In this Python tutorial, we will comprehensively learn all the concepts of Python. The following are the topics we are going to cover in this tutorial:
Watch this Python Tutorial Video for Beginners:
What is Python?
Python is a free, open-source programming language. Therefore, all you have to do is install Python once, and you can start working with it. Not to mention that you can contribute your own code to the community.
Python is also a cross-platform compatible language. So, what does this mean? Well, you can install and run Python on several operating systems. Whether you have a Windows, Mac, or Linux, you can rest assured that Python will work on all these operating systems.
Python is also a great visualization tool. It provides libraries such as Matplotlib, Seaborn, and bokeh to create stunning visualizations.
In addition, Python is the most popular language for Machine learning and Deep Learning. Today, all top organizations are investing in Python to implement Machine Learning in the back-end.
Why learn Python?
Learning a python programming language is fun. If you compare Python with any other language, for example, Java or C++, then you will find that its syntax is a way lot easier. You also don’t have to worry about the missing semicolons (;) in the end!
Suppose we want to print “Welcome to the world of programming” on our screen. Let’s compare the syntax for Python and Java:
Python Syntax:
print(“Welcome to the world of programming”)
Java Syntax:
class Simple{
public static void main(String args[]){
System.out.println("Welcome to the world of programming");
So here we see that Python code consists of only one line, but for Java, there are multiple lines of code just for printing a statement.
Let’s explore the history of Python in this Python tutorial.
Interested in learning Python? Enroll in our Python Course in London now!
Python History
Python’s roots are traced back to the late 1980s. Guido Van Rossum of CWI in the Netherlands began implementing Python in December 1989. Python labeled version was first published in February 199,1 whereas, Python 1.0 was launched in 1994, and it included new capabilities such as lambda, map, filter, and reduce. List comprehensions and garbage collection mechanisms were included in Python 2.0. Python 3.0 (commonly known as “Py3K”) was released on December 3, 2008. It was created to correct language’s underlying weakness. The ABC programming language, which was capable of Exception Handling and connecting with the Amoeba Operating System, is claimed to be the forerunner of Python.
Characteristics of Python
- Easy and simple to learn and understand.
- Python enables object-oriented programming and concepts such as classes, encapsulation, and so on.
- Python is a dynamically typed language
- It turns the code into bytecode, which can be run on any platform.
- It is an extensible programming language which means we can write and compile code like any other programming language.
- Python is also an integrated language since it can easily be used with other programming languages such as C, C++, Java, and others.
Career Opportunities:
Python has huge career opportunities in the IT industry. Almost every other IT company, be it a startup or a Multi-National Company uses python for varied applications. So, if you have good expertise in python, you will be in demand for a wide range of jobs in different domains such as machine learning, cloud infrastructure, website designing, testing, and many more.
Large Open Source Community:
Let’s say you are working on python projects and you get stuck somewhere, you don’t have to worry at all because python has a huge community for help. So, if you have any queries, you can directly seek help from millions of python community members.
Now, in this Python tutorial, we will look at the procedure to install Python.
Learn how to use Machine Learning in Python with this Machine Learning Tutorial.
Python Installation
If you are new to programming, then installing a programming language itself could be a herculean task. So, now we are going to look at the step-by-step process to install python.
- Start off by going to this website -> Downloads Python
- Click on the downloads tab and choose the operating system and python version. So, here I am downloading python version 3.7.4 for Windows operating system.
Now that we have installed python, let’s go ahead in this tutorial and start off with programming in Python
For the best of career growth, check out Intellipaat’s Python Course in Sydney and get certified!
Python 2 Vs. Python 3
The two versions of Python- Python 2 and Python 3 are the most widely used Python versions and there are many differences between these versions which are as follows:
Python 2 |
Python 3 |
The release year of Python 2 is 2000 |
The release year of Python 3 is 2008 |
The syntax is more complex in this version than in Python 3 |
The syntax is easy and simple |
By default, strings are saved in ASCII format in version 2 of Python |
By default, strings are saved in UNICODE format in this version. |
In Python 2, Print is a statement. So, the syntax is print “hello” |
In Python 3, Print is a function. So, the syntax is print (“hello”). |
Exceptions should be enclosed in notations in Python 2. |
Exceptions should be enclosed in parentheses in Python 3. |
In python 2, while using variables inside a for-loop, their values do change. |
In Python 3, the value of variables stays constant. |
Python 2 is not that popular after 2020 compared to Python 3 |
Python 3 is a more popular version of Python and is being used for many purposes |
To perform iterations in Python 2, xrange() is used |
To perform iterations in Python 3, Range() is used |
Explore the potential of Python’s ‘Pass’ statement and elevate Your understanding with our comprehensive blog!
