RSS/Atom feed Twitter
Tutorial: Create cool rifts with translucent lights!
Written by · Created on Nov 21, 2010, last updated over 12 years ago CC BY-NC License
Motivation
I'm a big fan of Trion Worlds great new MMORPG named "Rift". So I just took the time to create a logo similar to the "RIFT - Planes of Telara"-logo that has some cracks and rifts and also shining light through these rifts. Enjoy!
Tutorial details
  1. 1 Pieces of Eight.ttf
    Create a new image – any size is possible – I took 1024×768 px. Set the background to black and then type any text you want into the middle of the canvas using #3f3f3f as text color and 250px for size.
    You can use my font if you want – It’s some kind of gothic/fantasy style (downloaded it from dafont.com). The name of the font is “Pieces of Eight”. I attached it to this step for direct download.
  2. 2
    Next I want to give the text more special look – you can skip step 2 (this current one) and step 3 if you’re fine with the standard characters of the font otherwise do the following:
    - turn the visibility off for the text layer you just created
    - right click the text layer and choose Alpha to Selection
    - with this active selection go to Select / Selection to Path.
    - Select / None
    Now switch to the paths tab and double click the created selection to activate it.
    If you’re familiar with the paths tool move the points to change the shape of the text. I did it like shown in the image. This can take some time – just give the text your own style.
  3. 3
    Now hit Enter to create a selection of the path that you just worked on. Switch back to the layers tab and create a new layer. Fill the selection with #3f3f3f and hit CTRL+SHIFT+A to deactivate the selection.
  4. 4
    Now we’re going to give our plain gray text a more interesting look. We’re going to make use of the Lighting effects filter, therefore we need a channel to get nice highlights for the text afterwards.
    - right click the layer in the layers dialogue where your visible text is shown and choose Alpha to Selection.
    - Switch to the channels tab
    - Create a new channel by clicking the little create button and choose Initialize from selection. Name it i.e. “highlights”
  5. 5
    The text selection was turned white, everything else in the channel is black currently.
    Now turn off the selection by pressing CTRL+SHIFT+A.
    Click the just created channel to select it. Now we need to apply a gaussian blur to it.
    - Filter / Blur / Gaussian Blur: 6px.
    This will add gray color tones to the channel which is curretly only black and white. The gray tones come from the blurring of the hard white and black color.
  6. 6
    Turn the visibility of the channel off by clicking the eye icon – then switch back to the layers tab and click the text layer to select it.
    Now go to Filter / Lights and Shadow / Lighting Effects.
    In the popup dialogue switch to the Bump Map tab and choose the “highlights” channel we just created. Set the height to 0.02.
    DON’T click OK yet.
  7. 7 lighting_presets_rift_lights
    Switch to the “Light” tab and open my attached lights file. (Right click and save as – the file has no file ending – thats ok)
    I’m using 3 different lights to create interesting highlights and outlines. The first is a spot light giving the ceter of the text a little more focus. the 2nd and 3rd light is adirectional light that comes directly from top and from bottom to give the shape nice highlight at top and on the bottom outlines.
    Apply the lights.
  8. 8
    Now we’re going to add a soft stoney texture to the text.
    - right click the text layer in the layers dialogue and choose Alpha to selection
    - Then go to Select / shrink: 4 px.
    - Filter / Render / Clouds / Plasma (details from the image)
  9. 9
    Next deselect the selection and apply the Lighting Effects filter again. As bump map choose the new plasma layer.
    Now we’ve got a more structured surface. Go to Color / Desaturate.
  10. 10
    Set the opacity of the text layer (the layer below the “structure” layer) to 40%. Then set the layers mode of the structure layer to soft light.
  11. 11
    Now we’re getting to the rifts and the shining through light. Thats what you probably waitet for ;)
    Use the paths tool and create a shape as shown in the image. You need to make 2 points with the paths tool – after placing the second one drag the paths line to the left by taking it in the middle of the two points and move the line to the left which will create a nice curve. After that hold SHIFT while clicking the first point (this action deselects the point). Then hold CTRL on your keyboard, click the other point to connect the second one with the first one. Now a second line (another curve) will appear. Drag the lines as shown in the image to get that kind of shape.
