Posted on December 27th, 2012
3053 views Today we will introduce you an Oscillate effect applied to the object in a flash banner. Applying such effect is as easy as applying other effects especially you will do this automatically using a wizard.
Step 1 Download and Run IncrediFlash Xtreme 4.0 from here Step 2 Under Startup window choose Website Banner Step 3 Under Style tab menu, set Layout to Landscape and choose template at column 2 row 2. Step 4 Under Settings tab menu, you can replace the background either with your own image or with the one from Incrediflash Xtreme library. Step 5 Under Text and Logo tab menu, you can add some text to the template and change the default logo with your own. Step 6 Click Finish button to exit from Create a Flash Banner window Step 7 Congratulation! Your flash banner with Oscillate Effect is done.
