Posted on March 20th, 2012
2977 views Usually brochure is made from paper. But this time we'd like to introduce you how to present an online brochure. Of course it's not paper-related anymore.
Step 1 Install and Run IncrediFlash XTreme from here Step 2 Choose Blank Project under Startup window and set the dimension to 800 x 1000 pixels Step 3 By default a scene named Scene 1 has already been created by the time IncrediFlash XTreme open the new ready project file. Select Scene 1, then under Background property window, choose Image(Fit) as the background. Underneath Background type, click the Browse button to choose the background file. Choose background.jpg file as the background. Step 4 Insert board01.png, board02.png,board03.png into Scene 1 as shown below Step 5 Apply Fly-From Left effect, Fly-From Top, and Fly-From Right for board01.png, board02.png, and board03.png respectively. Step 6 Insert the following single text object for board01.png: Step 7 Insert the following images respectively for board01.png, board02.png and board03.png: text_china.png, text_greek.png, and text_us.png as shown below: Step 8 Apply the following effects for china, greek and us tours text objects respectively: Step 9 For text_china.png, text_greek.png, and text_us.png apply the following effects respectively: Step 10 Insert 2 rectangle objects for each board as shown below: Under Timeline window, make sure to put the double rectangles above on the top of the names of the tours. Step 11 Apply Fade effect for 6 rectangle objects above with duration of 1 second as shown below: Step 12 Insert "Kilele Travel" text object as shown below: Step 13 Insert surfing.png and penguin.png into the scene as shown below: Step 14 Apply Pan/Zoom/Rotate effect for both picture objects above as shown below:
Step 15 Insert the following images in a series: Step 16 Apply Pan/Zoom/Rotate effect to roll_photo.png. Step 17 Apply Spinner effect to komodo02.png, komodo01.png, gbr02.png, gbr01.png, pacific02.png, pacific01.png as shown below respectively: Step 18 Congratulation! your brochure is done. Here is the result:
Click here to play the flash file
