Create Cool Line Effects using Actionscript 3.0 in Flash CS4 or Flex Builder 3
by Horatiu Condrea 23
In this tutorial, you will learn the basics of architecting a simple Line Effect, like the one you can see bellow, either using Flash CS4 or Flex Builder 3.
We cover the basics on the simplest way, so everyone will be able to step in the scripted animation with actionscript 3.0 and create a nice visual effects like glow and blur.
Requirements
One of the following:
Download Source Files
Pre-Requisites
It would be useful to know how to use classes.
Create a ActionScript 3.0 Project or Class
If you use Flex Builder just create a new ActionScript 3.0 Project and call it LineEffect. If you use Flash CS3 or CS4 create a Flash File(ActionScript 3.0), and call it LineEffect.as . The Flash File and the class must be in the same folder. Well, this was the first step. See… It was not so hard. After that we can go and write our code
package {
	import flash.display.Sprite;
Same Imports
Again, if you use Flex Builder (Flex Builder I use too), it is not mandatory to write this step, because Flex Builder automatically imports when it sees something unknown. But if you use Flash CS3 or CS4 is required to write this step.
	import flash.display.Graphics;
	import flash.display.MovieClip;
	import flash.events.Event;
	import flash.events.MouseEvent;
	import flash.filters.BlurFilter;
	import flash.filters.DropShadowFilter;
	import flash.filters.GlowFilter;
	import flash.text.TextField;
	import flash.utils.getTimer;
       [SWF(width = "600", height = "400", frameRate = "30", backgroundColor = "#000000",    	pageTitle  = "Line Effect")]
If you are confused about this line of code:
Well, here we set the width, height, framerate, backgroundColor and the title of the SWF file.
Declaring Variables
To be easier for your future reference, I’ve declared variables for each color line. But before colors we need to declare a Sprite because we want to draw a line, and apply an effect to it. After that we will declare an Array that will help to animate the line. At the end we will declare the buttons with text as also line colors. The line colors consists in a BlurFilter, two GlowFilter and a DropShadowFilter. The code looks like that:
	public class LineEffect extends Sprite
		private var sp:Sprite = new Sprite();
		private var points:Array = new Array();
		private var prevmouseX:Number = 0;
		private var prevmouseY:Number = 0;
		private var fireBtn:MovieClip = new MovieClip();
		private var fireTF:TextField = new TextField();
		private var skyBtn:MovieClip = new MovieClip();
		private var skyTF:TextField = new TextField();
		private var grassBtn:MovieClip = new MovieClip();
		private var grassTF:TextField = new TextField();
		private var sunBtn:MovieClip = new MovieClip();
		private var sunTF:TextField = new TextField();
		private var bf:BlurFilter = new BlurFilter(3,3,1);
		private var growFilter:GlowFilter = new GlowFilter(0xff3300, 2, 20, 10, 2, 3, true, false);
		private var growFilter_b:GlowFilter = new GlowFilter(0xfff000, 2, 16, 10, 3, 9, false, false);
		private var dropShadow:DropShadowFilter = new DropShadowFilter(0, 360, 0xC11B17, 1, 70, 70, 5, 3, false, false, false);
		private var growFilter_2:GlowFilter = new GlowFilter(0x00ffff, 2, 20, 10, 2, 3, true, false);
		private var growFilter_b_2:GlowFilter = new GlowFilter(0x00ffff, 2, 16, 10, 3, 9, false, false);
		private var dropShadow_2:DropShadowFilter = new DropShadowFilter(0, 360, 0x000fff, 1, 70, 70, 5, 3, false, false, false);
		private var growFilter_3:GlowFilter = new GlowFilter(0x4AA02C, 2, 20, 10, 2, 3, true, false);
		private var growFilter_b_3:GlowFilter = new GlowFilter(0x4AA02C, 2, 16, 10, 3, 9, false, false);
		private var dropShadow_3:DropShadowFilter = new DropShadowFilter(0, 360, 0x4AA02C, 1, 70, 70, 5, 3, false, false, false);
		private var growFilter_4:GlowFilter = new GlowFilter(0xFDD017, 2, 20, 10, 2, 3, true, false);
		private var growFilter_b_4:GlowFilter = new GlowFilter(0xFDD017, 2, 16, 10, 3, 9, false, false);
		private var dropShadow_4:DropShadowFilter = new DropShadowFilter(0, 360, 0xFDD017, 1, 70, 70, 5, 3, false, false, false);
What events we have here?
