tutorialbunch.com
tutorialbunch about tutorialbunch contact tutorialbunch
Categories
line
menu symbol
Photoshop
dark line
dark line
menu symbol
Illustrator
dark line
dark line
menu symbol
Flash
dark line
dark line
menu symbol
Free Stock Images
dark line
  previous button index button next button
Water Drop Effect
After rain, some water drops can be seen on the flowers and leaf. You would also see that, now you can learn how to create water drop on the leaf and flower by using Photoshop. I have selected a banana leaf; you can apply this effect on any object.
Insert a banana picture on the new document, this picture has been taken for the learning purpose.
water drop
Draw a water drop shape, select Pen tool (P key) and draw a drop shape by some anchor point. If the shape is not similar to drop, use Direct Selection tool (A key) and change the anchor point position.
water drop
Add some style to this shape, go to Layer menu > layer style > and choose drop shadow. Choose color black and reduce opacity, distance, speed, size.
water drop
You have to make shadow inside the drop, go to Layer menu > Layer Style > and choose Inner shadow. Choose black color and blend mode, reduce opacity, angle and other settings.
water drop
Now apply glow inside, go to Layer menu > Layer Style > Inner Glow. Change opacity, blend mode, color and source.
water drop
Now you have done, the water drop picture will surely come out like this.
water drop
Make duplicate drops and adjust on different place and size, the water drop picture is competed.
water drop
Santosh Kumar Web & Graphic designer
Santosh Kumar
This is santosh kumar living in New Delhi (India) and love to work as a Web & Graphic Designing. I like to create sketch, background, illustration and vector graphics. Tutorialbunch.com is a very good place where I express my creativity.
Donate Please
Home | Photoshop | Illustrator | Flash | Free Stock Images | Contact Us | Sitemap
Copyright © 2008-2023 Tutorialbunch.com. All rights reserved
Designed by Utkarsh kashyap
