Dreevoo.com | Online Learning and Knowledge Sharing
Home | Home | Photography | Photography | Understanding Your DSLR Camera
Guest
Click to view your profile
Topics
Programs
Languages
Recipes
Home
Shortcuts
In this tutorial you will learn the meaning of words like aperture, exposure and shutter speed and how they come together to give you a better photo.
  Author: podtalje | Category: Photography | 11th June 2013 |
1.
First open the home page of the web service for camera simulation:
http://camerasim.com/camera-simulator
With CameraSim you will be able to set different parameters of the camera and see how good is your knowledge of photography.
All settings are standard and very similar to those you see on professional cameras.
2.
Lightning
Lighting is the single biggest determinant of how your camera needs to be set. With only a few exceptions, you can never have too much light.
Use this slider to experiment with different indoor and outdoor lighting conditions.
3.
Distance
Use this slider to simulate how close or far you are in relation to the subject.
4.
Focal Length
Moving this slider is the same as zooming in and out with your lens.
A wide, zoomed out setting creates the greatest depth of field (more things are in focus) while zooming in creates a shallower depth-of-field (typically just the subject will be in focus).
5.
ISO
ISO refers to how sensitive the “film” will be to the incoming light when the picture is snapped.
High ISO settings allow for faster shutter speeds in low light but introduce grain into the image.
Low ISO settings produce the cleanest image but require lots of light. Generally, you will want to use the lowest ISO setting that your lighting will allow.
6.
Aperture
Aperture, or f-stop, refers to how big the hole will be for the light to pass through when the shutter is open and the picture is snapped. Lower f numbers correspond with larger holes.
The important thing to remember is this: the higher the f number, the more things in front of and behind the subject will be in focus, but the more light you will need. The lower the f number, the more things in front of and behind the subject will be out of focus, and the less light you will need.
7.
Shutter
Shutter speed is how long the shutter needs to be open, allowing light into the camera, to properly expose the image.
Fast shutter speeds allow you to “freeze” the action in a photo, but require lots of light. Slower shutter speeds allow for shooting with less light but can cause motion blur in the image.
8.
After you have set the parameters, press button to snap a photo.
9.
If you settings were not correct you will see a blurry photo or the photo will be too dark or too bright.
In this case try to change the settings so that photo will be fine.
Homework:
Try to take the photo that looks like the image on the left.
  How to photograph a candle
Photography | 10th October 2011 | Author: mat
I will show you how to take a shot of a burning candle with a compact camera and make it look professional.
  How to take photos directly to your computer
Photography | 4th December 2011 | Author: mat
Did you know you can use your camera with Adobe Lightroom  to shoot photos and display them directly on your computer screen? It's called shooting in tethered mode.
  HDR Photography for beginners
Photography | 31st October 2011 | Author: mat
Let me show you how to take photos and how to merge them into a HDR image using the Photomatrix software.
Photography | 11th June 2013 | Author: podtalje
  Please login to post a comment
  Click to open user profile
90210outlets, 26th Oct 2021, 3:53 PM
Focusing manually by moving the lens rings is quite hard and requires practice and time. Not to mention that even professional photographers still use auto mode.
Set your camera on autofocus (AF) and let your device to do the job. At least at first.
It will save you a lot of time, and you will still get that sharp focus and great image quality you’re after!
You can switch between Manual focus to Auto Focus through the Menu. But it is easier and faster to do so with the switch on the lens itself. <a href="https://90210outlets.com/">KItchen&Ba....
90210outlets, 31st Oct 2021, 7:56 PM
Bedroom is a private space that can easily reflect your individual characteristics. Plus, a tidy and cozy bedroom will also help you relaxing and relieving stress. https://www.treasurebox.co.nz/furniture/....
LizErd, 16th Apr 2023, 12:20 PM
Bioremediation involves the use of microorganisms to remove heavy metals from wastewater. The microorganisms can break down the heavy metals into non-toxic forms or accumulate them within their cells, which can then be harvested. This method is particularly useful for recovering metals such as chromium and cobalt. GOLD COBALT NICKEL ZINC METAL RECOVERY FROM MINING EFFLUENThttps://watermanaustralia.com/product/me....
LizErd, 17th Apr 2023, 10:18 AM
I can see that you are an expert at your field! I am launching a website soon, and your information will be very useful for me.. Thanks for all your help and wishing you all the success in your business. Webuplifthttps://webuplift.co.uk/seo-glasgow/
Kadimi1988, 23rd Apr 2023, 12:09 PM
Jnanabhumi AP is a startup by passionate webmasters and bloggers who have passion to provide engaging content which is accurate, interesting and worthy to read. We are mope like a web community where you can https://jnanabhumiap.in/ jnanabhumiap.in find different information’s, resources, topics on day to day incidents or news. We provide you the finest of web content on each and every topics possible with help of editorial and content team.
mehmoodalam, 10th May 2023, 12:38 PM
I admire this article for the well-researched content and excellent wording. I got so involved in this material that I couldn’t stop reading. I am impressed with your work and skill. Thank you so much.Bear mascot costumes https://www.mascotcosplay.com/mascot-cos....
mehmoodalam, 10th May 2023, 12:52 PM
It is a great website.. The Design looks very good.. Keep working like that!.ufabetเว็บแทงบอล https://www.faithucc.info/ufabetเว....
pomo, 15th May 2023, 2:18 PM
Very informative post! There is a lot of information here that can help any business get started with a successful social networking campaign. 피망 머니상playpokerluck.com
mehmoodalam, 20th May 2023, 11:27 AM
When it comes to Toto sites, diversity reigns supreme. With a plethora of options available, players have the freedom to explore and select platforms that align with their personal preferences. From government-approved sites, ensuring legal and secure gameplay, to licensed private sites that meet stringent qualifications, and even overseas sites offering lucrative odds, the choices are vast. This extensive selection caters to the individual tastes of players, ensuring a customized and enjoyable experience for all.메이저사이트 https://thehaasteam.com/
online learning made for people
Dreevoo.com | CONTRIBUTE | FORUM | INFO