First we add the sp(Sprite) to the stage, then we add an Enter_Frame event to our Sprite, draw each button and create a Click event for each one in order to change from color and effect.
		public function LineEffect()
			this.addChild(sp);
			this.addEventListener(Event.ENTER_FRAME, onEnter);
			drawFireBtn(fireBtn);
			drawSkyBtn(skyBtn);
			drawGrassBtn(grassBtn);
			drawSunBtn(sunBtn);
			fireBtn.addEventListener(MouseEvent.CLICK, makeFire);
			skyBtn.addEventListener(MouseEvent.CLICK, makeSky);
			grassBtn.addEventListener(MouseEvent.CLICK,makeGrass);
			sunBtn.addEventListener(MouseEvent.CLICK, makeSun);
			sp.filters = [bf, dropShadow];
Enter Frame Function
The following Enter Frame function will track the mouse coordinates and show the effect on the stage .
		private function onEnter(e:Event):void
			var line:Graphics = sp.graphics;
			line.clear();
			line.lineStyle(2, 0xffffff);
			line.moveTo(mouseX, mouseY);
            var dx:Number = this.mouseX - prevmouseX;
			var vx:Number = dx ? dx : Math.random() * randSet(-1, 1);
			var dy:Number = this.mouseY - prevmouseY;
			var vy:Number = dy ? dy : Math.random() * randSet(-1, 1);
			var pLen:Number = points.push({x:this.mouseX, y:this.mouseY, vx:vx / 20, vy:vy / 20, life:getTimer()});
			for (var i:Number = 0; i < pLen; i++)
				if (!points[i])
					continue
				if (getTimer() - points[i].life > 1000)
					points.splice(i--, 1)
				else
					if (i!=0 && points[i])
						points[i].x += points[i].vx;
						points[i].y += points[i].vy;
						var cx:Number = points[i - 1].x;
						var cy:Number = points[i - 1].y;
						line.curveTo(cx, cy, (points[i].x + cx) * 0.5, (points[i].y + cy) * 0.5 );
					else
						line.moveTo(points[i].x, points[i].y);
			prevmouseX = this.mouseX;
			prevmouseY = this.mouseY;
                private function randSet(p_min:Number,p_max:Number):Number
			return Math.floor(Math.random() * 2);
Draw the buttons and make the click events
Now we write a function for each button that applies the colors and effects we have created in the beginning. On each function we insert the text buttons into the stage by drawing it with actionscript 3.0 using the drawRect class and we choose the rectangle fill color. Then we create a second function inside this one which calls the MouseEvent we have mentioned above and will start the effect.
private function drawFireBtn(obj:MovieClip):void
			with(obj.graphics)
				beginFill(0x0000ff,0);
			    drawRect(0,0,20,20);
			    endFill();
			fireTF.text = "Fire"
			fireTF.textColor = 0x666666;
			fireTF.mouseEnabled = false;
			fireTF.selectable = false;
			this.addChild(obj);
			obj.buttonMode = true;
			obj.addChild(fireTF);
			obj.x = 20;
			obj.y = 380;
		private function makeFire(E:MouseEvent):void
			sp.filters = [bf,growFilter,growFilter_b,dropShadow];
		private function drawSkyBtn(obj:MovieClip):void
			with(obj.graphics)
			    endFill();
			skyTF.text = "Sky"
			skyTF.textColor = 0x666666;
			skyTF.mouseEnabled = false;
			skyTF.selectable = false;
			this.addChild(obj);
			obj.addChild(skyTF);
			obj.x = 70;
			obj.y = 380;
		private function makeSky(e:MouseEvent):void
			sp.filters = [bf,growFilter_2,growFilter_b_2,dropShadow_2];
		private function drawGrassBtn(obj:MovieClip):void
			with(obj.graphics)
			    drawRect(0,0,25,20);
			    endFill();
			grassTF.text = "Grass"
			grassTF.textColor = 0x666666;
			grassTF.mouseEnabled = false;
			grassTF.selectable = false;
			this.addChild(obj);
			obj.addChild(grassTF);
			obj.x = 120;
			obj.y = 380;
		private function makeGrass(e:MouseEvent):void
			sp.filters = [bf,growFilter_3,growFilter_b_3,dropShadow_3];
		private function drawSunBtn(obj:MovieClip):void
			with(obj.graphics)
			    endFill();
			sunTF.text = "Sun"
			sunTF.textColor = 0x666666;
			sunTF.mouseEnabled = false;
			sunTF.selectable = false;
			this.addChild(obj);
			obj.addChild(sunTF);
			obj.x = 170;
			obj.y = 380;
		private function makeSun(e:MouseEvent):void
			sp.filters = [bf,growFilter_4,growFilter_b_4,dropShadow_4];
This was the Line Effect tutorial. I hope it will be usefull for many of you. Now you can try to create your own line effects and drop a comment mentioning the url of your experiments. We are always looking for the results of our tutorials.
Leave a Reply
Your email address will not be published.
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <s> <strike> <strong>
