15 Files are Selected-reg3.jpg
    D) Go to step 6.
    5. To Not Show Context Menu Items when more than 15 Files are Selected
    A) In the right pane of Explorer, right click on MultipleInvokePromptMinimum, and click on Delete. (see screenshot below)
    Context Menu Items Missing - Fix when more than 15 Files are Selected-reg-4.jpg
    B) Click/tap on Yes. (see screenshot below)
    Context Menu Items Missing - Fix when more than 15 Files are Selected-reg5.jpg
    7. Close regedit.
    8. If open, close and reopen Windows Explorer to apply the changes.
  1. Posts : 544
    Windows 10 Home, 64 bit
    Perfect for what I was looking for this morning! Thanks, Shawn.
      My Computer
  2. Posts : 72,083
    Thread Starter
    You're most welcome Arthur. :)
      My Computer
  3. Posts : 1
    Windows 7 Enterprise
    It is what it is the number you input
    What I have tested is that you set MultipleInvokePromptMinimum = 16, you can get the context menu displayed, but the files being opened is 16. In other words, it is what it is the number you input, which defines how many files you can open. If you enter 500, it is enough virtually, and this is the number I finally entered in my system. I am using Windows 7 Enterprise.
    Thanks for Brink, excellent post.
      My Computer
  4. Posts : 72,083
    Thread Starter
    Hello Sabaki, and welcome to Seven Forums.
    Yes you are correct. I updated the tutorial with this below to help make this more known. Thank you for helping with this to make it more clear. :)
      My Computer
  5. Posts : 1
    windows 7 pro 64
    Option 1
    OPTION 1 Works perfectly!!
      My Computer
  Related Discussions
Our Sites
Site Links
About Us
© Designer Media Ltd
Find Us
