[C4D] - [Saving render for PS] - [theguid]
#21
Posted 09 October 2004 - 06:15 PM
#22
Posted 20 October 2004 - 07:40 AM
#23
Posted 20 October 2004 - 01:05 PM
If you do a black background and then cut it out in ps you are likely to cut out anything in your render that might be black or close to black. By making a solid color background when you render you get a nice clean color that you can select and get rid of without worry of cutting out some of your render. You can set it to any color you want that is very different from your rendered materials. And make sure you set the variables to make it a composit background so it is a flat color and not recieving any lights or shadows that could complicate the cutting out. You will have a perfect flat color that you can use the magic wand on in photoshop and then do and inverse select to select your object.
EDIT- ok here is a step by step video on how to do this Cut out your background renders
#24
Posted 20 October 2004 - 04:28 PM
im not talking about cropping it by using magic eraser or whatever. all you have to do is ctrl click the alpha channel and select inverse and delete. it doesnt delete anything because of colors.
#25
Posted 20 October 2004 - 08:04 PM
It's not going to work. If you start getting into alpha channels you will pick up part of the render when it shouldn't and you will lose a large portion of the two boxes. And what I said above in the tut isn't cropping anything.. Its using the magic WAND to select the background, which is rendered in a very different color from anything you use in your object materials and thus avoid any bleeding over that you would get from using alpha channel selections. Use the compositing render method from the tut and you would end up with this:
which takes all of 2 seconds to remove the background from and gives you perfectly clean cut edges.
#26
Posted 21 October 2004 - 12:36 PM
#27
Posted 21 October 2004 - 02:18 PM
#29
Posted 13 January 2005 - 10:10 AM
I've got C4D XL7 and to get transparant bg in ps7. Check both Alpha Channel and Seperate Channel. this works fine.
I firts couldnt get it to work with just Alpha Channel, but with Seperate Alpha checked too, it works fine.
There is a problem exporting it to photoshop CS tho.
#30
Posted 12 February 2005 - 07:26 PM
To get a transparent background on PS CS do the following.
1. Go to "Render Settings..."
2. Click "Save"
3. Set the Format as: "TARGA"
4. Check the "Alpha Channel" box
5. UNCHECK THE "24-BIT DITHERING" box
6. Click "Output"
7. Set that crap to whatever you want.
8. Close the Render Settings window
9. Go to "Render To Picture Viewer"
10. When it's done rendering go to File>Save Picture as..
11. Make sure the Format is set to TARGA
12. Make sure the "Alpha Channel" box is checked.
13. And save that crap whereever you want.
TIME FOR PHOTOSHOP CS BABY.
14. Open your whatever crap .tga
15. In the "Layers" window, click the "Channels" Tab
16. If you did everything you were supposed to in C4D correctly, u should see the different channels.
17. Here's a list of each channel you should see:
RGB
Red
Green
Blue
Alpha1
18. Press and Hold CRTL+A and while HOLDING THAT DOWN, CLICK EACH INDIVISUAL CHANNEL.
19. Release your hold and click back to the "Layers" tab.
20. Right click the single layer that is there and choose "Layer via Copy..."
21. A layer should appear above it with a PERFECTLY PRECISE TRANSPARENT BG'ed Render Cut with the finest blades of the virtual world. Yes baby... it's that good.
That's it.
MAIN POINT:
There was a certain attribute that PS CS differenced from PS 7. That was the 24-Bit dithering option in Cinema4D. It's not their fault. Adobe has nothing to do with Maxon.
If you need any assistance in doing this, feel free to contact me at my messengers:
my MSN: [email protected]
my AIM: [email protected]
my YAH: [email protected]
#31
Posted 13 February 2005 - 10:02 PM
#32
Posted 14 February 2005 - 08:35 PM
#33
Posted 09 March 2005 - 11:00 AM
It's my fist post here !
My name is Oather, and I'm Franch, so, excuse me for my english !!
So,
I've Cinéma 4D v9. I make my render un .tga, and, when I open it in Photoshop (7.0.1), I've a black background ...
Can you help me ?
Oather
#34
Posted 09 March 2005 - 02:29 PM
save it as quicktime .png fileHey everybody !
So,
Can you help me ?
Oather
#35
Posted 18 August 2005 - 03:42 PM
#36
Posted 18 August 2005 - 03:46 PM
you like the word "crap" dont you?Crap
#37
Posted 08 November 2005 - 07:37 PM
#38
Posted 08 November 2005 - 09:19 PM
#39
Posted 10 November 2005 - 10:20 PM
#40
Posted 07 January 2006 - 02:14 PM
