Create Flash Animated Card Easily
Posted on January 29th, 2013
Adobe Flash
Making animated card isn't difficult now. You can make it self using this program. You can create and modify card as you want.
Download and Run IncrediShow from here
From startup menu, select "Create an empty project" and click "OK" button.
Incredishow will show a window to choose the dimension of the project. For this project,We use a Small Desktop Size. Click "OK" button.
To start adding photos to your project, click any of the empty thumbnail at the ProjectTimeline (bottom) with the text saying "Click to Add Photos".
A photo file browser window will appear. Click to select a photo. To select more than one photo, simply holdcontrol button while clicking. Click Open to start adding selected photos into your project.Once you finish adding photos, you will see at the Project Timeline that a slide is created for each photo.
Insert text from toolsbar. You can insert any text that you want. If you want to use a Chinese character, you have to use Arial Unicode MS and don't forget to check Multiple Font Support.
You can change the effect too. there are many effects and you can use it as you want.
Do it for your other text or image.
Congratulation! Your animated card is done. You can publish it into flash and upload it into your own website or send it by email into your college.
Here is the result:
jsebastian
Multimedia Trainer
