Sunday, October 23, 2011
Sony Vegas pro 11: Beginner tutorial "Getting started"
In this tutorial will you learn how to set the correct settings for your project and how to import and basic edit your recordings.
The first you will learn is how to set the right settings in File -> Properties by using the “Match media button”
Then you will learn how to trim, cut , move, insert text,  insert music, edit music and finally how to render your movie with the right settings.
No comments:
Post a Comment
