Thursday, September 29, 2011
How to fix the .exe association settings using Registry editor
  • Click Start, Run and type Command
  • Type the following commands one by one:
cd\windows
regedit
  • If Registry Editor opens successfully, then navigate to the following key:
HKEY_CLASSES_ROOT \ exefile \ shell \ open \ command
  • Double-click the (Default) value in the right pane
  • Delete the current value data, and then type:
"%1" %*
(ie., quote-percent-one-quote-space-percent-asterisk.)
  • Navigate to:
HKEY_CLASSES_ROOT\.exe
  • In the right-pane, set (default) to exefile
  • Exit the Registry Editor.
This will re-associate the .exe file types
Read More About Windows, Android, Troubleshooting and latest Tips and Trick here Space For your Digital World
0 comments:
Post a Comment