  12. 12
    Create a selection from the path and fill it with plain white. Then duplicate the “rift” 3 times and place it to the other characters of the text.
    Then create another shape using the paths tool in the same way as the described in step #11 for the special “R”. It should finally look like this:
  13. 13
    for easier use now merge the rifts onto a single layer. You can do this by right clicking the top rift-layer in the layers dialoge and use merge down for all the of the rift layers.
    Duplicate the merged single rifts layer and choose Filter / Blur / Gaussian: 9px.
    Then click the “transparency lock”-icon (found righht besides the opacity rule of the layers dialoge).
    Choose #fff588 as Foreground-Color and press CTRL+, (or EDIT / Fill FG-Color). Then set the layer mode to dodge.
  14. 14
    Duplicate the blurred layer 2 times. For the most top layer unset the *Lock Alpha Channel" option and apply a gaussian blur with 35px. The layers mode of this layer please set to Grain merge.
  15. 15
    Now lets get some rays into our image!
    Create a new layer – on the new one go to
    Filter / Light & Shadow / Supernova
  16. 16
    Now desaturate via Colors / Desaturate.
    Move the rays to a point where wou imagine the rays to come out of the rift. I put it a little left as shown in the image. Now use the Free select tool to cut out a rough part for the light of the “R”-characters.
  17. 17
    Copy and paste that part to a new layer. and disable the visibility of the original rays layer. We want to have smoother rays though – make a free selection around the rays, then feather the selection (SELECT / FEATHER: 100px) and invert the selection.
  18. 18
    Now add a layer mask to the layer and fill the selected parts on the mask with black. Then use a big soft brush to paint with black on the mask. Click the parts you want to remove. Make sure you use an opacity of around 30% to have more control on what removing from the details of the rays.
  19. 19
    Now go to Color / Colorize:
  20. 20
    Now copy the layer with the lightrays of the rift 3 times. Move them to the other rifts in the text and flip them accordingly. Also use the Scale tool to make the width smaller for the “I” and the “F” while you want to make it larger for the “T”.
  21. 21
    Now cut another nice part out of the original rays for the second lower rift on the “R”. Again use a layer mask and try what kind of rays look good for you.
  22. 22
    Now for the final step right click a layer in the layers dialogue and select new from visible. The newly created layer needs the layer mode set to “Dodge” – that enhances the glowing effect of the light in a extremley nice way!
    Hope you enjoyed the tutorial – took me alot of time to reproduce ;)
Comments
Subscription management
User rating
This topic (Create cool rifts with translucent lights!) has been rated 5.0/5.0.
about 4 years ago
You're welcome :) For more glowing you can try to copy all visible (Select → All, then Edit → Copy all visible) to a new layer and set the layer mode of this layer to "Screen".
Derrrberrr
about 4 years ago
Thank you so much for the response! I just finished the tutorial after many many hours of learning. I learned so many things from this tutorial. Mine doesnt look nearly as good as yours, but im super happy with it! If you could offer some more tips on making it glow more and overall shininess I would be so grateful
about 4 years ago
Maybe you forgot that you have to choose "Initialize by selection", when adding the channel (step 4). You can't really see the actual channel "on-screen". But you can see it easily in the channels dialog preview. There the previous selection from step 4 should be now white.
Derrrberrr
about 4 years ago
Hey Devvv, This tutorial looks amazing and is teaching me so many things. However i am getting stuck on step 5. Adding the channel does not seem to be changing the text white. Which i believe is the reason the gaussian blur wont work. Please help!
WubbaHead
over 5 years ago
Hiya devvv,
Glad you recieved my comments
Currently using your technics on a little trial/learning project just for fun. (and so I can try to remember how you did this, lol)
Great stuff, Thanks again !
over 5 years ago
Thank you :-) Glad that you could learn some new techniques!
WubbaHead
over 5 years ago
Excellent tutorial, Thank You !
There are a few niggles here and there but I was able to work through this tutorial with Gimp 2.10.6 in December of 2018 !
Eight years after you wrote this !!!
Mine didn't come out as pretty as yours, but the learning of technics was phenomenal.
