Remote Desktop Connection Automatic Log On - Allow or Prevent
    Allow or Prevent Remote Desktop Connection Clients to Automatically Log On to Host Computer
    Published by
    Designer Media Ltd
       Information
    If you allow Remote Desktop Connections to your (host) computer, then this will show you how to allow or prevent all Remote Desktop Connection clients from being able to automatically log on (Remember my credentials) to your (host) Vista, Windows 7, or Windows 8 computer.
    You must be logged in as an administrator to be able to do this tutorial.
       Note
    • If this is set to be allowed on your (host) computer, then a RDC client will be able to be set to automatically log on (Remember my credentials) to your (host) computer.
    • If this is set to be prevented on your (host) computer, then a RDC client will not be able to be set to automatically log on (Remember my credentials) to your (host) computer, and will always be prompted to enter their log on credentials before being allowed to log on to your (host) computer.
       Warning
    While all editions of Vista, Windows 7, and Windows 8 can be a remote desktop client...
    • Only the Vista Business, Ultimate, and Enterprise editions can host a remote desktop connection.
    • Only the Windows 7 Professional, Ultimate, and Enterprise editions can host a remote desktop connection.
    • Only the Windows 8 Pro and Enterprise editions can host a remote desktop connection.
    EXAMPLE: Remote Desktop Connection Clients Prevented and Must Always Enter Password
    OPTION ONE
    Using a REG File Download
    1. To Allow Automatic Log On from RDC Clients
    A) Click on the Download button below to download the file below.
    Allow_Automatic_Logon_from_RDC_Clients..reg
    B) Go to step 3.
    2. To Prevent Automatic Log On from RDC Clients
    Prevent_Automatic_Logon_from_RDC_Clients..reg
    3. Save the .reg file to your desktop.
    4. Right click on the downloaded .reg file and click on Merge.
    6. Click on Run, Continue (UAC-Vista) or Yes (UAC-Windows 7), Yes, and OK when prompted.
    7.When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    1. Open the Local Group Policy Editor.
    2. In the left pane, click on the arrow to expand Computer Configuration, Administrative Templates, Windows Components, Remote Desktop Services, Remote Desktop Session Host, and on Security. (see screenshot below)
    3. In the right pane of Security, right click on Always prompt for password upon connection and click on Edit. (see screenshot above)
    4. To Allow Automatic Log On from RDC Clients
    A) Select (dot) Not Configured or Disabled. (see screenshot below step 6)
    NOTE: Not Configured is the default setting.
    B) Go to step 6.
    5. To Prevent Automatic Log On from RDC Clients
    A) Select (dot) Enabled. (see screenshot below step 6)
    6. Click on OK. (See screenshot below)
    7. Close the Local Group Policy Editor. (see screenshot below step 2)
  1. Posts : 21
    Windows 7 Ultimate SP1 x64
    i tried it but nothing happen
      My Computer
  2. Posts : 72,063
    Thread Starter
    Hello Sianios,
    This tutorial only allows or prevents the ability of users to automatically log on (Remember my credentials) to your computer. For them to actually automatically log on to your computer, they would need to do the tutorial below instead if allowed by you in this one.
    Remote Desktop Connection Automatic Log On - Turn On or Off
    Hope this helps,
      My Computer
  Related Discussions
Our Sites
Site Links
About Us
© Designer Media Ltd
Find Us
