How to write a basic jQuery Plugin
Written by David O'Dey on May 17, 2016
If you’re like me you may have wanted to write a jQuery plugin, but wasn’t sure how or where to start? I will attempt to show you in this article, how to write a simple jQuery plugin that uses a weather API to display current temperatures based on a zip code. Lets get started.
What is a plugin?
Before you can write a jQuery plugin, its good to know what a plugin is and how they work. A plugin as a new method that performs a series of actions on a selection. It’s available to call on and re-use throughout your code. You create this method by extending the jQuery prototype object. Doing so inherits this new method on all core jQuery objects. If your really new to jQuery its easy to be intimidated by the terminology, don’t be. A method is a function, that’s all it is.
Where do you start?
Now that we understand what a plugin is and does, lets go ahead and write one. For this article I’ve created a plugin that will display the current temperature to selected cities based off zip code. Well add an icon to display the current weather and well also display the average temperature between all the selected cities.
Extend the jQuery prototype object and add scope. The first thing we need to do is start the script with the following code:
(function ( $ ) {
}( jQuery ));
We start with this for two reasons. It allows your plugin to play nice with other js libraries and avoid possible conflicts. This will also allow us to store private variables that can be used throughout your plugin. Our next step is to create the new method, for this example I used the name avgWeather.
(function ( $ ) {
    $.fn.avgWeather = function() {
}( jQuery ));
JQuery provides an easy way of doing this by using $.fn or jQuery.fn. This is what allows us to call $(‘.someClass’).avgWeather(); w will run the avgWeather function on the selection ‘someClass’.
We’re going to want to add some customizable settings. Lets add support for accepting options by adding an object literal. Doing so will allow us to add as many options as we need to our plugin.
(function ( $ ) {
$.fn.avgWeather = function( options ) {
    var settings = $.extend({}, $.fn.avgWeather.defaults, options);
$.fn.avgWeather.defaults = {
    tempUnits: "imperial",
    apiKey: "Enter Api Key"
}( jQuery ));
Now, whenever we need to refer to the unit of measurement in our code we can use: settings.tempUnits, which will return the value passed into $.fn.avgWeather.defaults. We will also be able to pass the options when calling the method in our markup, making it even more flexible.
$(".getTemp").avgWeather({
Passing the options like this in the markup, overwrite any of the default values we added to the script.
We’ve now created the basic foundation for our plugin. The plugin can accept private variables and should play nice with other libraries. We’ve created a new method that will be called when we want to run the script and we have the ability to pass multiple options, AWESOME.
The markup
Before we begin scripting the plugin lets take a look at the markup.
<div class="getTemp">
    <ul class="cities">
        <li data-zip="60559">Westmont
            <span class="temp">0</span>
            <img class="icon" src="">
        </li>
        <li data-zip="90210">Beverly Hills
        </li>
        <li>Average Temperature
            <span class="total-temp">0</span>
        </li>
    </ul>
</div>
What were going to do is run $(‘.getTemp’).avgWeather(); This will run the script on the div with getTemp. The script will do the following:
  1. Iterate through the <li> tags nested in <div class="getTemp">.
  2. If an <li> tag has a data attribute of data-zip then we well send off a request to the weather API and return the information for that zipcode.
  3. With the returned information we will display the temperature to the span tag with the class of temp, nested inside the <li> tag.
  4. We will also display the icon that is returned from the API and display that in img tag also nested inside the <li>.
  5. If the <li> tag does not have the data attribute associated with it, the script simply skips over it.
  6. Finally we will take all the temperatures, do some basic math and return the avg temperature, displaying that inside the class ‘total-temp’.
The script
Now that we have the basic structure complete, lets start the script. The first thing well want to do, is run a basic loop using $(‘this’) as the selector. This, refers to the selector that you will run the method avgWeather on. Based on the example markup above THIS would have the context of <div class=”getTemp”> ... </div>.
(function ( $ ) {
        $(this).each(function () {
        return this;
}( jQuery ));
You see that we added the line return this;. By returning this, we are returning the object back to jQuery so it can be chained to another jQuery object, if needed. Im sure you are familiar with chaining. Its when you string several jQuery methods together. For example : $(‘.getTemp).avgWeather().css(‘color’,’blue’); This would run the method .avgWeather() on the selection $(‘.getTemp’) and also change the color of all the output text to blue.
Next well want to iterate through the list items we presented in the markup.
(function ( $ ) {
            $("li[data-zip]", this).each(function() {
        return this;
}( jQuery ));
This will look for all the <li> tags with the data attribute of ‘data-zip’ and perform actions on each one. Before we handle that lets assign some variables.
(function ( $ ) {
       // output the total avg temp in this div
       var $targetTotal = $('.total-temp',this),
        // counts the number of cities
        $count = $('.cities li[data-zip]', this).length,
        // location of the icon url in the returned data
        iconUrl = 'http://openweathermap.org/img/w/',
        // starts the total counter
        total = 0;
        $('li[data-zip]', this).each(function() {
            var // output the current temp
            $target= $('.temp', this),
            // selects this element with class of icon
            $targetIcon = $('.icon', this),
            // finds the zipcode
            $zipCode = $(this).attr('data-zip'),
            // json url that the data is sent to
            jsonUrl = 'http://api.openweathermap.org/data/2.5/weather',
            temp,  // future data assignment
            icon;  // future data assignment
    return this;
}( jQuery ));
Getting and using the data
We are almost done, the last thing we will want to do is run the api call on the data and do something with the response. In this case, well want to output the temperature, load the icon and compute the average temperature. Lets make that API call to the server using ajax. For this example we used a free service called Open Weather Map.
(function ( $ ) {
        total = 0;
            temp,
            icon;
             $.ajax({
            	url: jsonUrl,
            	cache: true,
            	type: 'GET',
            	dataType: 'jsonp',
            	data: {
            		zip: $zipCode,
            		units: settings.tempUnits,
            		country: 'US',
            		appid: settings.apiKey
            	success: function (data) {
            		temp = Math.round(data.main.temp);
            		icon = iconUrl + data.weather[0].icon + '.png';
            		$target.text(temp);
            		total += temp;
            		$targetTotal.text(total / $count);
            		$targetIcon.attr('src', icon);
    return this;
}( jQuery ));
Notice in the data we are sending to the API, we’re using the option we created below settings.tempUnits?
The script is now complete, the only thing left is to fire the script in the markup and pass any options you want. What if you want to cycle through another set of select cities, do you need to alter the code? You wont have to change the js, but you will want to add the markup and change the zipcodes.
    <ul class="cities">
        </li>
        </li>
        </li>
    </ul>
</div>
    <ul class="cities">
        <li data-zip="85260">Scottsdale
        </li>
        <li data-zip="85331">Cave Creek
        </li>
        </li>
    </ul>
</div>
By adding a second set of <div class=”getTemp”> … </div> elements, the plugin will read it as a separate instance of this, running the script a second time returning those values. All you need to do is change the zip codes of the cities you want the data for and your all set.
Here is a link to the working demo of the plugin along with all the files on GitHub. I hope this article has gotten you a little bit more familiar with how plugins work. For more examples and to learn more go to learn.jquery.com.
