Accessibility
Home > Products > FreeHand > Support > Learning FreeHand MX
Macromedia FreeHand Support Center - Learning FreeHand MX
FreeHand tutorial: Designing with imported artwork
If you completed FreeHand tutorial: Illustration basics, which is the first tutorial of this two-part series, you designed a product logo. In this tutorial, you'll incorporate that artwork into a larger document: a sales brochure. Although you're not required to complete the previous tutorial before beginning this tutorial, Macromedia recommends that you work through the previous tutorial for a more complete experience with the new Macromedia FreeHand features and MX interface.
The tutorial takes approximately 1 hour to complete, depending upon your experience, and teaches you how to perform the following tasks:
Download the source file
View the completed file
Open an existing document
Import a FreeHand illustration
Apply special effects
Import a Macromedia Fireworks PNG file
Get creative with text
Work with styles
Import a Macromedia Flash SWF movie
Create a clipping path
Preview the document in Macromedia Flash Player
Take the next steps
9 February 2003
import, extrude, extrusion, 3-D, Fireworks, Flash, PNG, SWF, print, clipping path, mask, gradient, graphic style, text style, illustration, graphic, design, artwork, vector, bitmap, basics, live effects, raster effects, vector effects, type, text, Object panel, properties, alpha channel, transparency, tutorial
Doc ID: 9958