Especially liked the channels, plasma bump, and lighting effects technics ! Way Cool.
This is NOT for rank beginners, some knowledge is required to understand the steps.
Hope you get an alert of some kind to read this.
Happy Gimping
Q-B member for about 7 years Q-B 1 comment
about 7 years ago
Kyo - Select / Selection to Path produces a path, but it doesn't show it to you until you activate it - that's after you clear the selection
(- Select / None) and go to the paths tab on the Layers window.
"Now switch to the paths tab and double click the created selection to activate it."
The path will become visible and you can then edit it with the Paths tool
Kyo
about 7 years ago
Having troubles with this in GIMP 2.8. Stuck on step 2. Selection to path does not create a new layer.
over 7 years ago
You must make sure that the bump map layer is the exact same size as the layer where you want to apply it (Layer / Layer to Image size)!
Matt
over 7 years ago
Hi I'm stuck on step 6. There is no option to choose the Highlight channel on the bump ma
Kiela
over 8 years ago
I am having trouble with step 10. I'm not sure which text layer is the 'structure layer' and which is the actual 'text layer'. Also, when I try to adjust the opacity or mode, there isn't a gradient, just very uniformly dark text. Help!
almost 9 years ago
For the plasma layer to show up you need to male sure that it has exactly the Same lauer dimensions as the image: layer -> layer to image size should help
Austin
almost 9 years ago
I am getting stuck at steps 8 and 9 to where the plasma layer isn't showing up on the bump map. please help. thanks
about 9 years ago
I know, it's not easy - its also on the second highest skill level for available tutorials here on gimpusers.com. Nevertheless, I'm sorry it didn't work for you... If I can help you please just write again.
Rudy
about 9 years ago
This tutorial is complete waste of time if you are using 2.8 Cool Fount and amazing effect but tutorial doesn't talk about a lot of nuances that are just missing. If i would just blindly follow step by step at 5th step you would encounter error and had to stop! Take idea and hawe free weekend of to learn this thing and don't be surprised if you have to repeat over and over again! TERRIBLE TUTORIAL! OUTDATED!
EternalParad0x
about 9 years ago
@Wairudo Enjin
The same thing happened to me, but when I tried creating a new layer BEFORE adding the plasma and continued the steps, it turned out great!
Wairudo Enjin
almost 10 years ago
A new layer is not being created after completing step 8. Do you have any suggestions as to why this might be?
over 10 years ago
The layer you apply a bump map on needs to have the exact same dimensions as the bump map channel. to ensure it select the layer you want a bump map applied and go to Layers / Layer to boundary size. then the bump map should show up.
Nolan
over 10 years ago
When I went to the bump map, there was no option to select the "highlight" channel.
Sput79 member for over 10 years Sput79 1 comment rated this topic with 5/5
over 10 years ago
Your work is amazing. I am not getting this to work while following along. Is there a video or another place I can get more instruction? This is sweet and I really want to use it...thank you so much.
Mindless
over 10 years ago
Can you make video please? Im trying to do this more then week without succes...
Dan
over 10 years ago
Figured it out. Point 1 was on top, Point 2 on the bottom. Doing what you said failed every time. After holding shift and clicking point 1 to deselect, holding ctrl/cmd and clicking point 2 didn't do a thing. However, clicking point 1, the same point I held shift with and clicked, while holding ctrl/cmd worked. A very simple mistake that cost me an hour or two. Might want to test it out for yourself, maybe it's outdated, but this is what happened from my experience.
Dan
over 10 years ago
Step 11 seems to be terribly explained. Somebody else had this problem, and I am literally doing EXACTLY as it says, only to fail. I have the left curve down. I hold shift and click the first point, then hold command (mac's equivalent to ctrl) and no curve appears. I am able to get a curve going on the other side, but it's all messed up. The curve doesn't appear after doing exactly what you say. What am I doing wrong?
Unforgiven
over 10 years ago
Felt like a complete waste of time. Step 6 never seen the highlights as a choice with the text selected. The layer was the same size and I did restart gimp. I did see it however when I selected the background. Tried that and that didn't look right. So figured I would choose the text that it would allow. Never got the light file to look correct on step 7 but that may be because of the fail on step 6. The tut looked real cool and I was excited to do it. Feels like a waste of time. Big disappointment.