Variables in Python:
You can consider a variable to be a temporary storage space where you can keep changing values. Let’s take this example to understand variables:
So, let’s say, we have this cart and initially we store an apple in it.
After a while, we take out this apple and replace it with a banana.
Again, after some time, we replace this banana with a mango.
So, here this cart acts like a variable, where the values stored in it keep on changing.
Now, that we have understood what a variable is, let’s go ahead and see how can we assign values to a variable in python.
Assigning values to a variable:
To assign values to a variable in Python, we will use the assignment (=) operator.
Here, initially, we have stored a numeric value -> 10 in the variable ‘a’. After a while, we have stored a string value -> “sparta” in the same variable. And then, we have stored the logical value True.
Now, let’s implement the same thing in Jupyter Notebook and look at the result:
Assigning a value 10 to a:
Allocating “sparta” to a:
Assigning True to a:
Going ahead in this tutorial, we will learn about data types in Python.
Watch Learn Python Course for Beginners
Data Types in Python
Every variable is associated with a data type and these are the different types of data types available in python:
Now, let’s understand these individual data types by their implementation in the Jupyter notebook.
OOPS Concepts in Python
From its early beginning, Python has been an object-oriented language. Object-oriented programming (OOPs) is a programming technique that emphasizes the usage of classes and objects. Its goal is to use programming to create real-world concepts like inheritance, polymorphisms, and encapsulation. The basic idea behind OOPs is to combine data and the functions that interact with it into a single entity so that no other parts of the code may touch it. It also emphasizes the creation of reusable code. It is a common method of resolving an issue by generating objects.
The key concepts of Oops are as follows:
- Objects
- Classes
- Inheritance
- Polymorphisms
- Encapsulation
Numbers in Python
Numbers in python could be integers, floating-point numbers or complex numbers.
Let’s start off with an example on integer:
Here, we have assigned the value 100 to num1 and when we check the type of the variable, we see that it is an integer.
Next, we have an example on floating-point number:
This time, we have assigned the value 13.4 to num2 and checking the type of the variable, tells us that it is float.
Finally, let’s look at an example of a complex number:
Here, we have assigned the value 10-10j to num3. Now 10-10j comprises two parts-> the real part and the imaginary part and combining these two gives us the complex number.
Now, let’s start with Python Strings.
Intellipaat is providing free Python Interview Questions and Answers, which will help you excel in your career!
Python Strings
Anything written in single or double quotes is treated as a string in Python.
Now, let’s see how can we extract individual characters from a string.
So, I’d want to extract the first two characters from ‘str1’ which I have created above:
Now, similarly, let’s extract the last two characters from str1:
Now, let’s head onto tuples in Python:
Python Tuples
A python tuple is a collection of immutable Python objects enclosed within parentheses(). Elements in a tuple could be of the same data type or of the different data types.
Let’s create a tuple where elements are of the same data type:
Now, let’s access the first element from this tuple:
Extracting the last element from this tuple:
Now, we will go ahead and learn about Python lists.
We have the perfect professional Python Course in Bangalore for you!
Python Lists
Python Lists is an ordered collection of elements.
_blank
It can contain elements of different data types, unlike arrays.
Now, let’s create a list with different data types:
Now, let’s do some operation on the list we created:
Fetching the first element from the list:
Adding an element while removing the other:
The below line of code will return the length of the list:
This will return the list in reversed order.
Now, we will further look at Python Sets.
Get 100% Hike!
Master Most in Demand Skills Now !
Python Sets
Python sets are a collection of unordered and unindexed items.
Every element in a set is unique and it does contain duplicate values.
Sets can be used to perform mathematical calculations such as union, intersection, and differences.
Creating a set:
Here, in set ‘Age’, value “22” is appearing twice. Since every element in set is unique, it will remove the duplicate value.
Operations on Sets:
1. Add: This method adds an element to the set if it is not present in it.
2. Union: It returns the union of two sets.
3. Intersection: This method returns the intersection of two sets.
4. Difference: The difference of two sets(set1, set2) will return the elements which are present only in set1.
Now, we will look at Python Dictionary.
