XML Tutorials - Herong's Tutorial Examples - v5.25, by Herong Yang
SAX (Simple API for XML) Programming Interface
This chapter provides tutorial notes and example codes on SAX (Simple API for XML). Topics include introduction to SAX programming interface; Original Java implementation of SAX; SAX 1.0 and 2.0 standards; Java example of parsing XML files using SAX; printing SAX parsing pattern.
What Is SAX (Simple API for XML)
Using SAX Implementation in JDK
Takeaways:
Table of Contents
Introduction of XML (eXtensible Markup Language)
DOM (Document Object Model) Programming Interface
►SAX (Simple API for XML) Programming Interface
DTD (Document Type Definition) Introduction
Validating an XML Document against the Specified DTD Document Type
XSD (XML Schema Definition) Introduction
Validating XML Documents Against Specified XML Schemas
XSL (Extensible Stylesheet Language) Introduction
XSLT (XSL Transformations) Introduction
XSLT Elements as Programming Statements
Control and Generate XML Element in the Result
PHP Extensions for XML Manipulation
Processing XML with Python Scripts
XML Tools Plugin for Notepad++
XML Plugin Packages for Atom Editor
