Customized Character (Side view Head)
This time i’ll show you on how to make a side view head..
The image below is one of my original works..
First Step Face and Hair:
of course we must create a new document for us to start
the dimension of my work this time is 240x400
First of all use the pen tool and make a nose then mouth like this:
Then form the head like this:
The stroke brush and size (You have to select the head) :
doing the hair part is easy just do some lines on whatever hairstyle you want
Next up putting up the eyebrows well just draw a curve line and position it by the forehead like this :
The line should be at least “30 pt Flat” and then the stroke weight is “0.0028 in”
the same to do with the upper eyelid just resize it,and then for they eye you just use an oval brush and brush through at the near tip of the eyelid just like this :
I changed the color of the hair.. use the “Live Paint Bucket” to color it up… for you access “Skin Tones” look at the image :
and as for the lips just draw a heart shape and color the half with lighter color and the other side with a darker color like this:
Completion of the eye :
first make the lower eyelid by creating a line and then just use the “Blob Brush Tool” and color it white just like this:
Adding Extra Details (Make-up and Shadows) :
using the “Blob Bush Tool” or the “Brush Tool” just put some shadows by the edge of any part where you want to put the shadow details and then use “Gaussian Blur” just like these images :
If you’re having a hard time on the layers just select the item and then “right click” and go to Arrange >> Send to Back …. (just to organize the selections).
and for the blush on .. using the “Blob Brush Tool” and a light pink or red or whatever color you want to put and then follow the images :
Use “Gaussian Blur"
The neck shadow just use the dark color of the one and then lower the "Opacity” at the “Transparency” tab :
And then we are done on our head…
ADDITIONAL:
Doing the same thing like the girl’s head to make the head of the male
and for the body just think of a concept about it cause i thought of this :
That’s all there is for all i know for today… Thanks for reading/viewing
For more Graphic Designs just visit http://www.webnovation.com.au
