As the title says. I have done as the instructions says. But when i come to the part where i am supposed to set so that it render with Brazil. But it only tells how to do with 3ds max's up to v.6 When i try to follow the instructions for v.6 its not right. HELP ME!
Need some help setting up Brazil.
Started by chrillen, Aug 10 2005 10:52 AM
8 replies to this topic
Posted 10 August 2005 - 10:52 AM
Posted 10 August 2005 - 11:11 AM
hit F10
go to the bottom
and where it says assign renderer, change it from default to brazil
go to the bottom
#3 _*Žeddragon_*
Posted 10 August 2005 - 12:16 PM
also there is a lock under it. Unlock it. This is for material. Brazil can not show it... So use Default or something else.
Posted 10 August 2005 - 01:13 PM
Thanks guys. Btw when im here. In brazil rio, is there some way to make it render bigger than 512x384. There seems to be some kind of restriction...
Edited by chrillen, 10 August 2005 - 01:17 PM.
#5 _*Žeddragon_*
Posted 10 August 2005 - 01:23 PM
It is the first tab that says Common. Look for output size and it has options for you to make the render bigger....It might take time to render though...But I never changed the Default size though..
Or it might because you are using the testing version or something. *shurgs*
#6
Posted 10 August 2005 - 01:25 PM
Not working! Im using the free version that i found at splutterfish.com
I really wanted a trial of the real version but couldnt find one.
#7 _*Žeddragon_*
Posted 10 August 2005 - 01:37 PM
Quote
What's Not In This Build
This build is based upon the current version of Brazil r/s, but is selectively feature-limited so as to make it primarily usable for educational and testing purposes. Rio is not designed or intended for use in professional or production environments and will not work well in a mixed "Brazil r/s" and "Brazil Rio" environment. A list of disabled features and limitations would include:
* no support for network rendering
* image size has been limited to 512x384 maximum
* file saving/loading limitations:
o scene files can be created/saved/loaded freely between Rio versions
o scene files saved in Brazil Rio will be loadable/savable in Brazil r/s
o scene files saved in Brazil r/s will be loadable, read-only, in Brazil Rio (meaning you will not be able to re-save the loaded file)
This version is much faster and more complete than previous public test builds and contains the same features that were used to generate all the images in the gallery at splutterfish.com.
Guess you would of read what it can't do... Well I don't know what to say. I got the student one. So I guess you can say you are a student and pay less.
#8
Posted 10 August 2005 - 01:39 PM
DAMN! Im not rich dammit. I suppose you have no idea on where to get a trial of the full version?
#9
Posted 10 August 2005 - 01:50 PM
http://www.splutterfish.com/sf/sf_gen_page...tents/docs/info