TcMaX
over 10 years ago
stuck at step 20... using GIMP 2.8 and when I move the rays... It becomes invisible!
over 10 years ago
You missed the transparency lock as it seems. It is found in the layers dialog right above the layers (and below the opacity rulter). When you fill it (with the lock on) it will only fill parts that have any pixel value on the layer.
Evol
over 10 years ago
Got stuck in step 13. The Ctrl+, is filling the whole screen with yellow light and subsequent steps are making the whole image look completely fvcked up...
mini
over 10 years ago
I was not able to complete this tutorial. Got stuck at step 4.
It's way too frustrating.
Dasa
over 10 years ago
Plasma isn't making a new layer...
So what do I select when bump mapping the plasma?
almost 11 years ago
the layer must have the exact same dimensions as the bump map channel. try to go to "layer -> layer to image size". then try to apply the channel again in the lightning effects filter!
Technicallity
almost 11 years ago
When I go to lighting effects for the text layer, after I enable bump mapping, when i go to the drop down menu, I do not have an option for the highlight channel.
TcMaX
almost 11 years ago
Using 2.8 here, and the plasma isn't making a new layer D: (doesn't work for me)...
almost 11 years ago
I'ts not outdated, should work fine (just tried it with GIMP 2.8)!
.eXe
almost 11 years ago
The lighting file doesn't work for me.. When I click "Open" and select it, nothing changes with the presets. Not sure if it's outdated now.. I really wanted to do this tut >_<
solensdatter2 member for over 11 years solensdatter2 15 comments
about 11 years ago
WOW! Great work!! Hopefully I'll be as good ...someday :)
JustME
over 11 years ago
It's very nice...i waste my precious time for a big fail...i blocked at flip the light...and i delete all ...nice tutorial ..but not for me sorry....and really it's very nice images
Rift Universe
about 12 years ago
This is a great way to change the look of the Rift logo and keeping your site original.
about 12 years ago
Ted: Be sure that the Bump map layer does have the exactly same size as the layer you want to apply the lightning effects. You can ensure this by choosing the bump map layer in the layers dialog and then go to Layer / Layer to image size. Then it should have the same size as the other layer and it will show up in the "Bump map" tab.
Ted
about 12 years ago
This looks like it would be cool but on step #6 when I go to the Bump Map tab in the Lighting Effects dialogue it doesn't allow me to choose the channel I created. I restarted GIMP like 5 times and I can't get it to work. PLEASE HELP
Lauren
about 12 years ago
I got it to work :) I had to close the image and restart it. I think GIMP just got confused XD Thanks for the response ;)
about 12 years ago
maybe you still selected a channel or so? explicitly click a layer in the layers dialog. otherwise restart gimp - that maybe fixes it ;) if it does not help just write again.
Lauren
about 12 years ago
This is an awesome effect, (or at least looks like it will be), but for some reason on step #12 when I try to fill the path selection with pure white, it fills it with yellow. The only colour that it will fill with is black. It's on full opacity etc. and the colour is white. To see what it was, I tried turning the visibility off all layers but the background, and it still painted yellow, even if I deselected. Just a bit confused :( Any ideas?
Firezar
almost 13 years ago
Devvv: Thank you for your quick answer but i have already tried that.. With no luck. But i will try again.
almost 13 years ago
Firezar: It maybe helps by doing a Layer / Layer to Image size on the layer you apply the lights on. It is very important that the layer where you want to add a bump map on. Hope it solves your problem!
Effector: I don't think that the glowing effects would come out niceley on white background.
@all: thank you so much for the positive comments, it makes me happy to read all that ;))
Firezar
almost 13 years ago
Hi! Amazing tutorial but i'm stuck at step 6-7.. I can't apply the light? I figured out how to download the file and all that. But when I push "Apply" nothing happens? Any idea what i did wrong?
Effector
almost 13 years ago
Is it possible to create the same effect on white background? I tried, but I wasn't able to do that. If it is, please could you instruct me.
almost 13 years ago
Hi MrsZoeKnight! Thanks ;) I updated step 11 to make it more clear - is it working for you now?
