hi, i cannot seem to retrieve using $_POST in php the variables that I passed using ajax.
i have something like:
temp1 = "root";
temp2 = "false";
var url = "sample.php";
var arg1 = "arg1="+ temp1;
var arg2 = "arg2="+ temp2;
var paramPost = arg1+"&"+arg2;
ajax.postIt(paramPost,temp2);
function postIT(param, temp2) {
// make a HTTP GET request to the URL asynchronously
request.open("POST",url, true);
request.setRequestHeader("Content-Type","application/x-www-form-urlencoded");
request.setRequestHeader("Content-length",param.length);
request.setRequestHeader("Connection", "close");
request.send("param="+param);
in my file.php, i have:
if (isset($_POST['param']))
$args1 = $_POST['arg1']; //gives out blank
$args2 = $_POST['arg2']; //gives out false value (just right)
i also tried:
$args1 = $_POST['param']; //gives out "arg1=root"
am i doing it right? how can i retrieve just the value of $arg1 insteas of the
'name-value' pair?
help! thanks a lot!
retrieving variables in php using $_POST from ajax
Started by
tinks
, Mar 09 2011 10:55 PM
2 replies to this topic
Posted 09 March 2011 - 10:55 PM
Posted 09 March 2011 - 11:12 PM
Expand out the following lines:
var arg1 = "arg1="+ temp1; var arg2 = "arg2="+ temp2; var paramPost = arg1+"&"+arg2; // param = paramPost request.send("param="+param);You'll notice the post you're sending back then is:
param=arg1=root&arg2=falseDo you see the problem now?
Posted 10 March 2011 - 01:33 AM
yey! got it now! cant believe i appended that "param" !
thanks a loooooooot!
