How to Create an Intense Composite of a Stone Tiger with Blue Flames
In this tutorial, I'll show you how to create a fantasy photo-manipulation using basic adjustments and some stocks and how to add some textures and make it look like a fantasy fire and show you the way how to use the clipping mask and the mask as a professional and play with the lights.
Preview of Final Results
Tutorial Resources
Let’s start with creating new document in Photoshop. Go to File > New. Set the width to1038px, height to 1468px, and resolution on 300 Pixels/Inch.
step-001
Now, Place sky stock as it is shown by selecting File > Place.. and name it Sky. Photoshop will automatically place the image as smart objects, then Resize it to be like this.
step-002
Place the Rock Stock too by selecting File >Place .. and place it as shown in the image below. Name it "Rock Back".
step-003
Select the Pen tooland set the mode to "Path".
Use the Pen tool to create a path around the rock as shown below.
step-004
Right-click on the path and select "Make Selection". Set the "Feather Radius" setting to 1 pixel then click OK.
step-005
In the Layers panel (Window >Layers), click on the "Add layer mask" button. Make sure that you have the "Rock back" layer selected.
step-006
The layer mask will hide the area that we selected earlier. Your results should look like the image below.
step-007
Go to File >Place and place the Panther stock image. Like in the previous steps, use the Pen tool to create a selection of the panther. Right-click on the path and select "Make Selection". Click on the "Add layer mask" button in the Layers panel.
step-008
Select the "Rock Back" layer and duplicate it (Ctrl/Cmd+J). Move the layer above the "Tiger" layer. Flip the layer by going to Edit >Transform >Flip Horizontal.
step-009
Step 10
Duplicate the "ROCK" layer and rename it to "ROCK Shadow". Move this layer under the "ROCK" layer (so that it's 2nd from the top).
step-010
Step 11
Rasterize the "Rock Shadow" layer by right-clicking on the layer and selecting "Rasterize Layer". Then, go to Layer >Layer Mask >Apply.
step-011
Step 12
Right-click on the "Rock Shadow" layer and select "Blending Options". Checkmark the "Color Overlay" style and use the following settings:
Pages: 1 2 3
90% Off Cyberpunk Preset Bundle
Sponsored
Make your artwork look like they're from an alternate universe. These Cyberpunk presets work with Photoshop (via the Camera Raw filter) and Lightroom. Download all 788 presets for 90% off.
32 comments on “How to Create an Intense Composite of a Stone Tiger with Blue Flames”
  1. end product looks great, but it's a very difficult tut to follow and after downloading the psd file have noticed that there is a fair bit in there that isn't even mentioned in the above. A lot of it is very confusing ... and I have been using photoshop for a very long time.
    1. Yeah I too admit with above saying. It is like you are hiding things. You know some things are filled bye me by my like common sense this should be like this. So Please this project was awesome it conducted more easily
    2. I agree. Since I have a lot of experience with Photoshop, I was able to do this. There could be more detailed instructions, however.
  2. I got lost when you arrive to those gradient layers it doesn't seem to do
    nothing on the overall maybe it is ''over doing'' to get the same results. I have to redo it because I don't see how I will be able to bring it back the right way.
  3. Nice tut and all but you need to explain more in details in some specific areas especially for people who has NEVER used Photoshop before.
  4. Nice tut and all but you need to explain more in detail for some specific areas in your steps especially for people who has NEVER used Photoshop before.
  5. Thanks a lot! My cousin has a photo studio, and he always finds a creativity. yesterday i sent this tutorial's link to them, and today he called me and said the tutorials are awesome.
    Keep it good work!!!!
  6. I would love to do this one, but the links are HORRIBLE. When you click on them they don't go to the specific pic. If you suck it up and decide to dig around and find them, you have no idea what you are looking for because there isn't even an example pic for each link. I've had the tabs open since the original post above, but can't do anything with it because it's an impossible task.
  7. This tutorial is atrocious. The steps are simple enough, but so poorly written that many of them do not make sense. It's often very unclear which tool or layer or effect the user is working with. Can't believe I wasted so many hours on this.
    1. Hey, I was stuck as well, but the adjustments are the ones that are next to properties just below colour and swatches
      Hope that helps
  8. Hey everyone I`m stuck on Step 16! I`ve selected the stone BUT what is meant with the selection or how do I set up the shown adjustments? It would be very kind of you if someone could help me with a hint! I know I`m a sort of a ps-n00b, but everyone is at some point a bl00dy beginner.
    Best regards
    d4n
Leave a Reply
cross
