PSU - Test DC Output Voltage
Page 1 of 2 12 LastLast
    How to Test PSU DC Output Voltages to Determine if Faulty
    Published by
    Designer Media Ltd
       Information
    The Internal ATX Power Supply converts the Alternating Current (AC) from the mains input to a Direct Current (DC) output that is required for the computer to work.The typical voltages supplied are 3.3 volts, 5.0 volts, -5.0 volts, 12.0 volts, -12.0 volts.
    The 3,3 and 5 volts are typically used by the digital circuits, whereas the 12-volt is used to power the motors found in Disk Drives and Hard Drives. It is also used to Power the CPU. The following tests involve testing the voltages across the HDD, Motherboard, CPU, CD/DVD ROM Drive Power Connectors.
       Warning
    NEVER ATTEMPT MAINTENANCE ON POWER SUPPLIES AS THEY CAN BE DANGEROUS
    EVEN WHEN THE POWER REMOVED. If a fault is suspected with the PSU then the first step is to take VOLTAGE readings, then substitute the POWER SUPPLY with a good quality brand, with the same MAINS VOLTAGE and WATTAGE.
    PSU and PSU Connectors Overview.
    PSU - Test DC Output Voltage-power-supply.png PSU - Test DC Output Voltage-power-supply-connectors.png
    Here's How:
    1. To Check The HDD 4-Pin Molex Power Connector Voltages:
    The maximum voltage that will be measured will be no more than 12v/12.6v.
    The Multi-meter should be set to DC 20 Volts as shown.
    The meter display will show 00.0 (i.e. - 0 Volts).
    NOTE: Any number after the decimal point can be ignored
    The computer is best laid on its side when taking meter readings for ease of access.
    Next open the case and power up the computer:
    Care should be taken here as the fans will be spinning, certain components will be hot to the touch and observe ESD precautions.
    The Anti-static wristband should be worn and attached to the case or an Earthing Point.
    (If you do not have one, simply earth yourself on the metal part of the computer case periodically)
    Locate the HDD 4-pin Molex.
    The Red Probe should be inserted into the right-hand side of the connector (Yellow Wire)
    The Black Probe should be inserted into one of the two centre holes (Both of which are negative)(Black Wires).
    The reading should read 12.4V
    PSU - Test DC Output Voltage-hard-drive-test.png PSU - Test DC Output Voltage-molex.png
    NOTE: You can also take a reading between the connector and the computer case,
    the voltage reading will be the same (12.4V), as shown.
    A reading should also be taken between the RED wire on the back of the HDD Molex
    and the computer case, this will show a reading of around 5V.
    NOTE: This method can be repeated for testing the voltages for Red and Yellow wires
    on the CD/DVD Drive Molex Connector and for testing Molex Fan Connectors and CPU Connectors, some examples below.
    PSU - Test DC Output Voltage-cd-dvd-connector.png PSU - Test DC Output Voltage-cpu-4-pin.png
    2. To Check The Motherboard 24-Pin Power Connector Voltages:
    Next we can check the voltages across the 24-Pin Motherboard connector, simply connect the RED probe to each colour in turn, whilst the Black Probe is touching the computer case, the readings will be similar to those shown.
    NOTE: The BLACK and WHITE wires are not classed as COLOURS and are rated 0V,
    you need not test between the case and these connections.
    You can of course test between these and any COLOUR in order to get a reading.
    If we look at the relationship between the COLOURS and the VOLTAGE, we will see
    that ALL the COLOURS carry exactly the same voltage, as shown.
    This is very useful to note, because if a Device has failed then you can check that it is operating at the correct voltage if you measure the same colour Wire on a different Device.
       Note
    A few notes to consider when replacing or buying a new PSU:
    Most entry level systems are usually supplied with a basic generic, unbranded PSU. If you are building a medium to high spec system, it is highly recommended that you use a branded PSU such as Antec, OCZ, Corsair etc.
    Many engineers state that 10-15% of the system budget should be used on a quality PSU.
    When replacing Power Supplies Always check the Voltage is set to the correct setting on the rear of the PSU, either 110v/115v or 220v/230v. Setting the Power Supply voltage switch to the incorrect Input Voltage could seriously damage the Power Supply and possibly cause damage to other components of your computer.
    The correct voltage is determined by the country where the Power Supply is located.
    (I.E.- UK 220v/230v USA 110v/115v.
    Final Word!!
    *****ALWAYS RECHECK YOUR WORK WHEN WORKING WITH POWER SUPPLIES*****
    Cheers Dave :)
    Credit and thanks to Brink, Arc and Essenbe for their support.
  1. Lee
    Win 7 Pro x64, VM Win XP, Win7 Pro Sandbox, Kubuntu 11
    Good Stuff Mannnnnn!. . .Thanks. . .
      My Computer
  2. Posts : 3,118
    Win7 Home Premium x64 SP1
    Great post Northernsoul55
    Good timing as i'd overlooked checking my daughters psu when i bought it and just found that it's only showing 10v on the 12v rail. HWinfo shows 10v and HWmonitor 8v.
      My Computer
  3. Posts : 5,956
    Win 7 Pro x64, Win 10 Pro x64, Linux Light x86
    Thank you Northernsoul55 I believe this will be a much used tutorial
      My Computer
  4.    #4
    Thanks Dave
      My Computer
  5. Arc
    Microsoft Windows 10 Pro Insider Preview 64-bit
    A beautiful one it is, Dave :)
      My Computer
  6. Posts : 2,014
    Windows 7 Professional 64bit
    Thread Starter
       #6
    Thanks all :) Hopefully it will serve a purpose
      My Computer
  7. Posts : 3,056
    Windows 10
       #7
    Very well executed ! :)
      My Computer
  8. Posts : 4,566
    Windows 10 Pro
       #8
    Dude your the man!!!!!!!!!!!!!!:)
      My Computer
  9. Posts : 53,367
    Windows 10 Home x64
       #9
    Good one Dave
    A Guy
      My Computer
  Related Discussions
Our Sites
Site Links
About Us
© Designer Media Ltd
Find Us
