apache2-mpm-itk (just mpm-itk for short) is an MPM (Multi-Processing Module) for the Apache 2 web server. mpm-itk allows you to run each of your vhost under a separate uid and gid — in short, the scripts and configuration files for one vhost no longer have to be readable for all the other vhosts.
Requirements
Apache2 installation with PHP support
Install apache2 with PHP4 or PHP5 support in debian etch
#aptitude install apache2
This will complete the installation
Now you need to install php4 or php5 for apache2 server
For php4 users the following command
#aptitude install php4
For php5 users the following command
#aptitude install php5
Enable mod_php for apache2 server in etch
Use the following commands
#aptitude install libapache2-mod-php4
#aptitude install libapache2-mod-php5
If you install the PHP4 or PHP5 modules for Apache2 then they will automatically enable themselves.If you have any problem you can use the following commands to enable php modules manually.
# a2enmod php4
# a2enmod php5
Install apache2-mpm-itk on Debian
aptitude install apache2-mpm-itk
This will complete the installation.
Configure apache2-mpm-itk in Debain
apache2-mpm-itk is configured on a per-vhost basis, i.e., we don’t have to set any global options, and there’s only one directive we need to set in a vhost, AssignUserId, which takes two parameters, the user name and the group that the vhost will run as.
In this example we will use the default Debian Apache vhost (you can find its configuration in /etc/apache2/sites-available/default) with the document root /var/www (if you have different vhosts, please adjust this to your situation), and we want this vhost to run as the user web_test and group web.
If the user and group don’t already exist, we can create them as follows:
#groupadd web
#useradd -s /bin/false -d /home/web_test -m -g web web_test
Then we open our vhost configuration and add the following lines to it:
<IfModule mpm_itk_module>
AssignUserId web_test web
</IfModule>
For Example
#vi /etc/apache2/sites-available/default
NameVirtualHost *
<VirtualHost *>
ServerAdmin webmaster@localhost
DocumentRoot /var/www/
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
# This directive allows us to have apache2’s default start page
# in /apache2-default/, but still have / go to the right place
RedirectMatch ^/$ /apache2-default/
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
ServerSignature On
Alias /doc/ “/usr/share/doc/”
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</IfModule>
</VirtualHost>
Restart Apache server using the following commands
#/etc/init.d/apache2 restart
Very interesting. Is this the method of setting up vhosts that shared hosting providers use?
Any why do the right click disable on your site? It’s super irritating (and easily evaded by anyone of the level reading your site) since I can’t use my spell check that uses a right click.
Thanks.
So this is very similar to SuPHP which is available for this purpose? Have always looked for something like this. Works like a charm.
SuPHP runs only PHP as a different user, this mod runs apache too.
can u explain how to use this i mean where to create directories for each user , how to acces them, can you please explain oe to deploy an simple PHP project
sorry if it is an silly question!! 🙁
Thanx in advance
Hi,
When people come in to my vhost, they are web_guest (thanks to mpm-itk)
When user logs in he must be : Michael
I need to be able to change this vhost directive from my php-application
So my vhost directive has to change only for the logged in user Michael (remain the same for the rest)
AssignUserId guest_user guest_group
To:
AssignUserId Michael user_group
I’d appreciate if you could give some directions…
Thanks,
D
a2enmod mpm_itk
Needs to be applied at then end. Module no longer automatically enabled at the end of the apt-get or aptitude install.
Or the process will appear no to work and Apache2 will default to www-data
