TuxGuitar – A multitrack guitar tablature editor and player
Sponsored Link
TuxGuitar, you will be able to compose music using the following features
Tablature editor
Score Viewer
Multitrack display
Autoscroll while playing
Note duration management
Various effects (bend, slide, vibrato, hammer-on/pull-off)
Support for triplets (5,6,7,9,10,11,12)
Repeat open and close
Time signature management
Tempo management
Imports and exports gp3,gp4 and gp5 files
Install TuxGuitar in Ubuntu
sudo aptitude install tuxguitar
This will install all the required packages for tuxguitar.
Using TuxGuitar
If you want to use TuxGuitar go to Applications--->Sound & Video--->TuxGuitar
TuxGuitar is loading
Once it opens you should see similar to the following screen
TuxGuitar Version details
Nice posts. Keep it up.
Its not a nice post. Theres no link to downlaod the software which ive been looking for like it advertised and is full of adverts, and messy.
