How to Create an Ice Planet
You can find a lot of tutorials on how to make an ice planet in Photoshop. But I would like to invite you to try this unique simple tutorial on how to achieve the desired effect in a few steps.
Final Image Preview
How to Create Ice Planet
Create a new document with 1000×1000 pixels. Press D to set up foreground and background color as black (#000000) and white (#ffffff). Fill layer with black color (#000000).
How to Create Ice Planet 1
Create a new layer, name it “Planet” and apply Filter > Render > Clouds.
How to Create Ice Planet 2
Apply Filter > Artistic > Plastic Warp (Highlight Strength:20, Detail:15, Smoothness: 2).
How to Create Ice Planet 3
How to Create Ice Planet 4
Apply Filter > Distort > Polar Coordinates.
How to Create Ice Planet 5
How to Create Ice Planet 6
Apply Filter > Distort > Polar Coordinates again but changing option to Rectangular to Polar.
How to Create Ice Planet 7
How to Create Ice Planet 8
Use Filter > Distort > Sphesize.
How to Create Ice Planet 9
How to Create Ice Planet 10
Apply Filter > Distort > Sphesize one more time updating Amount to 50%.
How to Create Ice Planet 11
How to Create Ice Planet 12
Apply Filter > Distort > Pinch.
How to Create Ice Planet 13
How to Create Ice Planet 14
With Elliptical Marquee Tool select planet. After that invert selection with Select > Inverse.
How to Create Ice Planet 15
Press Delete to clear selected area and remove selection with Ctrl+D.
How to Create Ice Planet 16
Go to Edit > Transform > Scale to reduce planet size a bit (keep pressing SHIFT to maintain proportions).
How to Create Ice Planet 17
Duplicate “Planet” layer with Ctrl+J and apply Filter > Brush Strokes > Dark Strokes (Balance: 5, Black Intensity: 2, White Intensity: 2).
How to Create Ice Planet 18
How to Create Ice Planet 19
Update layer mode to Soft Light on current layer.
How to Create Ice Planet 20
Duplicate again “Planet” layer with Ctrl+J and move it on top of all layers. Apply Filter > Sketch > Bas Relief (Detail: 13, Smoothness: 2, Light: Bottom Right).
How to Create Ice Planet 21
How to Create Ice Planet 22
How to Create Ice Planet 23
Select Eraser Tool (Opacity: 30%, Size: 40px) and with a soft round brush remove the relief of ice surfaces.
How to Create Ice Planet 24
Duplicate again “Planet” layer with Ctrl+J and move it on top of all layers. Apply Filter > Sketch > Note Paper (Image Balance: 25, Graininess: 10, Relief: 11).
How to Create Ice Planet 25
How to Create Ice Planet 26
Update layer mode to Overlay on current layer.
How to Create Ice Planet 27
Select Eraser Tool again (Opacity: 30%, Size: 40px) and with a soft round brush remove too monotonous plots.
How to Create Ice Planet 28
Duplicate again “Planet” layer with Ctrl+J and move it on top of all layers. Apply Filter > Sketch > Plaster (Image Balance: 20, Smoothness: 2).
How to Create Ice Planet 29
How to Create Ice Planet 30
Update layer mode to Darker Color on current layer.
How to Create Ice Planet 31
Select Eraser Tool again (Opacity: 30%, Size: 100px) and with a soft round brush clean almost all layer content leaving only some areas to soften edges.
How to Create Ice Planet 32
Duplicate again “Planet” layer with Ctrl+J and move it on top of all layers. Update layer mode to Hard Light on current layer.
How to Create Ice Planet 33
Create a new layer on top of all other layers. Update layer mode to Screen, select Brush Tool (Opacity: 10%, Size: 90px) and lighten up darker water areas with white color.
How to Create Ice Planet 34
Step 10
Create a new layer on top of all other layers. Update layer mode to Color. Set foreground color to #47639a, select Brush Tool (Opacity: 10%, Size: 400px) and start applying to ice areas of the planet. If necessary increase or decrease a little brush opacity.
How to Create Ice Planet 35
Step 11
We need to add stars around the planet. With Brush Tool selected and a soft round brush (Size: 5px to start) press F5 to access brush presets.
How to Create Ice Planet 36
How to Create Ice Planet 37
How to Create Ice Planet 38
Set foreground color to white, create a new layer on top and draw the stars. Keep updating brush size.
How to Create Ice Planet 39
How to Create Ice Planet 40
Step 12
Create a new layer on top. Press D button to set up foreground and background colors as black and white and apply Filter > Render > Clouds.
How to Create Ice Planet 41
Update layer mode to Linear Dodge.
How to Create Ice Planet 42
Select Eraser Tool (Opacity: 30%) and clean layer so that the result should be similar to mine.
How to Create Ice Planet 43
Step 13
To finish the tutorial, create a new layer of top and update layer mode to Soft Color. Select Brush Tool with soft round brush (Opacity: 15-20%), choose color #263c35 and start decorating nebula. Keep updating brush color like I did and you will have a great result.
Final Image
How to Create a Ice Planet
