- Learning Ruby on Rails
- Rails 2.1 Home
- Rails 2.1 Introduction
- Rails 2.1 Installation
- Rails 2.1 Framework
- Rails 2.1 Dir Structure
- Rails 2.1 Examples
- Rails 2.1 Database Setup
- Rails 2.1 Active Records
- Rails 2.1 Migrations
- Rails 2.1 Controllers
- Rails 2.1 Views
- Rails 2.1 Layouts
- Rails 2.1 Scaffolding
- Rails 2.1 and AJAX
- Rails 2.1 Uploads Files
- Rails 2.1 Sends Emails
- Advanced Ruby on Rails 2.1
- Rails 2.1 RMagick Guide
- Rails 2.1 Basic HTTP Auth
- Rails 2.1 Error Handling
- Rails 2.1 Routes System
- Rails 2.1 Unit Testing
- Rails 2.1 Tips & Tricks
- Quick Reference Guide
- Ruby on Rails 2.1 Useful Resources
- Ruby on Rails 2.1 - Resources
- Ruby on Rails 2.1 - Discussion
Ruby on Rails 2.1 - Sending Emails
ActionMailer is the Rails component that enables applications to send and receive emails. In this chapter, we will see how to send an email using Rails.
Let’s start with creating an emails project using the following command.
C:\ruby> rails -d mysql emails
Here we are using -d mysql option to specify our interest to use MySQL database. We can specify any other database name like oracle or postgress using the -d option. By default, Rails uses SQLite database.
Setting Up the Database
Even though we are not using a database in our application, but Rails needs it to proceed. So let's perform these additional steps.
Given below is the way to create a database −
mysql> create database emails; Query OK, 1 row affected (0.01 sec) mysql> grant all privileges on emails.* to 'root'@'localhost' identified by 'password'; Query OK, 0 rows affected (0.00 sec) mysql> FLUSH PRIVILEGES; Query OK, 0 rows affected (0.00 sec)
To direct Rails to locate the database, edit the configuration file ~\upload\config\database.yml and change the database name to cookbook. When you finish, it should look as follows −
development: adapter: mysql encoding: utf8 database: emails username: root password: password host: localhost test: adapter: mysql encoding: utf8 database: emails username: root password: password host: localhost production: adapter: mysql encoding: utf8 database: emails username: root password: password host: localhost
Action Mailer – Configuration
Following are the steps you have to follow to complete your configuration before proceeding with the actual work. −
Go to the config folder of your emails project and open the environment.rb file and add the following line at the bottom of this file.
ActionMailer::Base.delivery_method = :smtp
It informs the ActionMailer that you want to use the SMTP server. You can also set it as :sendmail if you are using a Unix-based operating system such as Mac OS X or Linux.
Add the following lines of code at the bottom of your environment.rb as well.
ActionMailer::Base.smtp_settings = { :address => "smtp.tutorialspoint.com", :port => 25, :domain => "tutorialspoint.com", :authentication => :login, :user_name => "username", :password => "password", }
Replace each hash value with proper settings for your Simple Mail Transfer Protocol (SMTP) server. You can take this information from your Internet Service Provider if you already don't know. You don't need to change port number 25 and authentication type if you are using standard SMTP server.
You may also change the default email message format. If you prefer to send email in HTML instead of plain text format, add the following line to config/environment.rb as well −
ActionMailer::Base.default_content_type = "text/html"
ActionMailer::Base.default_content_type could be set to "text/plain", "text/html", and "text/enriched". The default value is "text/plain".
The next step is to create a mailer.
Generate a Mailer
Use the following command to generate a mailer as follows −
C:\ruby\> cd emails C:\ruby\emails> ruby script/generate mailer Emailer
It will create a file emailer.rb in the app/models directory. Check the content of this file as follows −
class Emailer < ActionMailer::Base end
Now let's create one method inside the ActionMailer::Base class as follows −
class Emailer < ActionMailer::Base def contact(recipient, subject, message, sent_at = Time.now) @subject = subject @recipients = recipient @from = 'no-reply@yourdomain.com' @sent_on = sent_at @body["title"] = 'This is title' @body["email"] = 'sender@yourdomain.com' @body["message"] = message @headers = {} end end
The contact method has four parameters: a recipient, a subject, a message, and a sent_at, which defines when the email is sent. The method also defines six standard parameters that are a part of every ActionMailer method −
@subject defines the e-mail subject.
@body is a Ruby hash that contains values with which you can populate the mail template. You created three key-value pairs: title, email, and message
@recipients is a list of the people to whom the message is being sent.
@from defines who the e-mail is from.
@sent_on takes the sent_at parameter and sets the timestamp of the email.
@headers is another hash that enables you to modify the e-mail headers. For example, you can set the MIME type of the e-mail if you want to send either plain text or HTML e-mail.
Creating the Controller
Now, we will create a controller for this application as follows −
C:\ruby\emails> ruby script/generate controller Emailer
Let’s define a controller method sendmail in app/controllers/emailer_controller.rb, which will call the Model method to send an actual email as follows −
class EmailerController < ApplicationController def sendmail recipient = params[:email] subject = params[:subject] message = params[:message] Emailer.deliver_contact(recipient, subject, message) return if request.xhr? render :text => 'Message sent successfully' end end
To deliver e-mail using the mailer's contact method, you have to add deliver_ to the beginning of the method name. You add a return if request.xhr?, so that you can escape to Rails Java Script (RJS) if the browser does not support JavaScript and then instruct the method to render a text message.
You are almost done except to prepare a screen from where you will get the user information to send email. Let's define one screen method index in the controller and then in the next section, we will define all the required views −
Add the following code in emailer_controller.rb file.
def index render :file => 'app\views\emailer\index.html.erb' end
Defining Views
Define a view in app\views\emails\index.html.erb. This will be called as the default page for the application and will allow users to enter message and send the required email −
<h1>Send Email</h1> <% form_tag :action => 'sendmail' do %> <p><label for="email_subject">Subject</label>: <%= text_field 'email', 'subject' %></p> <p><label for="email_recipient">Recipient</label>: <%= text_field 'email', 'recipient' %></p> <p><label for="email_message">Message</label><br/> <%= text_area 'email', 'message' %></p> <%= submit_tag "Send" %> <% end %>
Apart from the above view, we need one more template, which will be used by the Emailer's contact method while sending message. This is just text with standard Rails <%= %> placeholders scattered throughout.
Just put the following code in the app/views/contact.html.erb file.
Hi! You are having one email message from <%= @email %> with a title <%= @title %> and following is the message: <%= @message %> Thanks
Rest for Testing
Before testing, make sure your machine is connected to the internet and your Email Server and the Webserver are up and running.
Now, test your application by using http://127.0.0.1:3000/Emailer/index. It displays the following screen and by using this screen, you will be able to send your message to anybody.
After sending a message, it will display the text message - "Message sent successfully".
Sending HTML Emails using Rails
To send mails as HTML, make sure your view (the .erb file) generates HTML and set the content type to html in your emails/app/models/emailer.rb file as follows −
class Emailer < ActionMailer::Base def contact(recipient, subject, message, sent_at = Time.now) @subject = subject @recipients = recipient @from = 'no-reply@yourdomain.com' @sent_on = sent_at @body["title"] = 'This is title' @body["email"] = 'sender@yourdomain.com' @body["message"] = message @headers = {content_type => 'text/html'} end end
For a complete detail on ActionMailer, please look into the standard Ruby documentation.
