How to make a black-and-white photo from a color one with Soft4Boost Photo Studio?
Posted on July 22nd, 2013
General Photography
How to make a black-and-white photo from a color one?
Introduction
Sometimes you might need to make your color photo black-and-white. You can easily achieve this result using Soft4Boost Photo Studio. Besides you can adjust some additional settings to make the image look the way you want.
Step 1: Download and install Soft4Boost Photo Studio
Click here to download it. After the download is finished, run the S4BPhotoStudio.exe file and follow the installation wizard instructions.
[Back to the top]
Step 2: Run Soft4Boost Photo Studio and find the photo you want to edit
First of all run Soft4Boost Photo Studio. To do that find the corresponding program icon on your desktop and double-click it. If you unchecked the Create desktop icon box during the installation, you can run the program from the Start menu. Please follow Start > All Programs > Soft4Boost > Photo Studio.
After the program was launched, click the Browse tab on the left side of the window. In the Folders section you will see the folder tree that represents the files and folders structure of your computer. Open the necessary folders by left-clicking them. The contents of the folder that contains the image file you want to edit will be displayed in the panel situated at the bottom of the window and in the Preview Area as thumbnails. Double-click the necessary image and it will be displayed occupying the whole Preview Area.
[Back to the top]
Step 3: Make your photo black-and-white
As soon as you select an image by double-clicking it, the Edit tab will be opened. There you can see a number of sections situated one under another. Find the Presets section and left-click it once.
After that the section will open to let you view and select a preset from the list. Click the Black and White High Contrast preset. In the Preview Area you will see your picture getting black-and-white. This effect will be achieved by desaturing the photo and adding more contrast and brightness to it. If you are not satisfied with the result you can still correct some tone settings. For this purpose click the Tone Corrections section.
To adjust some of the settings drag an indicator along the slider or enter a value in the field next to the slider using the keyboard depending on the setting you want to change and then press the Enter key. After that view the result in the Preview Area.
You can experiment with these settings as you wish. If the result doesn't satisfy your needs, you can undo the last editing action by pressing the Undo button or bring the image back to its original state by pressing the Reset button. These buttons are situated at the bottom of the Edit tab.
[Back to the top]
Step 4: Save the edited photo
As soon as the needed photo is edited, you can save it. To do that click the File section of the Main Menu situated in the upper left corner of the program window. Here you can select one of the save options: Save and Save As.
That's all! So easily you can make your color photo black-and-white.
[Back to the top]
