My copy of photoshop CS2 isn't working, whenever I open it, it wont make it past the splash screen. It freezes up at "Reading text global resources..." I've tried to do the Repair thing and it still freezes up.
Photoshop CS2 problem
Started by zigzag8336, Nov 23 2005 06:00 PM
9 replies to this topic
Posted 23 November 2005 - 06:00 PM
Posted 23 November 2005 - 08:38 PM
Do/did you have a previous version of Photoshop that worked?
Posted 23 November 2005 - 10:58 PM
I had that problem at work.
Let it load for about 3-4 mins and it should eventually get in
Quit all other programs so you focus all your comp on Photoshop
It works, lol.
Posted 24 November 2005 - 12:06 AM
Ghost, I'm curious, did this happen once or does it do it every time you open PS?
Posted 24 November 2005 - 07:53 AM
i have had the exact same problem i tried for an absolute age to get it working but no luck...
just switched back to cs instead ( where i cant use any fonts ?)
#6
Posted 24 November 2005 - 01:19 PM
Look and see if Adobe have FAQ.
#8
Posted 27 November 2005 - 01:31 PM
I've got the same problem on my laptop and my PC. I dont think it's from a lack of memory, I have a Gigabyte in my PC.
#9
Posted 28 November 2005 - 01:06 PM
I had that problem, I restarted my computer and it works fine, I still have the problem of eraser wont erase anything, I need it for when Im drawing but the eraser is broken, I tried everything compared the settings of mine to a friends, all are the same...
#10
Posted 28 November 2005 - 02:17 PM
So many people have this problem. I used to get it quite regularly (once a week pretty much). Here is how u fix it (although it is a LONG time since I have done it now - since I last formatted my PC, it has been fine):
Go to the folder as follows:
C:\ (or w/e HDD is the main one) >> Documents and Settings >> (your XP username) >> Application Data >> Adobe >> Photoshop >> 9.0 (of w/e your version number is) >>
Then delete the folder called "Adobe Photoshop CS2 Settings". This will lose all of your settings, but it is the only way I found to fix it.
Hope that helps.
Hope that helps.