MrsZoeKnight member for almost 13 years MrsZoeKnight 1 comment rated this topic with 5/5
almost 13 years ago
This looks amazing but I'm stuck on 11. I have been working on this for two days now. Ugghh... I'm not sure what you mean about making the shape for the light to shine through..... It's not your tut it's me....
Gimper
about 13 years ago
Nice tutorial!
the font is more a pirate font, pieces of eight, being treasure talk for pirates(sorry if I seem like I am bragging)
Vadim
about 13 years ago
Amazing tutorial! Thank you!
127markaz member for almost 15 years 127markaz 6 comments rated this topic with 5/5
about 13 years ago
Now THIS is an excellent tutorial. Clear and concise. Will apply it after I hit the Create Comment button.
Thank you so much. I have the perfect graphic for it.
John Czajka
about 13 years ago
Awesome tutorial, definitely going to give this a shot when i get home.
GameCreator member for over 16 years GameCreator 9 comments
about 13 years ago
So how is that many people use it already? (they must use it in order to take screenshots and put into their tutorials, right?)
Some unofficial builds from sources?
I'm on a box with Gentoo Linux, so I build everything from sources already. Might it be available from sources for me now?
I see that they restored the dropdown list with percentage zoom values. That's great. I very missed it when I suddenly disappeared after one of the upgrades.
about 13 years ago
Excellent tutorial. Good for so many applications in addition to fonts. Well done.
GameCreator-the single window of which you speak will appear in the much anticipated v. 2.8 release.
GameCreator member for over 16 years GameCreator 9 comments rated this topic with 5/5
about 13 years ago
Great effect and brilliant idea with cutting the Supernova rays! :)
BTW how did you do that that your GIMP has everything in a single window with tabs?
about 13 years ago
bones: use "Save link as" then name the file lights.txt for example. Or just click the link and copy/paste the text into a new file.
In the lighting effects filter open this file in under the "Light" tab.
For the "lock transparency" or "Lock alpha channel" (it's the same) see the attached file please.
bones
about 13 years ago
I still think this is cool, but I still can't seem to make it all happen.
Your lights settings don't make sense to me (sorry). When I right click, the options I get are "Save link as" or "Save target as". I don't have an option to just "Save as".
And I don't have a transparency lock icon next to the opacity option. Not sure why, but it's not there.
I come back to this every now and again. Thanks for making it available, but I'm a bit lost.
fortyseven
about 13 years ago
@devvv: It works beautifully if you use: "Layer/Layer to Image Size" on the text layer. Thank you for your response and help. Very cool tut, btw!!
fortyseven
about 13 years ago
@devvv: Thank you, I will try it as you have said and let you know if I am successful.
about 13 years ago
fortyseven: make sure the layer you want to apply the light&shadow filter on is the exact(!) same size. otherwise the channel won't show up in the drop down.
to make it the same size you could use: Layers / Layer to Boundary Size
fortyseven
about 13 years ago
I don't see the 'highlights" channel in the Bump Map in Step 6.
metshadow
over 13 years ago
Very nice man. Just a thing. I don't know how, but at step 5 , i can't click on Light & Darkness... it may be impossibile, but i cannot click o.O
Can you teach me why?
Bones
over 13 years ago
This looks incredibly cool, but I got lost at steps 6 & 7.
Step 6 - When I went to "Bump Map" tab, there was no option for "Highlights", so I'm not sure what I missed.
Step 7 - I just couldn't work out what to do with the presets file you supplied. Just clicking "save us" asks me where to save to.
Do I use the numbers to save three lights? I'm confused.
Anyway, it looks great, and I might try again later.
Cheers
over 13 years ago
did you just right click the file and choose "save as..." ?
dannyboy6896
over 13 years ago
This is awesome but I cant save your attached lights file. I'm really confused because you said to just save as but i cant. When I click it, it just redirects me to a page with the presets in text. Am I missing something? I really want to get this done
cak anas
over 13 years ago
good tutorials... i like it..
nexus
over 13 years ago
excellent results! I'm impressed!
GOD
over 13 years ago
Very nice!! thanks for sharing