Python Dictionary
Python Dictionaries is an unordered collection of data. The data in the dictionary is stored as a key:value pair where the key should not be mutable and value can be of any type.
Creating a Dictionary:
Accessing elements from a dictionary:
Removing elements from a dictionary:
Replacing elements in a dictionary:
Going ahead in this tutorial, we will learn about conditional statements.
Conditional Statements
We use a conditional statement to run a single line of code or a set of codes if it satisfies certain conditions. If a condition is true, the code executes, otherwise, control passes to the next control statement.
There are three types of conditional statements as illustrated in the above example:
- If statement: Firstly, “if” condition is checked and if it is true the statements under “if” statements will be executed. If it is false, then the control will be passed on to the next conditional statements.
- Elif statement: If the previous condition is false, either it could be “if” condition or “elif” after “if”, then the control is passed on to the “elif” statements. If it is true then the statements after the “elif” condition will execute. There can be more than one “elif” statement.
- Else statement: When “if” and “elif” conditions are false, then the control is passed on to the “else” statement and it will execute.
Now, let’s go ahead and learn about loops in this Python tutorial.
Types of Loops in Python
If we have a block of code then statements in it will be executed sequentially. But, when we want a statement or a set of statements to be executed multiple times then we use loops.
1. While loop:
loop: We use this loop when we want a statement or a set of statement to execute as long as the Boolean condition associated with it satisfies.
In the while loop, the number of iterations depends on the condition which is applied to the while loop.
2. for loop:
Here, we know the number of iterations unlike while loop. This for loop is also used for iterations of statements or a set of statements multiple times.
3. Nested loop:
This type of loop consists of a loop inside a loop. It can be for loop or can be a combination of for and while loop.
Now, we will learn about user-defined functions in this Python tutorial for Beginners.
User-Defined Function
In any programming language, functions are a better and systematic way of writing. Functions provide us the liberty to use the code inside it whenever it is needed just by calling the function by its name.
Syntax: def function()
Going ahead in this tutorial, we will learn about Exception Handling.
Exception Handling
Basically, an exception is an abnormal condition or error that occurs during the execution of a program. Whenever an exception occurs in a program, the execution of the program halts and the further instruction of the programs are not executed.
We need to handle these exceptions in order to ensure the normal execution of the program.
Some of the common exceptions that occur in Python programs while executing are:
- NameError: This error occurs when a name is not found.
- ZeroDivisionError: When a number is divided by zero, ZeroDivisionError occurs.
- IndentationError: This error occurs due to the wrong indentation.
- IOError: When the Input-Output operation fails, IOError occurs.
So, in Python we use the try, catch, except, and finally to handle the exceptions.
Learn how to handle Exceptions in C++ through this blog!
try-except block
In the Python program, the line of code that may throw exceptions is placed in the try block.
The try block should have an except block with it to handle the exception. As an illustration – If any exception occurs in the try block then the statements in the except block will be executed.
Syntax:
try:
#line of code
except Exception:
#line of code
#rest of the code
Example:
“else” block
In this case, the else block will be executed if no exception occurs.
Syntax:
try:
#line of code
except Exception:
#line of code
else:
#If there is no exception then this piece of code will be executed
Example:
“finally” block
If we want a piece of executable code, which we cannot skip under any circumstances, then we need to put this code in the finally block.
Syntax:
try:
#line of code
finally:
#This piece of code will definitely be executed.
Example:
Applications of Python
These are some applications of Python:
- Python may be used to create web apps
- Python can be used as a support language and hence, the best use for software development
- It is also used in scientific and numeric applications.
- To build e-commerce websites or ERP applications, Python will be of great use.
- Fandango, AnyCAD, and RCAM are all functions in Python that can be used to construct a 3D CAD application.
- Many libraries for working with image processing applications are available in Python.
- Python is versatile enough to execute a variety of tasks, therefore it can also be utilized to construct multimedia apps.
Here, in this tutorial, we learned all the basics of Python which are variables, string, numbers, data types, tuples, lists, sets, dictionaries, conditional statements, loops, user-defined functions, and exception handling. If you want to go through more concepts of Python in-depth, this Tutorial consists of all the modules that will help you throughout your learning.
If you have any doubts or queries related to Python concepts, do a post on Python Community.
