* * * * - 2 votes
The Ultimate Layout Slicing and Coding Guide!
  • Please log in to reply
109 replies to this topic
#21 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
  • Interests:Photoshop, Tennis, PS2, web design, CS:S
Posted 13 July 2005 - 10:17 AM
can any of you guys help me out with my missing images problem? I tried clearing my cache on firefox and internet explorer as Faken suggested but, to no avail, i tried going on at school and it was fine. Is there anything wrong with my computer?
#22 scizor
scizor
  • 48 posts
Posted 13 July 2005 - 12:40 PM
Do a spyware or virus scan or something.
#23 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 13 July 2005 - 01:34 PM
tried and nothing, there must be something wrong with my computer :S
#24 Donna
Donna
    Retired P2L Queen!
  • 12,330 posts
  • Gender:Female
Posted 13 July 2005 - 01:42 PM
Are your browsers shutdown when you clear your cache & temp files?
#25 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 13 July 2005 - 02:46 PM
no I had them open and went to tools>options>clear cache
#26 scizor
scizor
  • 48 posts
Posted 14 July 2005 - 12:42 PM
I finished my index page a few hours ago and its great in firefox but it screws up a bit in ie.
Firefox:
IE
How can i fix it??
#27 PSLover2009
PSLover2009
  • 4 posts
Posted 14 July 2005 - 08:09 PM
I kind of need help..I'm kind of stuck..on the slicing..;) :huh:. I'm on step 7 I believe..and I get this..
Its weird..it goes down below, it doesn't stay at the top..:):lol:.
#28 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 15 July 2005 - 12:18 PM
you havent split it into 3 collumns, 1 for the header_logo one for the nav and one for the end of the nav
#29 PSLover2009
PSLover2009
  • 4 posts
Posted 15 July 2005 - 12:37 PM
Well, it didn't say anything about it..plus the guy that wrote it was using an OLD version of Dreamweaver.. :) :angry:.
#30 Jaymz
Jaymz
Posted 15 July 2005 - 01:14 PM
Well, it didn't say anything about it..plus the guy that wrote it was using an OLD version of Dreamweaver.. B) <3.
:hi: That should have gone like this....
PSLover2009: "Thank you for taking 80 hours out of your busy schedule to write this, but I'm having a slight problem, can you help me?"
P2L: "Why you're welcome, how can I help you"
#31 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 15 July 2005 - 02:59 PM
plus the version of dreamweaver didnt mean anything as long as it can split cells.
#32 PSLover2009
PSLover2009
  • 4 posts
Posted 16 July 2005 - 12:28 PM
I'm sorry..:P. I just dont get the split column thing..
#33 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 16 July 2005 - 04:23 PM
if your using dreamweaver mx 2004, right click>table>split cell and choose 1 row 3 columns
Edited by syndrome, 17 July 2005 - 08:21 AM.
#34 Faken
Faken
    Pimpmaster G
  • Admin
  • 5,966 posts
Posted 16 July 2005 - 11:40 PM
Firefox:
IE
How can i fix it??
I would need you to post the page... I can't tell from your screenshot.
Faken
#35 Faken
Faken
    Pimpmaster G
  • Admin
  • 5,966 posts
Posted 16 July 2005 - 11:43 PM
Well, it didn't say anything about it..plus the guy that wrote it was using an OLD version of Dreamweaver.. :) <_<.
You've definitely skipped some steps. I suggest you start that all over again and just use the same images. I see quite a few issues in there. My tutorial mentions EVERY step and I used MX instead of MX 2004. There's pretty much no difference whatsoever so you shouldn't have any problems.
I simply recommend you start it again, or at least back up a couple of steps BEFORE things went wrong.
Faken
#36 Faken
Faken
    Pimpmaster G
  • Admin
  • 5,966 posts
Posted 16 July 2005 - 11:45 PM
Syndrome - Sorry man, i have NO clue what the issue is with your PC. I suggest a gun.
Faken
#37 syndrome
syndrome
    P2L patient #4819
  • 1,311 posts
Posted 17 July 2005 - 05:44 AM
lmao thats ok, i can connect to my school user name from home and go on the internet from that so i can see :) even if the server is rubbish and slow :)
#38 PSLover2009
PSLover2009
  • 4 posts
Posted 17 July 2005 - 08:15 AM
Ok I will try to start over :). Thanks for you help support..:).
#39 scizor
scizor
  • 48 posts
Posted 17 July 2005 - 08:28 AM
Firefox:
IE
How can i fix it??
Faken
Go to Here
View it in firefox and ie and look under the nav thats under the logo and you will see that a bit of the background is there and it isnt supposed to be.
#40 Jamie Huskisson
Jamie Huskisson
  • 3,648 posts
Posted 17 July 2005 - 09:25 AM
<a href="/contactus.php"><img src="images/nav6.jpg" width="82" height="31" border="0"></a><img src="images/nav7.jpg" width="86" height="31">
          <table width="628" border="0" cellspacing="0" cellpadding="0">
try changing this to:
<a href="/contactus.php"><img src="images/nav6.jpg" width="82" height="31" border="0"></a><img src="images/nav7.jpg" width="86" height="31"><br>
