Num Lock - Create Shortcut in Windows
Page 1 of 2 12 LastLast
    How to Create a Desktop Shortcut to Turn Num Lock ON or OFF
    Published by
    Designer Media Ltd
       Information
    Some modern laptop keyboards have no Num Lock key. Instead the user needs to set Num Lock in BIOS.
    Various applications might turn Num Lock ON or OFF without user knowing of it.
    This tutorial will show you how to create a shortcut to turn the Num Lock on or off when you want to in XP, Vista, Windows 7, and Windows 8.
    This is how:
    1. Open Notepad
    2. Copy the following code into a new text document:
    Code:
    set WshShell = CreateObject("WScript.Shell")
    WshShell.SendKeys "{NUMLOCK}"
    3. Select Save as type: All Files (*.*), name the file as you wish and give it a .vbs extension to save your file as a Visual Basic Script:
    4. Create a shortcut for your NumLock script on your desktop (Create Shortcut & Change Shortcut Icon tutorials)
       Note
    Now you have a Num Lock shortcut which toggles NumLock ON and OFF every time it is clicked. Please notice that when script is run it gives you no sign or message; it simply turns Num Lock ON if it was OFF and vice versa.
    Kari
  1. Posts : 72,050
    Nice tutorial Kari. :)
      My Computer
  2. Posts : 9,600
    Win 7 Ultimate 64 bit
    What I would like to be able to do is disable the NUM LOCK key so it stays on all the time. I'm constantly fat fingering the stupid thing.
      My Computer
  3. Posts : 18,415
    windows 7 home 64bit
    Cheers Kari that will be handy :)
      My Computer
  4. Posts : 17,545
    Windows 10 Pro x64 EN-GB
    Thread Starter
    Thanks.
    Strangely enough it does not work on one laptop out of four I tested now.
    Kari
      My Computer
  5. Posts : 18,415
    Kari said:
    Thanks.
    Kari
    It works on mine though:)
      My Computer
  6. Posts : 51,474
    Windows 11 Workstation x64
       #6
    Fix here
      My Computers
  7. Posts : 72,050
       #7
      My Computer
  8. Posts : 9,600
       #8
    Fix here
    Oh, that was cold! Cold, man. That said,
      My Computer
  9. Posts : 19
    Windows 7 Home Premium (64-bit) Service Pack 1
       #9
    Kari said:
    Thanks.
    Kari
    Well you can always use the num lock key on the on-screen keyboard.
      My Computer
  Related Discussions
Our Sites
Site Links
About Us
© Designer Media Ltd
Find Us
